UNO D1 R32 error loading sketch: Unable to verify flash chip connection (Invalid head of packet (0x01):
Hi there,
Ive just started trying an UNO D1 R32 board and can't load sketches.
After a successful compile, it fails with "Unable to verify flash chip connection (Invalid head of packet (0x01): Possible serial noise or corruption.).
Because of the"Possible serial noise or corruption" message, I have tried different cables, and they have been working with an ESP 32 Dev Module.
I'm using a MacBook M1.
Arduino IDE V 2.04
Esp board core 2.0.7
I have tried configuring the IDE for both ESP32 Dev Module as recommended on a number of sites, and also for the WEMOS D1 R32 both with the same result.
When I press the reset button a lot of text is output to the console.
I will be very grateful for any help.
Geoff
The full output from loading and boot output below:
Compile and Load output:
... all the compilation and linking messages...
followed by:
Global variables use 22536 bytes (6%) of dynamic memory, leaving 305144 bytes for local variables. Maximum is 327680 bytes.
"/Users/geoff/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool" --chip esp32 --port "/dev/cu.usbserial-110" --baud 921600  --before default_reset --after hard_reset write_flash  -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 "/private/var/folders/6p/phj0z64x2kddg7r3vpf8w3940000gn/T/arduino/sketches/D2295E8FD660C821CAE827D0E6875C9B/Test1.ino.bootloader.bin" 0x8000 "/private/var/folders/6p/phj0z64x2kddg7r3vpf8w3940000gn/T/arduino/sketches/D2295E8FD660C821CAE827D0E6875C9B/Test1.ino.partitions.bin" 0xe000 "/Users/geoff/Library/Arduino15/packages/esp32/hardware/esp32/2.0.7/tools/partitions/boot_app0.bin" 0x10000 "/private/var/folders/6p/phj0z64x2kddg7r3vpf8w3940000gn/T/arduino/sketches/D2295E8FD660C821CAE827D0E6875C9B/Test1.ino.bin"
esptool.py v4.5.1
Serial port /dev/cu.usbserial-110
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e0:e2:e6:0b:4e:08
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0x01): Possible serial noise or corruption.).
Failed uploading: uploading error: exit status 2
Output to the console when Reset button is pressed
09:46:15.615 -> �ets Jul 29 2019 12:21:46
09:46:15.615 ->
09:46:15.615 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
09:46:15.615 -> configsip: 0, SPIWP:0xee
09:46:15.615 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
09:46:15.615 -> mode:DIO, clock div:2
09:46:15.615 -> load:0x3fff0018,len:4
09:46:15.615 -> load:0x3fff001c,len:5564
09:46:15.615 -> load:0x40078000,len:0
09:46:15.615 -> load:0x40078000,len:13756
09:46:15.615 -> entry 0x40078fb4
09:46:15.615 -> e[0;32mI (29) boot: ESP-IDF v3.0.3 2nd stage bootloadere[0m
09:46:15.647 -> e[0;32mI (29) boot: compile time 08:53:32e[0m
09:46:15.647 -> e[0;32mI (29) boot: Enabling RNG early entropy source...e[0m
09:46:15.647 -> e[0;32mI (34) boot: SPI Speed      : 40MHze[0m
09:46:15.647 -> e[0;32mI (38) boot: SPI Mode       : DIOe[0m
09:46:15.647 -> e[0;32mI (42) boot: SPI Flash Size : 4MBe[0m
09:46:15.647 -> e[0;32mI (46) boot: Partition Table:e[0m
09:46:15.647 -> e[0;32mI (49) boot: ## Label            Usage          Type ST Offset   Lengthe[0m
09:46:15.678 -> e[0;32mI (57) boot:  0 phy_init         RF data          01 01 0000f000 00001000e[0m
09:46:15.678 -> e[0;32mI (64) boot:  1 otadata          OTA data         01 00 00010000 00002000e[0m
09:46:15.678 -> e[0;32mI (72) boot:  2 nvs              WiFi data        01 02 00012000 0000e000e[0m
09:46:15.678 -> e[0;32mI (79) boot:  3 at_customize     unknown          40 00 00020000 000e0000e[0m
