UNO R4 attachInterrupt()
I was trying to measure R4 crystal frequency error with GPS PPS and attachInterrupt(). I got no response from sketch. So I made this simple sketch
#define PPSPIN 7
volatile unsigned long us;
volatile int ticks;
void handler() {
  ticks++;
  while (!Serial);
  analogWrite(6, 128);
  attachInterrupt(7, handler, RISING);
  Serial.println(ticks);
The sketch should report number of ticks per second from the PWM output (pin 6) to pin 7. Only 0's are printed??? I confirmed with scope that pin 6 was producing 490 hz sq wave .
should attachInterrupt be working?
Try digitalPinToInterrupt( 7 ) instead of just 7
digitalPinToInterrupt( 7 ) didn't help. i confirmed digitalPinToInterrupt( 7 ) equals 7.
However, attachinterrupt works on pins 2, 3,8,13 and fails on 7 and 5 .... I haven't tested all pins.
Using pin 13 for GPS PPS and using the cycle counter ARM_DWT_CYCCNT, my R4 crystal is fast by 10 ppm (some jitter)
Unfortunately, it looks like the documentation has not yet been updated to reflect this new board:
In the meantime corrected, see:
https://docs.arduino.cc/language-reference/en/functions/external-interrupts/attachInterrupt/
reference.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/
Looks like the interrupt pins are defined in the pinsmux.h file in the variants directory for the board.
Based on that the pins can be used for interrupts:
0, 1, 2, 3, 8, 12, 13, 15, 16, 17, 18 and 19.
I did test all of those pins using a encoder (one side only). All worked to count except D15 was counting even if I didn't turn the encoder so maybe something was active.
It takes about 2.7uS from a pin input edge to the start of the interrupt call code.
  attachInterrupt(2, pinIrq, RISING);
calling:
void pinIrq(void)
  *PFS_P103PFS_BY = 0x05;      // D4
  *PFS_P103PFS_BY = 0x04;      //
I wonder if that means that "lazy context save" for the floating point hardware has not been turned on?
Try adding FPU->FPCCR |= FPU_FPCCR_ASPEN_Msk | FPU_FPCCR_LSPEN_Msk; in setup or something.
Interesting...
Still the same, I assume there is some code that would also need to be removed.
Okay, here is a method to get at ANY of the R4 interrupts:
This example shows an ADC complete interrupt on the right (which just pulses the port pin) after the ADC read and start new conversion time on the left.
Code here: Demonstration code to attach an interrupt call to any event.
brilliant stuff, I look forward trying out the code, when I get a chance to see how much I can push the DSP at such high speeds
Hi Susan. Many tanks for the information you provided. I'm still trying to get my head around the code :wink:
How will this code look like if I wanted a Interrupt on the Overflow of GPT7 counter?
Regards,
  attachInterrupt(13, timer7interrupt, FALLING);        // This IRQ will be asigned to Slot 05 IELSR05 as 0x001 PORT_IRQ0 - Table 13.4
  *ICU_IELSR05 = IRQ_GPT7_OVF;                          // Assign Slot 05 IELSR05 for GPT7_OVF
  *PFS_P111PFS = 0x00000000;                            // Clear D13 ISEL pin assigned Interrupt Enable
:slight_smile:
Thank you very much for your response. I will give that a try :slight_smile:
Should I presume that the attachInterrupt() function will always allocate ICU_IELSR05 Slot 5?
What will the the low-level code for attachInterrupt() look like even if it is for a specific peripheral? Maybe to advanced for this forum?! :wink:
Thanks,
M
Yes, as long as it's the absolutely first thing in setup() it will be the first one allocated and so will go into ICU_IELSR05 Slot 5
Here is the top and tail from my timer 7 interrupt, which reads the ADC and updates the DAC.
void timer7interrupt(void)  // As declaired in the HiJack for the original pin interrupt
//  static uint16_t localValA0 = 0;  // Board input ADC A0 used for DAC output
  static uint16_t localValA1 = 0;  // Board input ADC A1
  static uint16_t localValA2 = 0;  // Board input ADC A1
  static uint16_t localCount = 0;
  static uint8_t test = 0;
  *PFS_P107PFS_BY = 0x05;      // Set D7 to show start of Timer Interrupt
// ==== ADC ====
//  adc_val_A0 = *ADC140_ADDR09;    // adcValue - internal 16bit register read = c. 123nS
  adc_val_A1 = *ADC140_ADDR00;    //
  adc_val_A2 = *ADC140_ADDR01;    //
  *ADC140_ADCSR |= (0x01 << 15);  // Next ADC conversion = c. 300nS
Lots of code here to do stuff :)
// ==== PWM ====
  *GPT167_GTCCRC = 0x000; // Min PWM value
  *GPT167_GTCCRD = 0x7FD; // Max PWM value
// ==== DAC ====
  *DAC12_DADR0 = (adc_val_A1 >> 2);  // DAC will update after all ADC conversions have finished
  *PFS_P107PFS_BY = 0x04;      // Clear D7 Interrupt Monitor pin
  }                            // Current IRQ time is 10.4uS
Naturally one would do something more useful with the PWM part.
I hope to be putting up something more specific to just the timers soon, but for the meantime look at:
https://github.com/TriodeGirl/M4_Minima_Test_Code_Fast-PWM_SPI_IRQ_ADC_DAC_SCI/blob/main/M4_Minima_Test_Code_Fast-PWM_SPI_IRQ_ADC_DAC_SCI_1a.ino#L1644
Hope this helps.
Hi Susan. Thank you very much for your help. I'll have a look at the link you provided. :slight_smile:
Would it be possible for you to help me with the below code. I'm I going in the right direction? It's a bit of topic in this forum topic.
I'm trying write a LED "blink" code but in low-level code for the UNO R4. I basically want to use GWT7 to generate a 1 Hz pulse on Pin 9 of the UNO. I have added comment to my code. I have uploaded it to my UNO R4 Minima but it is not working. I'm I missing something?
I recently "discovered" PlatformID and so far, it is looking great.
#include <Arduino.h>
//Initiate GPT7
void iniGPT()
  // Renesas (R7FA4M1AB3CFM#AA0)
  //  General PWM 16bit Timer (GPT7)
  //  GTCIO7A(P304)=Pin D9 on UNO
  //Set the initial value in the GTCNT counter to zero.
  R_GPT7->GTCNT=0;
  //Set GTIOC pin function. (Table 22.5)
  //Initial output is low, toggle output at cycle end and Output retained at GTCCRA/GTCCRB compare match.
  //Enable Output A.
  R_GPT7->GTIOR=(B01100<<R_GPT0_GTIOR_GTIOA_Pos)|(1<<R_GPT0_GTIOR_OAE_Pos);
  //Set count direction to count up.
  R_GPT7->GTUDDTYC=(1<<R_GPT0_GTUDDTYC_UD_Pos);
  //Set cycle value to overflow at 500 ms. 50% of period.
  R_GPT7->GTPR=23438;
  //GPT7 Start Count operation and set prescaler to PCLKD/1024
  R_GPT7->GTCR=(1<<R_GPT0_GTCR_CST_Pos)|(0x101<<R_GPT0_GTCR_TPCS_Pos);
      pinMode(9,OUTPUT);
      digitalWrite(9,LOW);
      iniGPT();
  while(1==1);
Hi Susan
I had a look at your code and tried to use your example to implement the 1 Hz pulse on pin 9. Its is not working though :frowning:
See below
/*  Arduino UNO R4 Minima demo code for core RA4M1 peripheral operations:
 * NOTE: Pin allocation is as per R4 Minima, the R4 WiFi has many board-pins with different connections.
 *  Susan Parker - 10th July 2023 - Start.
 *  1. Fast digital pin operation
 *  2. Split ADC operation for non-blocking ADC reads inside GPT timer interrupt
 *  Working on Direct register setups of GPT3, GPT4 , and GPT7
 *  Susan Parker - 19th July 2023.
 *  3. How to attach an interrupt to any RA4M1 peripheral
 *  Susan Parker - 20th July 2023.
 *  4. Direct register setups of GPT3, GPT4 , and GPT7 for synchronised Phase Accurate PWM to buffered level shifting
 *  Susan Parker - 21th July 2023.
 *  5. Add serial SCI2 setup for D0 and D1
 *  6. Start IIC functions << work in progress
 *  Susan Parker - 22nd July 2023.
 *  7. Add DAC12
 *  Susan Parker - 23nd July 2023 > 1st August.
 *  8. SPI1 and SPI0 - SPI1 as Master, SPI0 as Slave - 8-bit to 32-bit transfers
 *     Use of SPI interrupts
 *     Change GPT3 to GPT1 for trangular phase-accurate PWM on pins D2 and D3
 *     Lots of tidying up and added comments
 * The Minima USB Serial is used for diagnostics and demonstration - would not be used in practise for a FastPWM application.
 * This code is "AS IS" without warranty or liability.
