UniversalTelegramBot only receives one message
I have a strange behavior with the UniversalTelegramBot Lib on a ESP32.
First of all, the code was running on a ESP8266 like a charm. Then I started to port it to my ESP32 and now I only receive a message if it is already available for the first loop run. In the loop runs afterwards I do not receive anything.
I have no clue what's wrong with the code. Does not look so complicated.
I use the following versions of the libs.
ESP board v2.0.2
UniversalTelegramBot v 1.3.0
Arduino JSON v 6.18.0
I hope you can help me on this.
#include <analogWrite.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
/* ******************** configurtion ********************* */
// Replace with your network credentials
const char* p_ssid = "Skynet";
const char* p_password = "1234";
// Initialize Telegram BOT
#define BOTtoken "1234"
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can
// message you
#define CHAT_ID "1234"
/* ****************** public variables ******************** */
WiFiClientSecure p_TelegramClient;
UniversalTelegramBot p_bot(BOTtoken, p_TelegramClient);
// Checks for new messages every 1 second.
int p_botRequestDelay = 1000;
unsigned long p_lastTimeBotRan;
/* **************** function declarations **************** */
void handleNewMessages(int numNewMessages);
  WiFi.mode(WIFI_STA);
  WiFi.begin(p_ssid, p_password);
  p_TelegramClient.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
  Serial.print("Connecting to WiFi");
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi: ");
  Serial.println(p_ssid);
  Serial.print("Local IP address: ");
  // Telegram
  if (millis() > p_lastTimeBotRan + p_botRequestDelay)
    int numNewMessages = p_bot.getUpdates(p_bot.last_message_received + 1);
    while (numNewMessages)
      handleNewMessages(numNewMessages);
    p_lastTimeBotRan = millis();
//Handle what happens when you receive new messages
  Serial.println("handleNewMessages");
  Serial.println(String(numNewMessages));
  for (int i = 0; i < numNewMessages; i++) {
    // String to search for
    String text_ratio = "Current ratio: ";
    // Chat id of the requester
    String chat_id = String(p_bot.messages[i].chat_id);
    if ( chat_id != CHAT_ID )
      p_bot.sendMessage(chat_id, "I don't know you.", "");
      p_bot.sendMessage(chat_id, "Whatever...", "");
      // Print the received message
      String text = p_bot.messages[i].text;
      Serial.println(text);
      String from_name = p_bot.messages[i].from_name;
     if (text == "/start")
        String welcome = "Welcome, " + from_name + ".\n";
        p_bot.sendMessage(CHAT_ID, welcome, "");
I also tried the EchoBot example from the UniversalTelegramBot lib now. Same behavior. The first message was received and sent back. All others are not received.
also with the latest lib versions the problem stays the same :frowning:
After I played a little bit with the ESP32 I plugged in the ESP8266 again, which is also connected to this telegram bot channel.
The ESP8266 was receiving every message previously sent to the ESP32 again. Even if the ESP32 was echoing the message already. Very strange. Now I have no clue anymore whats wrong with it.
