Understanding IR codes for Samsung TV
Hello Guys,
Can somebody help me to understand how could I use RAW IR data in an project using ESP8266-HTTP-IR-Blaster library ?
I've created a NodeMCU board with an IR sender and receiver according to GitHub - mdhiggins/ESP8266-HTTP-IR-Blaster: ESP8266 Compatible IR Blaster that accepts HTTP commands for use with services like Amazon Echo
Everything is working fine as long as I'm using the captured codes for ex.:
http:///msg?code=E0E040BF:SAMSUNG:32
This is the Code for the Power button (E0E040BF)
As I'm using it in a home automation system, it would very beneficial for me if I had a dedicated ON and OFF sequence, which I found here: RC: SAMSUNG PLASMA, LCD AND LED TV HEX CODES (Page 1 of 9) , but unable to translate, modify, or send it via RAW data.
Using Node-red, tried many ways, also implemented a MQTT client to the original project, but did not accept these codes anyhow I try. Does not sends it.
Also tried as a JSON, didn't help.
"type":"raw",
"data":"[0000, 006D, 0000, 0022, 00AC, 00AC, 0015, 0040, 0015, 0040, 0015, 0040, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0040, 0015, 0040, 0015, 0040, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0015, 0040, 0015, 0040, 0015, 0015, 0015, 0015, 0015, 0040, 0015, 0040, 0015, 0040, 0015, 0040, 0015, 0015, 0015, 0015, 0015, 0040, 0015, 0040, 0015, 0015, 0015, 0689]",
"khz":38
Any idea what could I try next?
