Anyone able to sucessfully flash edge impulse example on UNO Q?
west flash -r openocd
Facing below error with above command:
west flash: using runner openocd
-- runners.openocd: Flashing file: /home/edge_impulse/zephyrproject/example-standalone-inferencing-zephyr-module/build/zephyr/zephyr.hex
Open On-Chip Debugger 0.12.0-01018-gb89d626c6 (2025-08-15-10:01)
Licensed under GNU GPL v2
For bug reports, read OpenOCD: Bug Reporting
Error: Debug Adapter has to be specified, see "adapter driver" command
Hi @pravijet ,
Welcome to the forum..
no, I've never dabbled in any of this..
I advise to make sure you unoQ is listed in adb devices, step 1..
Sounds like your west terminal did not use the Debug bridge you also had opened in the other terminal..
You did have 2 terminals opened, Debug bridge started on one and using the other for west??
night and day..
they are not related at all to each other besides each having bridge in their name..
The Debug Bridge is what Edge Impulse is utilizing to upload..
they are not using AppLab not even sure if Arduino is in use either and it seems quite complicated to follow..
It is all explained in the link dropped in post#1..
~q
Thanks for your response. Yes, I have two terminals open—one for the debug bridge and another for flashing using west, as mentioned in the Edge Impulse documentation. However, I still get the error mentioned at the beginning of the post.
sorry I am in no way setup to accomplish that..
never used Edge Impulse before, instructions seem to be for linux..
might want to try their forums if they exists..
good luck.. ~q