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
// Notes:
//  adc_val_A0 = analogRead(analogPin);  // blocking code takes between 22uS to 24uS to complete
//  For external aref - ADR4540 - Ultralow Noise, High Accuracy Voltage Reference
//    Using an aref gives c. +- 1 to 2 value in 14 bit reads on USB power
//    https://www.analog.com/media/en/technical-documentation/data-sheets/adr4520_4525_4530_4533_4540_4550.pdf
#include "Arduino.h"
/* The following c. 1200 lines of #defines for registers would normally go into a seperate .H file */
// ARM-developer - Accessing memory-mapped peripherals
// https://developer.arm.com/documentation/102618/0100
// ==== Clock Generation ====
#define SYSTEM 0x40010000 // ICU Base - See 13.2.6 page 233
#define SYSTEM_SCKDIVCR  ((volatile unsigned int *)(SYSTEM + 0xE020))  // System Clock Division Control Register
// SYSTEM_SCKDIVCR = 10010100
//   PCKD[2:0] = 4; 1/16
//   PCKC[2:0] = 1; 1/2
// ==== Interrupt Control Unit ====
/* Default Arduino Startup - see section 13.3.2 for Event Number info
 0 33 USBFS_USBI
 1 34 USBFS_USBR
 2 31 USBFS_D0FIFO
 3 32 USBFS_D1FIFO
 4 1E AGT0_AGTI
#define ICUBASE 0x40000000 // ICU Base - See 13.2.6 page 233
// 32 bits -
#define IELSR 0x6300 // ICU Event Link Setting Register n
#define ICU_IELSR00 ((volatile unsigned int *)(ICUBASE + IELSR))            //
#define ICU_IELSR01 ((volatile unsigned int *)(ICUBASE + IELSR + ( 1 * 4))) //
#define ICU_IELSR02 ((volatile unsigned int *)(ICUBASE + IELSR + ( 2 * 4))) //
#define ICU_IELSR03 ((volatile unsigned int *)(ICUBASE + IELSR + ( 3 * 4))) //
#define ICU_IELSR04 ((volatile unsigned int *)(ICUBASE + IELSR + ( 4 * 4))) //
#define ICU_IELSR05 ((volatile unsigned int *)(ICUBASE + IELSR + ( 5 * 4))) //
#define ICU_IELSR06 ((volatile unsigned int *)(ICUBASE + IELSR + ( 6 * 4))) //
#define ICU_IELSR07 ((volatile unsigned int *)(ICUBASE + IELSR + ( 7 * 4))) //
#define ICU_IELSR08 ((volatile unsigned int *)(ICUBASE + IELSR + ( 8 * 4))) //
#define ICU_IELSR09 ((volatile unsigned int *)(ICUBASE + IELSR + ( 9 * 4))) //
#define ICU_IELSR10 ((volatile unsigned int *)(ICUBASE + IELSR + (10 * 4))) //
#define ICU_IELSR11 ((volatile unsigned int *)(ICUBASE + IELSR + (11 * 4))) //
#define ICU_IELSR12 ((volatile unsigned int *)(ICUBASE + IELSR + (12 * 4))) //
#define ICU_IELSR13 ((volatile unsigned int *)(ICUBASE + IELSR + (13 * 4))) //
#define ICU_IELSR14 ((volatile unsigned int *)(ICUBASE + IELSR + (14 * 4))) //
#define ICU_IELSR15 ((volatile unsigned int *)(ICUBASE + IELSR + (15 * 4))) //
#define ICU_IELSR16 ((volatile unsigned int *)(ICUBASE + IELSR + (16 * 4))) //
#define ICU_IELSR17 ((volatile unsigned int *)(ICUBASE + IELSR + (17 * 4))) //
#define ICU_IELSR18 ((volatile unsigned int *)(ICUBASE + IELSR + (18 * 4))) //
#define ICU_IELSR19 ((volatile unsigned int *)(ICUBASE + IELSR + (19 * 4))) //
#define ICU_IELSR20 ((volatile unsigned int *)(ICUBASE + IELSR + (20 * 4))) //
#define ICU_IELSR21 ((volatile unsigned int *)(ICUBASE + IELSR + (21 * 4))) //
#define ICU_IELSR22 ((volatile unsigned int *)(ICUBASE + IELSR + (22 * 4))) //
#define ICU_IELSR23 ((volatile unsigned int *)(ICUBASE + IELSR + (23 * 4))) //
#define ICU_IELSR24 ((volatile unsigned int *)(ICUBASE + IELSR + (24 * 4))) //
#define ICU_IELSR25 ((volatile unsigned int *)(ICUBASE + IELSR + (25 * 4))) //
#define ICU_IELSR26 ((volatile unsigned int *)(ICUBASE + IELSR + (26 * 4))) //
#define ICU_IELSR27 ((volatile unsigned int *)(ICUBASE + IELSR + (27 * 4))) //
#define ICU_IELSR28 ((volatile unsigned int *)(ICUBASE + IELSR + (28 * 4))) //
#define ICU_IELSR29 ((volatile unsigned int *)(ICUBASE + IELSR + (29 * 4))) //
#define ICU_IELSR30 ((volatile unsigned int *)(ICUBASE + IELSR + (30 * 4))) //
#define ICU_IELSR31 ((volatile unsigned int *)(ICUBASE + IELSR + (31 * 4))) //
// IRQ Event Numbers
#define IRQ_NO_EVENT         0x00
#define IRQ_PORT_IRQ0        0x01
#define IRQ_PORT_IRQ1        0x02
#define IRQ_PORT_IRQ2        0x03
#define IRQ_PORT_IRQ3        0x04
#define IRQ_PORT_IRQ4        0x05
#define IRQ_PORT_IRQ5        0x06
#define IRQ_PORT_IRQ6        0x07
#define IRQ_PORT_IRQ7        0x08
#define IRQ_PORT_IRQ8        0x09
#define IRQ_PORT_IRQ9        0x0A
#define IRQ_PORT_IRQ10       0x0B
#define IRQ_PORT_IRQ11       0x0C
#define IRQ_PORT_IRQ12       0x0D
//      IRQ_PORT_UNUSED      0x0E
#define IRQ_PORT_IRQ14       0x0F
#define IRQ_PORT_IRQ15       0x10
#define IRQ_DMAC0_INT        0x11
#define IRQ_DMAC1_INT        0x12
#define IRQ_DMAC2_INT        0x13
#define IRQ_DMAC3_INT        0x14
#define IRQ_DTC_COMPLETE     0x15
//      IRQ_UNUSED           0x16
#define IRQ_ICU_SNZCANCEL    0x17
#define IRQ_FCU_FRDYI        0x18
#define IRQ_LVD_LVD1         0x19
#define IRQ_LVD_LVD2         0x1A
#define IRQ_VBATT_LVD        0x1B
#define IRQ_MOSC_STOP        0x1C
#define IRQ_SYSTEM_SNZREQ    0x1D
#define IRQ_AGT0_AGTI        0x1E
#define IRQ_AGT0_AGTCMAI     0x1F
#define IRQ_AGT0_AGTCMBI     0x20
#define IRQ_AGT1_AGTI        0x21
#define IRQ_AGT1_AGTCMAI     0x22
#define IRQ_AGT1_AGTCMBI     0x23
#define IRQ_IWDT_NMIUNDF     0x24
#define IRQ_WDT_NMIUNDF      0x25
#define IRQ_RTC_ALM          0x26
#define IRQ_RTC_PRD          0x27
#define IRQ_RTC_CUP          0x28
#define IRQ_ADC140_ADI       0x29
#define IRQ_ADC140_GBADI     0x2A
#define IRQ_ADC140_CMPAI     0x2B
#define IRQ_ADC140_CMPBI     0x2C
#define IRQ_ADC140_WCMPM     0x2D
#define IRQ_ADC140_WCMPUM    0x2E
#define IRQ_ACMP_LP0         0x2F
#define IRQ_ACMP_LP1         0x30
#define IRQ_USBFS_D0FIFO     0x31
#define IRQ_USBFS_D1FIFO     0x32
#define IRQ_USBFS_USBI       0x33
#define IRQ_USBFS_USBR       0x34
#define IRQ_IIC0_RXI         0x35
#define IRQ_IIC0_TXI         0x36
#define IRQ_IIC0_TEI         0x37
#define IRQ_IIC0_EEI         0x38
#define IRQ_IIC0_WUI         0x39
#define IRQ_IIC1_RXI         0x3A
#define IRQ_IIC1_TXI         0x3B
#define IRQ_IIC1_TEI         0x3C
#define IRQ_IIC1_EEI         0x3D
#define IRQ_SSIE0_SSITXI     0x3E
#define IRQ_SSIE0_SSIRXI     0x3F
//      IRQ_UNUSED           0x40
#define IRQ_SSIE0_SSIF       0x41
#define IRQ_CTSU_CTSUWR      0x42
#define IRQ_CTSU_CTSURD      0x43
#define IRQ_CTSU_CTSUFN      0x44
#define IRQ_KEY_INTKR        0x45
#define IRQ_DOC_DOPCI        0x46
#define IRQ_CAC_FERRI        0x47
#define IRQ_CAC_MENDI        0x48
#define IRQ_CAC_OVFI         0x49
#define IRQ_CAN0_ERS         0x4A
#define IRQ_CAN0_RXF         0x4B
#define IRQ_CAN0_TXF         0x4C
#define IRQ_CAN0_RXM         0x4D
#define IRQ_CAN0_TXM         0x4E
#define IRQ_IOPORT_GROUP1    0x4F
#define IRQ_IOPORT_GROUP2    0x50
#define IRQ_IOPORT_GROUP3    0x51
#define IRQ_IOPORT_GROUP4    0x52
#define IRQ_ELC_SWEVT0       0x53
#define IRQ_ELC_SWEVT1       0x54
#define IRQ_POEG_GROUP0      0x55
#define IRQ_POEG_GROUP1      0x56
#define IRQ_GPT0_CCMPA       0x57
#define IRQ_GPT0_CCMPB       0x58
#define IRQ_GPT0_CMPC        0x59
