Underwater Communications FSK modulation and demodulation
I need to perform underwater communications in a range up to 100m. I will use transceivers in order to create the sound waves. I will use FSK to modulate the data, lets say 100khz for value '0' and 110khz for value '1'. The data would be coded with RTTY/Baodot scheme.
I am a newbie with Arduino's technology and I would like to know if it is capable to perform all these operations:
1- Create a FSK modulation.
2- Receive FSK and demodulate it.
The RTTY seems to be fully implementated with some already done libraries.
I have seen some libraries like SoftModem that I could use but I am not completely sure.
What do you thing about it?
Thanks,
(No expert disclaimer)
I think you better use frequencies that are an integer divider of the 16MHz clock and that are a bit further apart. (easier to generate and easier to detect e.g 40Khz and 80Khz.
I said 100khz and 110khz just for giving an example. The frequencies that will be used will be determined by the resonance frequency of the transducer.
I just want to know if Arduino is suitable for this work and if it is capable to perform modulation/repeception/demodulation or if maybe would be better to use a FPGA.
Thanks,