09:46:15.711 -> e[0;32mI (87) boot:  4 ota_0            OTA app          00 10 00100000 00180000e[0m
09:46:15.711 -> e[0;32mI (94) boot:  5 ota_1            OTA app          00 11 00280000 00180000e[0m
09:46:15.711 -> e[0;32mI (102) boot: End of partition tablee[0m
09:46:15.711 -> e[0;32mI (106) boot: No factory image, trying OTA 0e[0m
09:46:15.711 -> e[0;32mI (111) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x200f4 (131316) mape[0m
09:46:15.775 -> e[0;32mI (166) esp_image: segment 1: paddr=0x0012011c vaddr=0x3ffc0000 size=0x02d6c ( 11628) loade[0m
09:46:15.775 -> e[0;32mI (171) esp_image: segment 2: paddr=0x00122e90 vaddr=0x40080000 size=0x00400 (  1024) loade[0m
09:46:15.775 -> e[0;32mI (173) esp_image: segment 3: paddr=0x00123298 vaddr=0x40080400 size=0x0cd78 ( 52600) loade[0m
09:46:15.809 -> e[0;32mI (203) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xdf390 (914320) mape[0m
09:46:16.137 -> e[0;32mI (524) esp_image: segment 5: paddr=0x0020f3b0 vaddr=0x4008d178 size=0x01f14 (  7956) loade[0m
09:46:16.137 -> e[0;32mI (527) esp_image: segment 6: paddr=0x002112cc vaddr=0x400c0000 size=0x00064 (   100) loade[0m
09:46:16.137 -> e[0;32mI (539) boot: Loaded app from partition at offset 0x100000e[0m
09:46:16.137 -> e[0;32mI (539) boot: Disabling RNG early entropy source...e[0m
09:46:16.202 -> Bin version(Wroom32):1.1.2
09:46:16.202 -> I (638) wifi: wifi firmware version: de47fad
09:46:16.202 -> I (639) wifi: config NVS flash: enabled
09:46:16.202 -> I (639) wifi: config nano formating: disabled
09:46:16.202 -> I (649) wifi: Init dynamic tx buffer num: 32
09:46:16.202 -> I (649) wifi: Init data frame dynamic rx buffer num: 32
09:46:16.202 -> I (649) wifi: Init management frame dynamic rx buffer num: 32
09:46:16.234 -> I (655) wifi: wifi driver task: 3ffded44, prio:23, stack:3584
09:46:16.234 -> I (660) wifi: Init static rx buffer num: 10
09:46:16.234 -> I (663) wifi: Init dynamic rx buffer num: 32
09:46:16.234 -> I (668) wifi: wifi power manager task: 0x3ffdfe10 prio: 21 stack: 2560
09:46:16.301 -> I (731) wifi: mode : softAP (e0:e2:e6:0b:4e:09)
09:46:16.301 -> I (739) wifi: mode : sta (e0:e2:e6:0b:4e:08) + softAP (e0:e2:e6:0b:4e:09)
09:46:16.301 -> I (743) wifi: mode : softAP (e0:e2:e6:0b:4e:09)
PS:
I don't know whether this is relevant:
When the board is plugged in it creates a network ESB_0B04E09 That I can connect to without a password.
When connected to ESB_0B04E09, I can ping 192.168.4.1, but can't open that IPaddress in Safari or Chrome. Chrome responds with:
# This site can’t be reached
**192.168.4.1** refused to connect.
Try:
* Checking the connection
* [Checking the proxy and the firewall](chrome-error://chromewebdata/#buttons)
ERR_CONNECTION_REFUSED
:clap: :clap: :clap:
Whew..
I've tried everything I can think of.
What worked:
running esptool from the command line with a BAUD rate of 115200 instead of the 921600 that the IDE was doing.
Is there somewhere I can set the default BAUD rate for this board?
I've tried searching my Mac for "baud" hoping to find a json or other configuration file with no success.
... and I found where to set the upload speed on the tools menu.
And would that be? trying to connect my macbook air M2 to an esp32 and getting this error:
A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0xE0): Possible serial noise or corruption.).
Thanks Francois
115200 worked for me. Otherwise try lower BAUD rates.
I hope this helps.
Thanks worked perfectly…
:+1:
Thanks a lot
I spend a day to the problem of uploading program to ESP32-9102x
but fail to solve until I read this post!!!!!
Thanks Thanks Thanks a lot
