greetings guys.
I'm wrapping my head around this millis function because I'm eliminating the use of delay() in my code.
/* Blink without Delay
Turns on and off a light emitting diode (LED) connected to a digital
pin, without using the delay() function. This means that other code
can run at the same time without being interrupted by the LED code.
The circuit:
* LED attached from pin 13 to ground.
* Note: on most Arduinos, there is already an LED on the board
that's attached to pin 13, so no hardware is needed for this example.
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modified 11 Nov 2013
by Scott Fitzgerald
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to set a pin number :
const int waterpump = 7; // the number of the relay pin
// Variables will change :
int waterState = HIGH; // waterState used to set the pump
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change :
const long interval = 15* 60* 1000L; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(waterpump, OUTPUT);
if(currentMillis - previousMillis >= interval) {
// save the last time you pump
// if the LED is off turn it on and vice-versa:
if (waterState == HIGH)
waterState = LOW;
waterState = HIGH;
// set the LED with the ledState of the variable:
digitalWrite(waterpump, waterState);
I modified it from arduino blinkwithoutdelay sketch.
My pump doesn't run at all. Can anyone explain why?
*the wiring from pump to arduino is correct as my delay() code works before this.
This might not evaluate correctly, because, despite the stated result type on the left, and the L on the right, the first calculation will be 15*60.
Actually, that is not a problem, because there is no int overflow.
Your code looks OK to me. Did you manage to unplug the wire, somehow ?
Try blinking a led or writing something to Serial.print( ) to see if anything is happening.
michinyon:
michinyon:
hey man. the wiring is fine. i tested with this and it works.
int Pump = 7;
//int Light = 8;
pinMode (Pump, OUTPUT);
pinMode (Light, OUTPUT);
digitalWrite(Pump,HIGH); //turn on pump
delay(300000);
// digitalWrite(Light, HIGH); //turn on light
// delay(57600000);
digitalWrite(Pump,LOW); // turn off pump
delay (1200000);
// digitalWrite(Light, LOW);
// delay(28800000);
running the blingkingwithoutdelay example works too.
Well, as I said, your code looks OK.
You are not actually trying to drive the pump directly from your arduino digital output, are you ? that won't work.
michinyon:
update: seems like the pump first runs on 15mins OFF delay. That's why I thought it wasn't working. How should i tweak this?
michinyon:
Uhm, it does... 15 * 60 *1000 = 900000. Int can only be 65535. So 15 * 60 * 1000 will become 48032. So you need to make the first const match the unsigned long => 15UL * 60 *1000
So you want to have the pump running the first 15 minutes? Add the digitalWrite to setup. Also check out the rest of the small changes.
/* Blink without Delay-edit
const int WaterpumpPin = 7; // the number of the relay pin **better name
bool waterState = HIGH; // waterState used to set the pump **bool is okay
const unsigned long Interval = 15UL * 60* 1000; // interval at which to blink (milliseconds) **First const need to match the unsigned long
pinMode(WaterpumpPin, OUTPUT);
digitalWrite(WaterpumpPin, waterState); //**this makes it turn on at start
if(currentMillis - previousMillis >= Interval) {
waterState = !waterState; //Shorter/easier to read
waterState = LOW;
waterState = HIGH;
I don't think so.
15 * 60 will be treated as an int, and the answer will be 900
The second multiplication will be 900 * 1000L , an int x a long, and the result will be a long, a positive long, which should have no trouble being assigned to an unsigned long on the LHS of the assignment.
And if, for some reason, the compiler attempts to do this calculation from the other end, which would be legal because multiplication is associative, then it would be an int x a long, which is long, x another int, which is still a long.
You are right! I forgot to do it in steps, by bad.
But I hope the TS will now understand the need for the L of UL postfix. And by assigning it to the first const you know it's always right. Because the fact it works out this time is pure luck.
Thanks guys.
I added a light and another condition.
Am i doing this right?