#define IRQ_GPT0_CMPD        0x5A
#define IRQ_GPT0_CMPE        0x5B
#define IRQ_GPT0_CMPF        0x5C
#define IRQ_GPT0_OVF         0x5D
#define IRQ_GPT0_UDF         0x5E
#define IRQ_GPT1_CCMPA       0x5F
#define IRQ_GPT1_CCMPB       0x60
#define IRQ_GPT1_CMPC        0x61
#define IRQ_GPT1_CMPD        0x62
#define IRQ_GPT1_CMPE        0x63
#define IRQ_GPT1_CMPF        0x64
#define IRQ_GPT1_OVF         0x65
#define IRQ_GPT1_UDF         0x66
#define IRQ_GPT2_CCMPA       0x67
#define IRQ_GPT2_CCMPB       0x68
#define IRQ_GPT2_CMPC        0x69
#define IRQ_GPT2_CMPD        0x6A
#define IRQ_GPT2_CMPE        0x6B
#define IRQ_GPT2_CMPF        0x6C
#define IRQ_GPT2_OVF         0x6D
#define IRQ_GPT2_UDF         0x6E
#define IRQ_GPT3_CCMPA       0x6F
#define IRQ_GPT3_CCMPB       0x70
#define IRQ_GPT3_CMPC        0x71
#define IRQ_GPT3_CMPD        0x72
#define IRQ_GPT3_CMPE        0x73
#define IRQ_GPT3_CMPF        0x74
#define IRQ_GPT3_OVF         0x75
#define IRQ_GPT3_UDF         0x76
#define IRQ_GPT4_CCMPA       0x77
#define IRQ_GPT4_CCMPB       0x78
#define IRQ_GPT4_CMPC        0x79
#define IRQ_GPT4_CMPD        0x7A
#define IRQ_GPT4_CMPE        0x7B
#define IRQ_GPT4_CMPF        0x7C
#define IRQ_GPT4_OVF         0x7D
#define IRQ_GPT4_UDF         0x7E
#define IRQ_GPT5_CCMPA       0x7F
#define IRQ_GPT5_CCMPB       0x80
#define IRQ_GPT5_CMPC        0x81
#define IRQ_GPT5_CMPD        0x82
#define IRQ_GPT5_CMPE        0x83
#define IRQ_GPT5_CMPF        0x84
#define IRQ_GPT5_OVF         0x85
#define IRQ_GPT5_UDF         0x86
#define IRQ_GPT6_CCMPA       0x87
#define IRQ_GPT6_CCMPB       0x88
#define IRQ_GPT6_CMPC        0x89
#define IRQ_GPT6_CMPD        0x8A
#define IRQ_GPT6_CMPE        0x8B
#define IRQ_GPT6_CMPF        0x8C
#define IRQ_GPT6_OVF         0x8D
#define IRQ_GPT6_UDF         0x8E
#define IRQ_GPT7_CCMPA       0x8F
#define IRQ_GPT7_CCMPB       0x90
#define IRQ_GPT7_CMPC        0x91
#define IRQ_GPT7_CMPD        0x92
#define IRQ_GPT7_CMPE        0x93
#define IRQ_GPT7_CMPF        0x94
#define IRQ_GPT7_OVF         0x95
#define IRQ_GPT7_UDF         0x96
#define IRQ_GPT_UVWEDGE      0x97
#define IRQ_SCI0_RXI         0x98
#define IRQ_SCI0_TXI         0x99
#define IRQ_SCI0_TEI         0x9A
#define IRQ_SCI0_ERI         0x9B
#define IRQ_SCI0_AM          0x9C
#define IRQ_SCI0_RXI_OR_ERI  0x9D
#define IRQ_SCI1_RXI         0x9E
#define IRQ_SCI1_TXI         0x9F
#define IRQ_SCI1_TEI         0xA0
#define IRQ_SCI1_ERI         0xA1
#define IRQ_SCI1_AM          0xA2
#define IRQ_SCI2_RXI         0xA3
#define IRQ_SCI2_TXI         0xA4
#define IRQ_SCI2_TEI         0xA5
#define IRQ_SCI2_ERI         0xA6
#define IRQ_SCI2_AM          0xA7
#define IRQ_SCI9_RXI         0xA8
#define IRQ_SCI9_TXI         0xA9
#define IRQ_SCI9_TEI         0xAA
#define IRQ_SCI9_ERI         0xAB
#define IRQ_SCI9_AM          0xAC
#define IRQ_SPI0_SPRI        0xAD
#define IRQ_SPI0_SPTI        0xAE
#define IRQ_SPI0_SPII        0xAF
#define IRQ_SPI0_SPEI        0xB0
#define IRQ_SPI0_SPTEND      0xB1
#define IRQ_SPI1_SPRI        0xB2
#define IRQ_SPI1_SPTI        0xB3
#define IRQ_SPI1_SPII        0xB4
#define IRQ_SPI1_SPEI        0xB5
#define IRQ_SPI1_SPTEND      0xB6
// ==== Event Link Controller ====
#define ELCBASE 0x40040000 // Event Link Controller
#define ELC_ELCR     ((volatile unsigned char  *)(ELCBASE + 0x1000))              // Event Link Controller Register
#define ELC_ELSEGR0  ((volatile unsigned char  *)(ELCBASE + 0x1002))              // Event Link Software Event Generation Register 0
#define ELC_ELSEGR1  ((volatile unsigned char  *)(ELCBASE + 0x1004))              // Event Link Software Event Generation Register 1
#define ELSR 0x1010        // Event Link Setting Registers
#define ELC_ELSR00   ((volatile unsigned short *)(ELCBASE + ELSR +( 0 * 4)))      // ELC_GPTA
#define ELC_ELSR01   ((volatile unsigned short *)(ELCBASE + ELSR +( 1 * 4)))      // ELC_GPTB
#define ELC_ELSR02   ((volatile unsigned short *)(ELCBASE + ELSR +( 2 * 4)))      // ELC_GPTC
#define ELC_ELSR03   ((volatile unsigned short *)(ELCBASE + ELSR +( 3 * 4)))      // ELC_GPTD
#define ELC_ELSR04   ((volatile unsigned short *)(ELCBASE + ELSR +( 4 * 4)))      // ELC_GPTE
#define ELC_ELSR05   ((volatile unsigned short *)(ELCBASE + ELSR +( 5 * 4)))      // ELC_GPTF
#define ELC_ELSR06   ((volatile unsigned short *)(ELCBASE + ELSR +( 6 * 4)))      // ELC_GPTG
#define ELC_ELSR07   ((volatile unsigned short *)(ELCBASE + ELSR +( 7 * 4)))      // ELC_GPTH
#define ELC_ELSR08   ((volatile unsigned short *)(ELCBASE + ELSR +( 8 * 4)))      // ELC_AD00 - ADC14A
#define ELC_ELSR09   ((volatile unsigned short *)(ELCBASE + ELSR +( 9 * 4)))      // ELC_AD01 - ADC14B
#define ELC_ELSR12   ((volatile unsigned short *)(ELCBASE + ELSR +(12 * 4)))      // ELC_DA0 - DAC12
#define ELC_ELSR14   ((volatile unsigned short *)(ELCBASE + ELSR +(14 * 4)))      // ELC_PORT1
#define ELC_ELSR15   ((volatile unsigned short *)(ELCBASE + ELSR +(15 * 4)))      // ELC_PORT2
#define ELC_ELSR16   ((volatile unsigned short *)(ELCBASE + ELSR +(16 * 4)))      // ELC_PORT3
#define ELC_ELSR17   ((volatile unsigned short *)(ELCBASE + ELSR +(17 * 4)))      // ELC_PORT4
#define ELC_ELSR18   ((volatile unsigned short *)(ELCBASE + ELSR +(18 * 4)))      // ELC_CTSU
// ==== Low Power Mode Control ====
#define SYSTEM 0x40010000 // System Registers
#define SYSTEM_SBYCR   ((volatile unsigned short *)(SYSTEM + 0xE00C))      // Standby Control Register
#define SYSTEM_MSTPCRA ((volatile unsigned int   *)(SYSTEM + 0xE01C))      // Module Stop Control Register A
#define MSTP 0x40040000 // Module Registers
#define MSTP_MSTPCRB   ((volatile unsigned int   *)(MSTP + 0x7000))      // Module Stop Control Register B
#define MSTPB2   2 // CAN0
#define MSTPB8   8 // IIC1
#define MSTPB9   9 // IIC0
#define MSTPB18 18 // SPI1
#define MSTPB19 19 // SPI0
#define MSTPB22 22 // SCI9
#define MSTPB29 29 // SCI2
#define MSTPB30 30 // SCI1
#define MSTPB31 31 // SCI0
#define MSTP_MSTPCRC   ((volatile unsigned int   *)(MSTP + 0x7004))      // Module Stop Control Register C
#define MSTP_MSTPCRD   ((volatile unsigned int   *)(MSTP + 0x7008))      // Module Stop Control Register D
#define MSTPD2   2 // AGT1   - Asynchronous General Purpose Timer 1 Module
#define MSTPD3   3 // AGT0   - Asynchronous General Purpose Timer 0 Module
#define MSTPD5   5 // GPT320 and GPT321 General 32 bit PWM Timer Module
#define MSTPD6   6 // GPT162 to GPT167 General 16 bit PWM Timer Module
#define MSTPD14 14 // POEG   - Port Output Enable for GPT Module Stop
#define MSTPD16 16 // ADC140 - 14-Bit A/D Converter Module
#define MSTPD19 19 // DAC8   -  8-Bit D/A Converter Module
#define MSTPD20 20 // DAC12  - 12-Bit D/A Converter Module
#define MSTPD29 29 // ACMPLP - Low-Power Analog Comparator Module
#define MSTPD31 31 // OPAMP  - Operational Amplifier Module
// These bits are read as 1, the write value should be 1.
