I am trying to find a simple way to use pointer functions to build a FSM. I could not get many of the C examples on the net to compile in Arduino like this one:
typedef enum {STATE_A = 0, STATE_B} State_type;
// table with pointers to to the function
void (*state_table[]) = {state_a, state_b}; // this line gives error message
State_Type curr_state;
Setup() {}
Loop() {
state_table{curr_state]();
void state_a(){
// run state code
curr_state = STATE_B
void state_b(){
// run state code
curr_state = STATE_A
Please advise how to fix this version.
I managed to get the attached FunctionPointers-A working. But this variation, FunctionPointers-B, compiles but does not work.
I would appreciate it if someone could explain what my errors are.
Further what is a good text book explaining function pointers in (arduino) embedded systems?
Thank you!
Whandall:
I quite often use typedefs for function pointers, which keeps the declarations readable and makes changes easy.
typedef void (*vvFunction)();
vvFunction table[] = {state_a, state_b};
This is probably a rhetorical questions, but which do you think is easier for a beginner to read and understand? If these two lines were separated with a few lines of code (agreed...they shouldn't be), you still have to "splice" the two lines together to understand the data definition, which is why I would just use the single-line definition. It's really a matter of style as much as anything.
econjack:
In anything other than a trivial program the chances are that one is going to need a variable to hold the function pointer as well as the function pointer array. This variable needs to use the same function pointer definition so it makes sense to use a typdef rather than write out the same function pointer definition many many times.
I feel an array of some objects (here function pointers defined seperate) is less cryptic than defining all in one place.
Better naming than my lame try of the used type can help too.
We are looking at the most simple type of function, no parameters and no return value.
With more parameters and complicated return types those statements can get pretty hard to read,
even to experts.
Think of a pointer to a function returning some function...
If you use the function pointers in many places, passing them around etc. it's a pita to change all usages,
if the function interface changes even slightly.
I use that technique more in respect to maintainability/extendability and experienced typedefs in the function pointer context as helpful.
Whandall:
Certainly the naming (using Whandall's easy-to-read example) of the function pointer type and associated array name(s) may also aid in identifying what the programmer was doing (i.e. make less obscure):