#define ONESEC (1000UL)
#define ONEMIN (60*ONESEC)
#define ONEHOUR (60*ONEMIN)
const int pump = 7;
const int light = 8;
//Variables will change
bool pumpState = HIGH;
bool lightState = HIGH;
unsigned long previousMillis = 0; // will store the last time it was updated
//constant's wont change :
const unsigned long intervalLight = ( 16 * ONEHOUR);
const unsigned long intervalPumpOn = (10 * ONEMIN);
const unsigned long intervalPumpOff = (4 * ONEHOUR);
pinMode (pump, OUTPUT);
pinMode (light, OUTPUT);
digitalWrite(pump, pumpState);
digitalWrite(light, lightState);
if (currentMillis - previousMillis >= intervalLight) {
// save the last time light on
//if light is off turn it on and vice vera
lightState = !lightState;
//updatePump();
if (currentMillis - previousMillis >= intervalPumpOn) {
//save the last time the pump on
pumpState = HIGH;
if (currentMillis - previousMillis <= intervalPumpOff) {
pumpState = LOW;
digitalWrite( pump, pumpState);
trying to run the pump 10mins on and 4 hours off
It looks as if you need 4 sets of timer variables, one for your pump on period, one for your pump off period, one for your light on period and one for your light off period. (Only three if your light on period = your light off period.
It's not clear from your code)
unsigned long previousMillisPumpOn;
unsigned long previousMillisPumpOff;
unsigned long previousMillisLightOn;
unsigned long previousMillisLightOff;
Instead of 4 lots of currentMillis, just use millis(), which is, of course the current number of milliseconds since the Arduino was powered up or reset.
Also, look up 'State machine'. It may make your code simpler.
The code below might help.... I've put the BlinkWithoutDelay functionality in a function called bwod() and which is repeated as many times as needed as bwod2() etc. Those are called from loop(). Right at the top of the sketch, the on- and off-times are defined for each LED; they may all differ from one another.
(Meantime, I have re-done all of this as a library, which I'll post this weekend after a bit more testing....)
/* Blink without Delay in a function
by JimboZA.... this one puts bwod code in a function and
allows for differing off and on times
and for that to be with 3x independent LEDs
Turns on and off a light emitting diode(LED) connected to a digital
The circuit:
* LED2 attached from pin 12, 14, 15 to ground.
adapted from:
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
// set pin numbers:
const int ledPin = 12; // the number of the LED pin
const int led2Pin = 14;
const int led3Pin = 15;
// Variables will change:
//led1
int ledState = LOW; // ledState used to set the LED
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval; // interval at which to blink (milliseconds)
long onTime=890;
long offTime=105;
//led2
int led2State = LOW; // ledState used to set the LED
long previousMillis2 = 0; // will store last time LED was updated
long interval2; // interval at which to blink (milliseconds)
long onTime2=275;
long offTime2=260;
//led3
int led3State = LOW; // ledState used to set the LED
long previousMillis3 = 0; // will store last time LED was updated
long interval3; // interval at which to blink (milliseconds)
long onTime3=125;
long offTime3=1575;
pinMode(ledPin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
//and bwod() is where all the bwod stuff is done
bwod();
bwod2();
bwod3();
void bwod()
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
if (ledState == LOW)
ledState = HIGH;
interval=onTime;
ledState = LOW;
interval=offTime;
digitalWrite(ledPin, ledState);
} //end bwod
void bwod2()
// blink the LED.
unsigned long currentMillis2 = millis();
if(currentMillis2 - previousMillis2 > interval2) {
previousMillis2 = currentMillis2;
if (led2State == LOW)
led2State = HIGH;
interval2=onTime2;
led2State = LOW;
interval2=offTime2;
digitalWrite(led2Pin, led2State);
}//end bwod2
void bwod3()
// blink the LED.
unsigned long currentMillis3 = millis();
if(currentMillis3 - previousMillis3 > interval3) {
previousMillis3 = currentMillis3;
if (led3State == LOW)
led3State = HIGH;
interval3=onTime3;
led3State = LOW;
interval3=offTime3;
digitalWrite(led3Pin, led3State);
}//end bwod3