// Bit value 0: Cancel the module-stop state
// Bit value 1: Enter the module-stop state.
// ==== 14-Bit A/D Converter ====
#define ADCBASE 0x40050000 /* ADC Base */
        // N/C = Pin not connected; N/A = No pin for LQFP64 package
// 16 bit registers
#define ADC140_ADDR00 ((volatile unsigned short *)(ADCBASE + 0xC020))      // A1 (P000 AN00 AMP+)
#define ADC140_ADDR01 ((volatile unsigned short *)(ADCBASE + 0xC020 +  2)) // A2 (P001 AN01 AMP-)
#define ADC140_ADDR02 ((volatile unsigned short *)(ADCBASE + 0xC020 +  4)) // A3 (P002 AN02 AMPO)
#define ADC140_ADDR03 ((volatile unsigned short *)(ADCBASE + 0xC020 +  6)) // N/C
#define ADC140_ADDR04 ((volatile unsigned short *)(ADCBASE + 0xC020 +  8)) // N/C
#define ADC140_ADDR05 ((volatile unsigned short *)(ADCBASE + 0xC020 + 10)) // Aref (P010 AN05 VrefH0)
#define ADC140_ADDR06 ((volatile unsigned short *)(ADCBASE + 0xC020 + 12)) // N/C
#define ADC140_ADDR07 ((volatile unsigned short *)(ADCBASE + 0xC020 + 14)) // TxLED (P012 AN07)
#define ADC140_ADDR08 ((volatile unsigned short *)(ADCBASE + 0xC020 + 16)) // RxLED (P013 AN08)
#define ADC140_ADDR09 ((volatile unsigned short *)(ADCBASE + 0xC020 + 18)) // A0 (P014 AN09 DAC)
#define ADC140_ADDR10 ((volatile unsigned short *)(ADCBASE + 0xC020 + 20)) // N/C
#define ADC140_ADDR11 ((volatile unsigned short *)(ADCBASE + 0xC020 + 22)) // N/A
#define ADC140_ADDR12 ((volatile unsigned short *)(ADCBASE + 0xC020 + 24)) // N/A
#define ADC140_ADDR13 ((volatile unsigned short *)(ADCBASE + 0xC020 + 26)) // N/A
#define ADC140_ADDR14 ((volatile unsigned short *)(ADCBASE + 0xC020 + 28)) // N/A
#define ADC140_ADDR16 ((volatile unsigned short *)(ADCBASE + 0xC040))      // R10/R26 net (P500 AN16)
#define ADC140_ADDR17 ((volatile unsigned short *)(ADCBASE + 0xC040 +  2)) // SWD-pin8 SCI1_TxD (P501 AN17)
#define ADC140_ADDR18 ((volatile unsigned short *)(ADCBASE + 0xC040 +  4)) // SWD-pin7 SCI1_RxD (P502 AN18)
#define ADC140_ADDR19 ((volatile unsigned short *)(ADCBASE + 0xC040 +  6)) // D4 (P103 AN19)
#define ADC140_ADDR20 ((volatile unsigned short *)(ADCBASE + 0xC040 +  8)) // D5 (P102 AN20 ADtrg0)
#define ADC140_ADDR21 ((volatile unsigned short *)(ADCBASE + 0xC040 + 10)) // A4 (P101 AN21 SDA)
#define ADC140_ADDR22 ((volatile unsigned short *)(ADCBASE + 0xC040 + 12)) // A5 (P100 AN20 SCL)
#define ADC140_ADDR23 ((volatile unsigned short *)(ADCBASE + 0xC040 + 14)) // N/A
#define ADC140_ADDR24 ((volatile unsigned short *)(ADCBASE + 0xC040 + 16)) // N/A
#define ADC140_ADDR25 ((volatile unsigned short *)(ADCBASE + 0xC040 + 18)) // N/A
#define ADC140_ADDBLDR  ((volatile unsigned short *)(ADCBASE + 0xC018))    // A/D Data Duplexing Register
#define ADC140_ADTSDR   ((volatile unsigned short *)(ADCBASE + 0xC01A))    // A/D conversion result of temperature sensor output
#define ADC140_ADOCDR   ((volatile unsigned short *)(ADCBASE + 0xC01C))    // A/D result of internal reference voltage
#define ADC140_ADDBLDRA ((volatile unsigned short *)(ADCBASE + 0xC084))    // A/D Data Duplexing Register A
#define ADC140_ADDBLDRB ((volatile unsigned short *)(ADCBASE + 0xC086))    // A/D Data Duplexing Register B
#define ADC140_ADCSR      ((volatile unsigned short *)(ADCBASE + 0xC000)) // A/D Control Register
#define ADC140_ADANSA0    ((volatile unsigned short *)(ADCBASE + 0xC004)) // A/D Channel Select Register A0
#define ADC140_ADANSA1    ((volatile unsigned short *)(ADCBASE + 0xC006)) // A/D Channel Select Register A1
#define ADC140_ADADS0     ((volatile unsigned short *)(ADCBASE + 0xC008)) // A/D-Converted Value Addition/Average Channel Select Register 0
#define ADC140_ADADS1     ((volatile unsigned short *)(ADCBASE + 0xC00A)) // A/D-Converted Value Addition/Average Channel Select Register 1
#define ADC140_ADCER      ((volatile unsigned short *)(ADCBASE + 0xC00E)) // A/D Control Extended Register
#define ADC140_ADSTRGR    ((volatile unsigned short *)(ADCBASE + 0xC010)) // A/D Conversion Start Trigger Select Register
#define ADC140_ADEXICR    ((volatile unsigned short *)(ADCBASE + 0xC012)) // A/D Conversion Extended Input Control Register
#define ADC140_ADANSB0    ((volatile unsigned short *)(ADCBASE + 0xC014)) // A/D Channel Select Register B0
#define ADC140_ADANSB1    ((volatile unsigned short *)(ADCBASE + 0xC016)) // A/D Channel Select Register B1
#define ADC140_ADRD       ((volatile unsigned short *)(ADCBASE + 0xC01E)) // A/D Self-Diagnosis Data Register
#define ADC140_ADGSPCR    ((volatile unsigned short *)(ADCBASE + 0xC080)) // A/D Group Scan Priority Control Register
#define ADC140_ADCMPCR    ((volatile unsigned short *)(ADCBASE + 0xC090)) // A/D Compare Function Control Register
#define ADC140_ADCMPANSR0 ((volatile unsigned short *)(ADCBASE + 0xC094)) // A/D Compare Function Window A Channel Select Register 0
#define ADC140_ADCMPANSR1 ((volatile unsigned short *)(ADCBASE + 0xC096)) // A/D Compare Function Window A Channel Select Register 1
#define ADC140_ADCMPLR0   ((volatile unsigned short *)(ADCBASE + 0xC098)) // A/D Compare Function Window A Comparison Condition Setting Register 0
#define ADC140_ADCMPLR1   ((volatile unsigned short *)(ADCBASE + 0xC09A)) // A/D Compare Function Window A Comparison Condition Setting Register 1
#define ADC140_ADCMPDR0   ((volatile unsigned short *)(ADCBASE + 0xC09C)) // A/D Compare Function Window A Lower-Side Level Setting Register
#define ADC140_ADCMPDR1   ((volatile unsigned short *)(ADCBASE + 0xC09E)) // A/D Compare Function Window A Upper-Side Level Setting Register
#define ADC140_ADWINLLB   ((volatile unsigned short *)(ADCBASE + 0xC0A8)) // A/D Compare Function Window B Lower-Side Level Setting Register
#define ADC140_ADWINULB   ((volatile unsigned short *)(ADCBASE + 0xC0AA)) // A/D Compare Function Window B Upper-Side Level Setting Register
#define ADC140_ADCMPSR0   ((volatile unsigned short *)(ADCBASE + 0xC0A0)) // A/D Compare Function Window A Channel Status Register 0
#define ADC140_ADCMPSR1   ((volatile unsigned short *)(ADCBASE + 0xC0A2)) // A/D Compare Function Window A Channel Status Register 1
// 8 bit registers
#define ADC140_ADADC      ((volatile unsigned char  *)(ADCBASE + 0xC00C)) // A/D-Converted Value Addition/Average Count Select Register
#define ADC140_ADDISCR    ((volatile unsigned char  *)(ADCBASE + 0xC07A)) // A/D Disconnection Detection Control Register
#define ADC140_ADHVREFCNT ((volatile unsigned char  *)(ADCBASE + 0xC08A)) // A/D High-Potential/Low-Potential Reference Voltage Control Register
#define ADC140_ADWINMON   ((volatile unsigned char  *)(ADCBASE + 0xC08C)) // A/D Compare Function Window A/B Status Monitor Register
#define ADC140_ADCMPANSER ((volatile unsigned char  *)(ADCBASE + 0xC092)) // A/D Compare Function Window A Extended Input Select Register
#define ADC140_ADCMPLER   ((volatile unsigned char  *)(ADCBASE + 0xC093)) // A/D Compare Function Window A Extended Input Comparison Condition Setting Register
#define ADC140_ADCMPSER   ((volatile unsigned char  *)(ADCBASE + 0xC0A4)) // A/D Compare Function Window A Extended Input Channel Status Register
#define ADC140_ADCMPBNSER ((volatile unsigned char  *)(ADCBASE + 0xC0A6)) // A/D Compare Function Window B Channel Select Register
#define ADC140_ADCMPBSR   ((volatile unsigned char  *)(ADCBASE + 0xC0AC)) // A/D Compare Function Window B Status Register
// 35.2.14 A/D Sampling State Register n (ADSSTRn) (n = 00 to 14, L, T, O)
#define ADC140_ADSSTR00 ((volatile unsigned char *)(ADCBASE + 0xC0E0))      // AN00
#define ADC140_ADSSTR01 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  1)) // AN01
#define ADC140_ADSSTR02 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  2)) // AN02
#define ADC140_ADSSTR03 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  3)) // AN03
