I have an UNO using an ESP8266 to communicate with my pc via processing. I have the programs working for sending messages at the moment, but I'm hoping to send my sensor data and graph it on the processing side.
I have data that I want to send constantly, but I have also values that I want to send specifically while a particular process is running so that I can compare it. I don't know if an array is the best way of doing this but I suspect something will have to be done to compile it on the arduino side within the timeframe or ill lose repeatability on the wifi transmission.
Having a quick look at a C++ tutorial of arrays, it seems you need to specify the size when you declare it because the memory needs to be set aside. How do I know how big my array needs to be for a specific time frame?
trojanhawrs:
that's your decision (within limits).
a common approach to transmitting an unlimited amount of data is to allocate 2 buffers: ping and pong. while data is accumulating in one buffer, the other buffer is transmitted. 256 byte buffers might be reasonable.
of course code needs to keep track of where to insert data into a buffer, which buffer is being used to accumulate, which is being transmitted and when to swap buffers. pointers to the buffers make this convenient.
the assumption is that it takes less time to transmit the data than accumulate it. otherwise your limited by available memory and it is transmitted after capture
Hi gcjr, thanks for the reply. It might be worth mentioning that this particular data set is going to be running a maximum of 5 seconds (i dont know if that makes any difference as to whether I need to add more complicated code in or not).
I take it when you specify the size you're not required to fill it?
Buffer it is then, will start having a read up now.
If my sensor is being read by my analog pin 0-1023, is the most efficient variable for me to store that in a "byte"? I was looking at char but it seems that can only store up to 255
trojanhawrs:
trojanhawrs:
The char data type is meaningless if you're saving numeric values. Use a char for saving 8-bit characters, use the [
The byte data type is an Arduino-specific datatype that doesn't show the right intent either. It's fine for handling raw data such as network buffers, but not for numeric data.
If you want to store a 10-bit unsigned number, such as your analog reading, use uint16_t. It takes up two bytes, so you might need a data framing mechanism when you send them to another device.
Thanks for all the input gents, all still a bit over my head at the moment. Can anyone recommend some good tutorials that might give me a better grounding or am I as well to keep chucking shit at the wall and seeing what sticks?
trojanhawrs:
It all depends on you and how you learn best. There are many options:
trojanhawrs:
it's often time consuming to change, download, test, repeat. i use the the code to interactively run code by entering single character commands thru the serial monitor. it's takes a while to figure out what capabilities you need. the code makes it easy to add and change those capabilities
i've use this approach to run code that captures data and then dump it on the serial monitor. it allows parameters to be changed and then capture/dump more data.
i don't know of a tutorial to figure out what you need to do.
// pcRead - debugging using serial monitor
const char version [] = "PcRead 200416a";
int debug = 0;
// toggle output bit
void
pinToggle (
int pin)
static int bits = 0;
int bit = 1 << pin;
if (debug) {
Serial.print ("pinToggle: ");
Serial.println (pin);
if (bits & bit) {
digitalWrite (pin, LOW);
bits &= ~bit;
else {
digitalWrite (pin, HIGH);
bits |= bit;
int
readString (
char *s,
int maxChar )
int n = 0;
Serial.print ("> ");
do {
if (Serial.available()) {
int c = Serial.read ();
if ('\n' == c)
s [n++] = c;
if (maxChar == n)
} while (true);
return n;
// process single character commands from the PC
#define MAX_CHAR 10
char s [MAX_CHAR] = {};
int analogPin = 0;
void
pcRead (void)
static int val = 13;
switch (c) {
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
val = c - '0' + (10 * val);
case 'A':
analogPin = val;
Serial.print ("analogPin = ");
Serial.println (val);
val = 0;
case 'D':
debug ^= 1;
case 'I':
pinMode (val, INPUT);
Serial.print ("pinMode ");
Serial.print (val);
Serial.println (" INPUT");
val = 0;
case 'O':
pinMode (val, OUTPUT);
Serial.print (val);
Serial.println (" OUTPUT");
val = 0;
case 'P':
pinMode (val, INPUT_PULLUP);
Serial.print (val);
Serial.println (" INPUT_PULLUP");
val = 0;
case 'a':
Serial.print ("analogRead: ");
Serial.println (analogRead (val));
val = 0;
case 'c':
digitalWrite (val, LOW);
Serial.print ("digitalWrite: LOW ");
val = 0;
case 'p':
#if !defined(ARDUINO_ARCH_ESP32)
analogWrite (analogPin, val);
Serial.print ("analogWrite: pin ");
Serial.print (analogPin);
Serial.print (", ");
val = 0;
#endif
case 'r':
Serial.print ("digitalRead: pin ");
Serial.print (val);
Serial.println (digitalRead (val));
val = 0;
case 's':
digitalWrite (val, HIGH);
Serial.print ("digitalWrite: HIGH ");
val = 0;
case 't':
Serial.print ("pinToggle ");
pinToggle (val);
val = 0;
case 'v':
Serial.print ("\nversion: ");
Serial.println (version);
case '\n': // ignore
case '"':
while ('\n' != Serial.read ()) // discard linefeed
readString (s, MAX_CHAR-1);
Serial.println (s);
case '?':
Serial.println ("\npcRead:\n");
Serial.println (" [0-9] append to #");
Serial.println (" A # - set analog pin #");
Serial.println (" D # - set debug to #");
Serial.println (" I # - set pin # to INPUT");
Serial.println (" O # - set pin # to OUTPUT");
Serial.println (" P # - set pin # to INPUT_PULLUP");
Serial.println (" a # - analogRead (pin #)");
Serial.println (" c # - digitalWrite (pin #, LOW)");
Serial.println (" p # -- analogWrite (analogPin, #)");
Serial.println (" r # - digitalRead (pin #)");
Serial.println (" s - digitalWrite (pin #, HIGH)");
Serial.println (" t -- toggle pin # output");
Serial.println (" v - print version");
Serial.println (" \" - read string");
Serial.println (" ? - list of commands");
default:
Serial.print ("unknown char ");
Serial.println (c,HEX);
void
loop (void)
pcRead ();
void
setup (void)
#if defined(ARDUINO_ARCH_ESP32)
Serial.println ("esp32");
#endif
