Hi everybody,
inspired by a possibly I2C-problem of a user I came across this non-blocking I2C-library from Github-user nitacku
I want to test this library but I do not yet understand the documentation and the example-codes
I started to analyse the demo-example
I added questions and comments to the demo-code
Copyright (c) 2018 PhotonicFusion LLC
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the "Software"),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
IN THE SOFTWARE.
@file Nonblocking_Read_RTC.ino
@summary Non-blocking read example using the PCF2129 RTC device
@version 1.0
@author nitacku
@data 16 August 2018
#include <inttypes.h>
#include <nI2C.h>
enum address_i2c_t : uint8_t
ADDRESS_I2C = 0x51, // Address of I2C device
// Device register addresses for PCF2129 RTC
enum address_t : uint8_t
ADDRESS_CONTROL_1 = 0x00,
ADDRESS_CONTROL_2 = 0x01,
ADDRESS_CONTROL_3 = 0x02,
ADDRESS_TIME = 0x03,
ADDRESS_DATE = 0x06,
ADDRESS_ALARM = 0x0A,
ADDRESS_CLOCKOUT = 0x0F,
ADDRESS_TIMESTAMP = 0x12,
// Global handle to I2C device
CI2C::Handle g_i2c_handle;
// Global buffer for received I2C data
// Could be allocated locally as long as the buffer remains in scope for the
// duration of the I2C transfer. Easiest guarantee is to simply make global.
// my questions:
// what determines the size of the buffer-array?
// what will happen if the buffersize is too small?
uint8_t g_rx_buffer[7];
// Callback function prototype
void RxCallback(const uint8_t error);
void setup(){
// Register device with address size of 1 byte using Fast communication (400KHz)
// my question:
// what does the "->" mean???
g_i2c_handle = nI2C->RegisterDevice(ADDRESS_I2C, 1, CI2C::Speed::FAST);
// Initialize Serial communication
void loop(){
// Perform non-blocking I2C read
// RxCallback() will be invoked upon completion of I2C transfer
// my questions:
// does this line of code do the following:
// do a read-operation on device registered with g_i2c_handle
// read register specified in ADDRESS_TIME
// use uint8_t array named "g_rx_buffer" to store the bytes sended by the I2C-slave
// read/receive the number of bytes specified by sizeof(g_rx_buffer)
// if receiving has finished call callbackfunction named "RxCallback"
uint8_t status = nI2C->Read(g_i2c_handle, ADDRESS_TIME, g_rx_buffer, sizeof(g_rx_buffer), RxCallback);
// some more questions:
// what does happen if the adress to read from is wrong?
if (status){
Status values are as follows:
0:success
1:busy
2:timeout
3:data too long to fit in transmit buffer
4:memory allocation failure
5:attempted illegal transition of state
6:received NACK on transmit of address
7:received NACK on transmit of data
8:illegal start or stop condition on bus
9:lost bus arbitration to other master
Serial.print("Communication Status #: ");
Serial.println(status);
// Wait 1 second before transmitting again
// Convert BCD numbers to human-readable format
uint8_t BCD_to_DEC(const uint8_t b){
return (b - (6 * (b >> 4)));
void RxCallback(const uint8_t status) {
// Check that no errors occurred
if (status == 0){
uint8_t second = BCD_to_DEC(g_rx_buffer[0]);
uint8_t minute = BCD_to_DEC(g_rx_buffer[1]);
uint8_t hour = BCD_to_DEC(g_rx_buffer[2]);
char time[15];
const char* format_string = PSTR("time: %02u:%02u:%02u");
snprintf_P(time, 15, format_string, hour, minute, second);
Serial.println(time);
else{
0:success
1:busy
2:timeout
last but not least: does anybody have experience with this library?
best regards Stefan