#define ADC140_ADSSTR04 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  4)) // AN04
#define ADC140_ADSSTR05 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  5)) // AN05
#define ADC140_ADSSTR06 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  6)) // AN06
#define ADC140_ADSSTR07 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  7)) // AN07
#define ADC140_ADSSTR08 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  8)) // AN08
#define ADC140_ADSSTR09 ((volatile unsigned char *)(ADCBASE + 0xC0E0 +  9)) // AN09
#define ADC140_ADSSTR10 ((volatile unsigned char *)(ADCBASE + 0xC0E0 + 10)) // AN10
#define ADC140_ADSSTR11 ((volatile unsigned char *)(ADCBASE + 0xC0E0 + 11)) // AN11
#define ADC140_ADSSTR12 ((volatile unsigned char *)(ADCBASE + 0xC0E0 + 12)) // AN12
#define ADC140_ADSSTR13 ((volatile unsigned char *)(ADCBASE + 0xC0E0 + 13)) // AN13
#define ADC140_ADSSTR14 ((volatile unsigned char *)(ADCBASE + 0xC0E0 + 14)) // AN14
#define ADC140_ADSSTRL  ((volatile unsigned char *)(ADCBASE + 0xC0DD))      // AN16 to AN25
#define ADC140_ADSSTRT  ((volatile unsigned char *)(ADCBASE + 0xC0DE))      // Temp
#define ADC140_ADSSTRO  ((volatile unsigned char *)(ADCBASE + 0xC0DF))      // Iref
// ==== 12-Bit D/A Converter ====
#define DACBASE 0x40050000          // DAC Base - DAC output on A0 (P014 AN09 DAC)
#define DAC12_DADR0    ((volatile unsigned short *)(DACBASE + 0xE000))      // D/A Data Register 0
#define DAC12_DACR     ((volatile unsigned char  *)(DACBASE + 0xE004))      // D/A Control Register
#define DAC12_DADPR    ((volatile unsigned char  *)(DACBASE + 0xE005))      // DADR0 Format Select Register
#define DAC12_DAADSCR  ((volatile unsigned char  *)(DACBASE + 0xE006))      // D/A A/D Synchronous Start Control Register
#define DAC12_DAVREFCR ((volatile unsigned char  *)(DACBASE + 0xE007))      // D/A VREF Control Register
// =========== Ports ============
#define PORTBASE 0x40040000 /* Port Base */
// 19.2.1 Port Control Registers, to control/access multiple pins with a single operation
// Not all options defined for each register, expand as needed
#define PCNTR1 0x0000  // Port n Control Register 1 - 32bit access
#define PORT0_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1))              //
#define PORT1_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1 + (1 * 0x20))) //
#define PORT2_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1 + (2 * 0x20))) //
#define PORT3_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1 + (3 * 0x20))) //
#define PORT4_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1 + (4 * 0x20))) //
#define PORT5_PCNTR1 ((volatile unsigned int *)(PORTBASE + PCNTR1 + (5 * 0x20))) //
#define PODR 0x0000  // Port n Control Register 1 - Output Data
#define PORT0_PODR ((volatile unsigned short *)(PORTBASE + PODR))              //
#define PORT1_PODR ((volatile unsigned short *)(PORTBASE + PODR + (1 * 0x20))) //
#define PORT2_PODR ((volatile unsigned short *)(PORTBASE + PODR + (2 * 0x20))) //
#define PORT3_PODR ((volatile unsigned short *)(PORTBASE + PODR + (3 * 0x20))) //
#define PORT4_PODR ((volatile unsigned short *)(PORTBASE + PODR + (4 * 0x20))) //
#define PORT5_PODR ((volatile unsigned short *)(PORTBASE + PODR + (5 * 0x20))) //
#define PDR  0x0002  // Port n Control Register 1 - Pin Direction
#define PORT0_PDR ((volatile unsigned short *)(PORTBASE + PDR))              //
#define PORT1_PDR ((volatile unsigned short *)(PORTBASE + PDR + (1 * 0x20))) //
#define PORT2_PDR ((volatile unsigned short *)(PORTBASE + PDR + (2 * 0x20))) //
#define PORT3_PDR ((volatile unsigned short *)(PORTBASE + PDR + (3 * 0x20))) //
#define PORT4_PDR ((volatile unsigned short *)(PORTBASE + PDR + (4 * 0x20))) //
#define PORT5_PDR ((volatile unsigned short *)(PORTBASE + PDR + (5 * 0x20))) //
#define PIDR  0x0006  // Port n Control Register 2 - Pin State - For reading
#define PORT0_PIDR ((volatile unsigned short *)(PORTBASE + PIDR))              //
#define PORT1_PIDR ((volatile unsigned short *)(PORTBASE + PIDR + (1 * 0x20))) //
#define PORT2_PIDR ((volatile unsigned short *)(PORTBASE + PIDR + (2 * 0x20))) //
#define PORT3_PIDR ((volatile unsigned short *)(PORTBASE + PIDR + (3 * 0x20))) //
#define PORT4_PIDR ((volatile unsigned short *)(PORTBASE + PIDR + (4 * 0x20))) //
#define PORT5_PIDR ((volatile unsigned short *)(PORTBASE + PIDR + (5 * 0x20))) //
#define PORR 0x0008  // Port n Control Register 3 - Pin Reset (to Low Output)
#define PORT0_PORR ((volatile unsigned short *)(PORTBASE + PORR))              //
#define PORT1_PORR ((volatile unsigned short *)(PORTBASE + PORR + (1 * 0x20))) //
#define PORT2_PORR ((volatile unsigned short *)(PORTBASE + PORR + (2 * 0x20))) //
#define PORT3_PORR ((volatile unsigned short *)(PORTBASE + PORR + (3 * 0x20))) //
#define PORT4_PORR ((volatile unsigned short *)(PORTBASE + PORR + (4 * 0x20))) //
#define PORT5_PORR ((volatile unsigned short *)(PORTBASE + PORR + (5 * 0x20))) //
#define POSR  0x000A  // Port n Control Register 3 - Pin Set (to High Output)
#define PORT0_POSR ((volatile unsigned short *)(PORTBASE + POSR))              //
#define PORT1_POSR ((volatile unsigned short *)(PORTBASE + POSR + (1 * 0x20))) //
#define PORT2_POSR ((volatile unsigned short *)(PORTBASE + POSR + (2 * 0x20))) //
#define PORT3_POSR ((volatile unsigned short *)(PORTBASE + POSR + (3 * 0x20))) //
#define PORT4_POSR ((volatile unsigned short *)(PORTBASE + POSR + (4 * 0x20))) //
#define PORT5_POSR ((volatile unsigned short *)(PORTBASE + POSR + (5 * 0x20))) //
// 19.2.5 Port mn Pin Function Select Register (PmnPFS/PmnPFS_HA/PmnPFS_BY) (m = 0 to 9; n = 00 to 15)
// 32 bits - Use for setting pin functions to other than default pin I/O
// Note: These are the pin allocations for the R4 Minima - The WiFI has diferent pin assignments
// Note: Pin IRQxx on R4 Minima pins D0, D1, D2, D3, D8, D12, D13, D15, D16, D17, D18, D19 only
#define P000PFS 0x0800  // Port 0 Pin Function Select Register
#define PFS_P000PFS ((volatile unsigned int *)(PORTBASE + P000PFS))            // A1 / D15 - AN00 - AMP0+ - IRQ6
#define PFS_P001PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 1 * 4))) // A2 / D16 - AN01 - AMP0- - IRQ7
#define PFS_P002PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 2 * 4))) // A3 / D17 - AN03 - AMP0O - IRQ2
#define PFS_P003PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 3 * 4))) // N/C - AN03
#define PFS_P004PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 4 * 4))) // N/C - AN04 - IRQ3
#define PFS_P005PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 5 * 4))) // N/A - AN11 - IRQ10
#define PFS_P006PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 6 * 4))) // N/A - AN12
#define PFS_P007PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 7 * 4))) // N/A - AN13
#define PFS_P008PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 8 * 4))) // N/A - AN14
// #define PFS_P009PFS ((volatile unsigned int *)(PORTBASE + P000PFS + ( 9 * 4))) // Does not exist
#define PFS_P010PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (10 * 4))) // N/A - AN05
#define PFS_P011PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (11 * 4))) // N/C - AN06 - IRQ15
#define PFS_P012PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (12 * 4))) // TxLED - AN07
#define PFS_P013PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (13 * 4))) // RxLED - AN08
#define PFS_P014PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (14 * 4))) // A0 / D14 - AN09 - DAC0
#define PFS_P015PFS ((volatile unsigned int *)(PORTBASE + P000PFS + (15 * 4))) // N/C - AN10 - IRQ7
#define P100PFS 0x0840  // Port 1 Pin Function Select Register
#define PFS_P100PFS ((volatile unsigned int *)(PORTBASE + P100PFS))            // A5 / D19 - MISOA - SCL1 - IRQ2
#define PFS_P101PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 1 * 4))) // A4 / D18 - MOSIA - SDA1 - IRQ1
#define PFS_P102PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 2 * 4))) // D5 - RSPCKA
#define PFS_P103PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 3 * 4))) // D4 - SSLA0
#define PFS_P104PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 4 * 4))) // D3 - IRQ1
#define PFS_P105PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 5 * 4))) // D2 - IRQ0
#define PFS_P106PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 6 * 4))) // D6
#define PFS_P107PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 7 * 4))) // D7
#define PFS_P108PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 8 * 4))) // SWD p2 SWDIO
#define PFS_P109PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 9 * 4))) // D11 / MOSI
#define PFS_P110PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (10 * 4))) // D12 / MISO - IRQ3
#define PFS_P111PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (11 * 4))) // D13 / SCLK - IRQ4
#define PFS_P112PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (12 * 4))) // D10 / CS
#define PFS_P113PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (13 * 4))) // N/C
#define PFS_P114PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (14 * 4))) // N/A
#define PFS_P115PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (15 * 4))) // N/A
#define P200PFS 0x0880  // Port 2 Pin Function Select Register
#define PFS_P200PFS ((volatile unsigned int *)(PORTBASE + P200PFS))           // NMI
#define PFS_P201PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (1 * 4))) // MD
#define PFS_P202PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (2 * 4))) // N/A
#define PFS_P203PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (3 * 4))) // N/A
#define PFS_P204PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (4 * 4))) // LOVE (Heart Pad on underside of board)
#define PFS_P205PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (5 * 4))) // N/C - IRQ1
#define PFS_P206PFS ((volatile unsigned int *)(PORTBASE + P200PFS + (6 * 4))) // N/C - IRQ0
// Pins P212, P213, P214, and P215 are Crystal functions, or N/C
#define P300PFS 0x08C0  // Port 3 Pin Function Select Register
#define PFS_P300PFS ((volatile unsigned int *)(PORTBASE + P300PFS))            // SWD p4 SWCLK
#define PFS_P301PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 1 * 4))) // D0 / RxD - IRQ6
#define PFS_P302PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 2 * 4))) // D1 / TxD - IRQ5
#define PFS_P303PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 3 * 4))) // D9
#define PFS_P304PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 4 * 4))) // D8  - IRQ9
#define PFS_P305PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 5 * 4))) // N/C - IRQ8
#define PFS_P306PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 6 * 4))) // N/C
#define PFS_P307PFS ((volatile unsigned int *)(PORTBASE + P300PFS + ( 7 * 4))) // N/C
#define P400PFS 0x0900  // Port 4 Pin Function Select Register
#define PFS_P400PFS ((volatile unsigned int *)(PORTBASE + P100PFS))            // N/C - IRQ0
#define PFS_P401PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 1 * 4))) // N/C - IRQ5
#define PFS_P402PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 2 * 4))) // N/C - IRQ4
#define PFS_P403PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 3 * 4))) // N/A
#define PFS_P404PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 4 * 4))) // N/A
#define PFS_P405PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 5 * 4))) // N/A
#define PFS_P406PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 6 * 4))) // N/A
#define PFS_P407PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 7 * 4))) // ADTRG0 - R7, R8, and R9 divider.
#define PFS_P408PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 8 * 4))) // N/C - IRQ7
#define PFS_P409PFS ((volatile unsigned int *)(PORTBASE + P100PFS + ( 9 * 4))) // N/C - IRQ6
#define PFS_P410PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (10 * 4))) // N/C - IRQ5
#define PFS_P411PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (11 * 4))) // N/C - IRQ4
#define PFS_P412PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (12 * 4))) // N/A
#define PFS_P413PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (13 * 4))) // N/A
#define PFS_P414PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (14 * 4))) // N/A - IRQ9
#define PFS_P415PFS ((volatile unsigned int *)(PORTBASE + P100PFS + (15 * 4))) // N/A - IRQ8
#define P500PFS 0x0940  // Port 5 Pin Function Select Register
#define PFS_P500PFS ((volatile unsigned int *)(PORTBASE + P500PFS))           // AN016 in R10/R26 divider
#define PFS_P501PFS ((volatile unsigned int *)(PORTBASE + P500PFS + (1 * 4))) // SWD p8 TxD - IRQ11
#define PFS_P502PFS ((volatile unsigned int *)(PORTBASE + P500PFS + (2 * 4))) // SWD p7 RxD - IRQ12
#define PFS_P503PFS ((volatile unsigned int *)(PORTBASE + P500PFS + (3 * 4))) // N/A
#define PFS_P504PFS ((volatile unsigned int *)(PORTBASE + P500PFS + (4 * 4))) // N/A
#define PFS_P505PFS ((volatile unsigned int *)(PORTBASE + P500PFS + (5 * 4))) // N/A - IRQ14
#define PFS_PODR   0  // Pin Output Data     - 0: Low output; 1: High output
#define PFS_PIDR   1  // Pin Input State     - Read 0: Low level; 1: High level
#define PFS_PDR    2  // Pin Direction       - 0: Input (input pin); 1: Output (output pin)
#define PFS_PCR    4  // Pull-up Control     - 1: Enable internal pull-up
#define PFS_NCODR  6  // N-Channel Open Drain Control - 1: NMOS open-drain output.
#define PFS_DSCR  10  // Port Drive Capability - 1: Middle drive; Default 0: Low drive
#define PFS_EOR   12  // Event on Rising     - 1: Detect rising edge  - Set EOR and EOF both to 1
#define PFS_EOF   13  // Event on Falling    - 1: Detect falling edge - ... for Detect both edges
#define PFS_ISEL  14  // IRQ Input Enable    - 1: Used as an IRQn input pin.
#define PFS_ASEL  15  // Analog Input Enable - 1: Used as an analog pin.
#define PFS_PMR   16  // Pin Mode Control    - 1: Used as an I/O port for peripheral functions
#define PFS_PSEL_4_0 24 // Peripheral Function Select
// 16 bit register access
#define PFS_P100PFS_HA ((volatile unsigned short *)(PORTBASE + 0x0842))
#define PFS_P115PFS_HA ((volatile unsigned short *)(PORTBASE + 0x0842 + (15 * 2)))
#define PFS_P200PFS_HA ((volatile unsigned short *)(PORTBASE + 0x0882))
#define PFS_P206PFS_HA ((volatile unsigned short *)(PORTBASE + 0x0882 + (06 * 2))) //
// 8 bits - Used for fast pin set/clear operations of register lower byte
#define PFS_P000PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803))            // A1
#define PFS_P001PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 1 * 4))) // A2
#define PFS_P002PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 2 * 4))) // A3
#define PFS_P003PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 3 * 4))) // N/C
#define PFS_P004PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 4 * 4))) // N/C
#define PFS_P005PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 5 * 4))) // N/A
#define PFS_P006PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 6 * 4))) // N/A
#define PFS_P007PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 7 * 4))) // N/A
#define PFS_P008PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 8 * 4))) // N/A
// #define PFS_P009PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + ( 9 * 4))) //
#define PFS_P010PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (10 * 4))) // N/A
#define PFS_P011PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (11 * 4))) // N/C - P58 - VREFL0 << WTF!!!
#define PFS_P012PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (12 * 4))) // TxLED - VREFH
#define PFS_P013PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (13 * 4))) // RxLED - VREFL
#define PFS_P014PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (14 * 4))) // A0 - DAC0
#define PFS_P015PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0803 + (15 * 4))) // N/C
#define PFS_P100PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843))            // A5
#define PFS_P101PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 1 * 4))) // A4
#define PFS_P102PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 2 * 4))) // D5
#define PFS_P103PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 3 * 4))) // D4
#define PFS_P104PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 4 * 4))) // D3
#define PFS_P105PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 5 * 4))) // D2
#define PFS_P106PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 6 * 4))) // D6
#define PFS_P107PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 7 * 4))) // D7
#define PFS_P108PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 8 * 4))) // SWDIO
#define PFS_P109PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + ( 9 * 4))) // D11 / MOSI
#define PFS_P110PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (10 * 4))) // D12 / MISO
#define PFS_P111PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (11 * 4))) // D13 / SCLK
#define PFS_P112PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (12 * 4))) // D10 / CS
#define PFS_P113PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (13 * 4))) // N/C
#define PFS_P114PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (14 * 4))) // N/A
#define PFS_P115PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0843 + (15 * 4))) // N/A
#define PFS_P200PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883))            // NMI input
#define PFS_P201PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (01 * 4))) // MD
#define PFS_P202PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (02 * 4))) // N/A
#define PFS_P203PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (03 * 4))) // N/A
#define PFS_P204PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (04 * 4))) // LOVE (Heart Pad on underside of board)
#define PFS_P205PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (05 * 4))) // N/C
#define PFS_P206PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x0883 + (06 * 4))) // N/C
#define PFS_P212PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08B3))            // EXTAL
#define PFS_P213PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08B3 + (01 * 4))) // XTAL
#define PFS_P214PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08B3 + (02 * 4))) // N/C XCOUT (P214 IN)
#define PFS_P215PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08B3 + (03 * 4))) // N/C XCIN  (P215 IN)
#define PFS_P300PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3))            // SWCLK (P300)
#define PFS_P301PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (01 * 4))) // D0 / RxD (P301)
#define PFS_P302PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (02 * 4))) // D1 / TxD (P302)
#define PFS_P303PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (03 * 4))) // D9
#define PFS_P304PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (04 * 4))) // D8
#define PFS_P305PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (05 * 4))) // N/C
#define PFS_P306PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (06 * 4))) // N/C
#define PFS_P307PFS_BY ((volatile unsigned char  *)(PORTBASE + 0x08C3 + (07 * 4))) // N/C
// ==== General PWM Timer (GPT) ====
#define GPTBASE 0x40070000 /* PWM Base */
#define GTWP 0x8000  // General PWM Timer Write-Protection Register
#define GPT320_GTWP ((volatile unsigned int *)(GPTBASE + GTWP))
#define GPT321_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0100))
#define GPT162_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0200))
#define GPT163_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0300))
#define GPT164_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0400))
#define GPT165_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0500))
#define GPT166_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0600))
#define GPT167_GTWP ((volatile unsigned int *)(GPTBASE + GTWP + 0x0700))
#define GTSTR 0x8004  // General PWM Timer Software Start Register
#define GPT320_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR))
#define GPT321_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0100))
#define GPT162_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0200))
#define GPT163_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0300))
#define GPT164_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0400))
#define GPT165_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0500))
#define GPT166_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0600))
#define GPT167_GTSTR ((volatile unsigned int *)(GPTBASE + GTSTR + 0x0700))
#define GTSTP 0x8008  // General PWM Timer Software Stop Register
#define GPT320_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP))
#define GPT321_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0100))
#define GPT162_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0200))
#define GPT163_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0300))
#define GPT164_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0400))
#define GPT165_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0500))
#define GPT166_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0600))
#define GPT167_GTSTP ((volatile unsigned int *)(GPTBASE + GTSTP + 0x0700))
#define GTCLR 0x800C  // General PWM Timer Software Clear Register
#define GPT320_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR))
#define GPT321_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0100))
#define GPT162_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0200))
#define GPT163_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0300))
#define GPT164_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0400))
#define GPT165_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0500))
#define GPT166_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0600))
#define GPT167_GTCLR ((volatile unsigned int *)(GPTBASE + GTCLR + 0x0700))
#define GTSSR 0x8010  // General PWM Timer Start Source Select Register
#define GPT320_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR))
#define GPT321_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0100))
#define GPT162_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0200))
#define GPT163_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0300))
#define GPT164_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0400))
#define GPT165_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0500))
#define GPT166_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0600))
#define GPT167_GTSSR ((volatile unsigned int *)(GPTBASE + GTSSR + 0x0700))
#define GTPSR 0x8014  // General PWM Timer Stop Source Select Register
#define GPT320_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR))
#define GPT321_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0100))
#define GPT162_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0200))
#define GPT163_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0300))
#define GPT164_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0400))
#define GPT165_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0500))
#define GPT166_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0600))
#define GPT167_GTPSR ((volatile unsigned int *)(GPTBASE + GTPSR + 0x0700))
#define GTCSR 0x8018  // General PWM Timer Clear Source Select Register
#define GPT320_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR))
#define GPT321_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0100))
#define GPT162_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0200))
#define GPT163_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0300))
#define GPT164_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0400))
#define GPT165_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0500))
#define GPT166_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0600))
#define GPT167_GTCSR ((volatile unsigned int *)(GPTBASE + GTCSR + 0x0700))
#define GTUPSR 0x801C  // General PWM Timer Up Count Source Select Register
#define GPT320_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR))
#define GPT321_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0100))
#define GPT162_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0200))
#define GPT163_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0300))
#define GPT164_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0400))
#define GPT165_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0500))
#define GPT166_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0600))
#define GPT167_GTUPSR ((volatile unsigned int *)(GPTBASE + GTUPSR + 0x0700))
#define GTDNSR 0x8020  // General PWM Timer Down Count Source Select Register
#define GPT320_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR))
#define GPT321_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0100))
#define GPT162_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0200))
#define GPT163_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0300))
#define GPT164_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0400))
#define GPT165_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0500))
#define GPT166_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0600))
#define GPT167_GTDNSR ((volatile unsigned int *)(GPTBASE + GTDNSR + 0x0700))
#define GTICASR 0x8024 // General PWM Timer Input Capture Source Select Register A
#define GTICBSR 0x8028 // General PWM Timer Input Capture Source Select Register B
#define GTCR 0x802C // General PWM Timer Control Register
#define GPT320_GTCR ((volatile unsigned int *)(GPTBASE + GTCR))
#define GPT321_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0100))
#define GPT162_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0200))
#define GPT163_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0300))
#define GPT164_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0400))
#define GPT165_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0500))
#define GPT166_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0600))
#define GPT167_GTCR ((volatile unsigned int *)(GPTBASE + GTCR + 0x0700))
#define GTUDDTYC 0x8030 // General PWM Timer Count Direction and Duty Setting Register
#define GPT320_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC))
#define GPT321_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0100))
#define GPT162_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0200))
#define GPT163_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0300))
#define GPT164_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0400))
#define GPT165_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0500))
#define GPT166_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0600))
#define GPT167_GTUDDTYC ((volatile unsigned int *)(GPTBASE + GTUDDTYC + 0x0700))
#define GTIOR 0x8034 // General PWM Timer I/O Control Register
#define GPT320_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR))
#define GPT321_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0100))
#define GPT162_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0200))
#define GPT163_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0300))
#define GPT164_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0400))
#define GPT165_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0500))
#define GPT166_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0600))
#define GPT167_GTIOR ((volatile unsigned int *)(GPTBASE + GTIOR + 0x0700))
#define GTST 0x803C // General PWM Timer Status Register
#define GPT320_GTST ((volatile unsigned int *)(GPTBASE + GTST))
#define GPT321_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0100))
#define GPT162_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0200))
#define GPT163_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0300))
#define GPT164_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0400))
#define GPT165_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0500))
#define GPT166_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0600))
#define GPT167_GTST ((volatile unsigned int *)(GPTBASE + GTST + 0x0700))
#define GTBER 0x8040 // General PWM Timer Buffer Enable Register
#define GPT320_GTBER ((volatile unsigned int *)(GPTBASE + GTBER))
#define GPT321_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0100))
#define GPT162_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0200))
#define GPT163_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0300))
#define GPT164_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0400))
#define GPT165_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0500))
#define GPT166_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0600))
#define GPT167_GTBER ((volatile unsigned int *)(GPTBASE + GTBER + 0x0700))
// Note: GTCNT can only be written to after the counting stops
#define GTCNT 0x8048 // General PWM Timer Counter
#define GPT320_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT))
#define GPT321_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0100))
#define GPT162_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0200))
#define GPT163_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0300))
#define GPT164_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0400))
#define GPT165_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0500))
#define GPT166_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0600))
#define GPT167_GTCNT ((volatile unsigned int *)(GPTBASE + GTCNT + 0x0700))
#define GTCCRA 0x804C // General PWM Timer Compare Capture Register A
#define GPT320_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA))
#define GPT321_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0100))
#define GPT162_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0200))
#define GPT163_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0300))
#define GPT164_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0400))
#define GPT165_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0500))
#define GPT166_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0600))
#define GPT167_GTCCRA ((volatile unsigned int *)(GPTBASE + GTCCRA + 0x0700))
#define GTCCRB 0x8050 // General PWM Timer Compare Capture Register B
#define GPT320_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB))
#define GPT321_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0100))
#define GPT162_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0200))
#define GPT163_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0300))
#define GPT164_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0400))
#define GPT165_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0500))
#define GPT166_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0600))
#define GPT167_GTCCRB ((volatile unsigned int *)(GPTBASE + GTCCRB + 0x0700))
#define GTCCRC 0x8054 // General PWM Timer Compare Capture Register C
#define GPT320_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC))
#define GPT321_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0100))
#define GPT162_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0200))
#define GPT163_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0300))
#define GPT164_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0400))
#define GPT165_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0500))
#define GPT166_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0600))
#define GPT167_GTCCRC ((volatile unsigned int *)(GPTBASE + GTCCRC + 0x0700))
//#define GTCCRD 0x805C // General PWM Timer Compare Capture Register D  - See page 425 22.2.19
#define GTCCRD 0x8058 // General PWM Timer Compare Capture Register D
#define GPT320_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD))
#define GPT321_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0100))
#define GPT162_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0200))
#define GPT163_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0300))
#define GPT164_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0400))
#define GPT165_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0500))
#define GPT166_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0600))
#define GPT167_GTCCRD ((volatile unsigned int *)(GPTBASE + GTCCRD + 0x0700))
//#define GTCCRE 0x8058 // General PWM Timer Compare Capture Register E  - As above...
#define GTCCRE 0x805C // General PWM Timer Compare Capture Register E
#define GPT320_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE))
#define GPT321_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0100))
#define GPT162_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0200))
#define GPT163_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0300))
#define GPT164_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0400))
#define GPT165_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0500))
#define GPT166_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0600))
#define GPT167_GTCCRE ((volatile unsigned int *)(GPTBASE + GTCCRE + 0x0700))
#define GTCCRF 0x8060 // General PWM Timer Compare Capture Register F
#define GPT320_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF))
#define GPT321_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0100))
#define GPT162_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0200))
#define GPT163_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0300))
#define GPT164_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0400))
#define GPT165_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0500))
#define GPT166_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0600))
#define GPT167_GTCCRF ((volatile unsigned int *)(GPTBASE + GTCCRF + 0x0700))
#define GTPR 0x8064 // General PWM Timer Cycle Setting Register
#define GPT320_GTPR ((volatile unsigned int *)(GPTBASE + GTPR))
#define GPT321_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0100))
#define GPT162_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0200))
#define GPT163_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0300))
#define GPT164_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0400))
#define GPT165_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0500))
#define GPT166_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0600))
#define GPT167_GTPR ((volatile unsigned int *)(GPTBASE + GTPR + 0x0700))
#define GTPBR 0x8068 // General PWM Timer Cycle Setting Buffer Register
#define GPT320_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR))
#define GPT321_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0100))
#define GPT162_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0200))
#define GPT163_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0300))
#define GPT164_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0400))
#define GPT165_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0500))
#define GPT166_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0600))
#define GPT167_GTPBR ((volatile unsigned int *)(GPTBASE + GTPBR + 0x0700))
// ====  Asynchronous General Purpose Timer (AGT) =====
#define AGTBASE 0x40084000
#define AGT0_AGT    ((volatile unsigned short *)(AGTBASE))         // AGT Counter Register
#define AGT1_AGT    ((volatile unsigned short *)(AGTBASE + 0x100))
#define AGT0_AGTCMA ((volatile unsigned short *)(AGTBASE + 0x002)) // AGT Compare Match A Register
#define AGT1_AGTCMA ((volatile unsigned short *)(AGTBASE + 0x102))
#define AGT0_AGTCMB ((volatile unsigned short *)(AGTBASE + 0x004)) // AGT Compare Match B Register
#define AGT1_AGTCMB ((volatile unsigned short *)(AGTBASE + 0x104))
// 8 bit registers
#define AGT0_AGTCR    ((volatile unsigned char  *)(AGTBASE + 0x008))  // AGT Control Register
#define AGT1_AGTCR    ((volatile unsigned char  *)(AGTBASE + 0x108))  //
#define AGT0_AGTMR1   ((volatile unsigned char  *)(AGTBASE + 0x009))  // AGT Mode Register 1
#define AGT1_AGTMR1   ((volatile unsigned char  *)(AGTBASE + 0x109))  //
#define AGT0_AGTMR2   ((volatile unsigned char  *)(AGTBASE + 0x00A))  // AGT Mode Register 2
#define AGT1_AGTMR2   ((volatile unsigned char  *)(AGTBASE + 0x10A))  //
#define AGT0_AGTIOC   ((volatile unsigned char  *)(AGTBASE + 0x00C))  // AGT I/O Control Register
#define AGT1_AGTIOC   ((volatile unsigned char  *)(AGTBASE + 0x10C))  //
#define AGT0_AGTISR   ((volatile unsigned char  *)(AGTBASE + 0x00D))  // AGT Event Pin Select Register
#define AGT1_AGTISR   ((volatile unsigned char  *)(AGTBASE + 0x10D))  //
#define AGT0_AGTCMSR  ((volatile unsigned char  *)(AGTBASE + 0x00E))  // AGT Compare Match Function Select Register
#define AGT1_AGTCMSR  ((volatile unsigned char  *)(AGTBASE + 0x10E))  //
#define AGT0_AGTIOSEL ((volatile unsigned char  *)(AGTBASE + 0x00F))  // AGT Pin Select Register
#define AGT1_AGTIOSEL ((volatile unsigned char  *)(AGTBASE + 0x10F))  //
// ==== 28. Serial Communications Interface (SCI) ====
#define SCIBASE 0x40070000
// Receive Data Register
#define SCI0_RDR ((volatile unsigned char  *)(SCIBASE + 0x0005))
#define SCI1_RDR ((volatile unsigned char  *)(SCIBASE + 0x0025))
#define SCI2_RDR ((volatile unsigned char  *)(SCIBASE + 0x0045))
#define SCI9_RDR ((volatile unsigned char  *)(SCIBASE + 0x0125))
// Receive 9-bit Data Register
#define SCI0_RDRHL ((volatile unsigned short *)(SCIBASE + 0x0010))
#define SCI1_RDRHL ((volatile unsigned short *)(SCIBASE + 0x0030))
#define SCI2_RDRHL ((volatile unsigned short *)(SCIBASE + 0x0050))
#define SCI9_RDRHL ((volatile unsigned short *)(SCIBASE + 0x0130))
// Receive FIFO Data Register H
#define SCI0_FRDRH ((volatile unsigned char *)(SCIBASE + 0x0010))
#define SCI1_FRDRH ((volatile unsigned char *)(SCIBASE + 0x0030))
// Receive FIFO Data Register L
#define SCI0_FRDRL ((volatile unsigned char *)(SCIBASE + 0x0011))
#define SCI1_FRDRL ((volatile unsigned char *)(SCIBASE + 0x0031))
// Receive FIFO Data Register HL
#define SCI0_FRDRHL ((volatile unsigned short *)(SCIBASE + 0x0010))
#define SCI1_FRDRHL ((volatile unsigned short *)(SCIBASE + 0x0030))
// Transmit Data Register
#define SCI0_TDR ((volatile unsigned char  *)(SCIBASE + 0x0003))
#define SCI1_TDR ((volatile unsigned char  *)(SCIBASE + 0x0023))
#define SCI2_TDR ((volatile unsigned char  *)(SCIBASE + 0x0043))
#define SCI9_TDR ((volatile unsigned char  *)(SCIBASE + 0x0123))
// Transmit 9-bit Data Register
#define SCI0_TDRHL ((volatile unsigned short *)(SCIBASE + 0x000E))
#define SCI1_TDRHL ((volatile unsigned short *)(SCIBASE + 0x002E))
#define SCI2_TDRHL ((volatile unsigned short *)(SCIBASE + 0x004E))
#define SCI9_TDRHL ((volatile unsigned short *)(SCIBASE + 0x012E))
// Transmit FIFO Data Register H
#define SCI0_FTDRH ((volatile unsigned char *)(SCIBASE + 0x000E))
#define SCI1_FTDRH ((volatile unsigned char *)(SCIBASE + 0x002E))
// Transmit FIFO Data Register L
#define SCI0_FTDRL ((volatile unsigned char *)(SCIBASE + 0x000F))
#define SCI1_FTDRL ((volatile unsigned char *)(SCIBASE + 0x002F))
// Transmit FIFO Data Register HL
#define SCI0_FTDRHL ((volatile unsigned short *)(SCIBASE + 0x000E))
#define SCI1_FRDRHL ((volatile unsigned short *)(SCIBASE + 0x002E))
// Serial Mode Register
#define SCI0_SMR ((volatile unsigned char  *)(SCIBASE + 0x0000))
#define SCI1_SMR ((volatile unsigned char  *)(SCIBASE + 0x0020))
#define SCI2_SMR ((volatile unsigned char  *)(SCIBASE + 0x0040))
#define SCI9_SMR ((volatile unsigned char  *)(SCIBASE + 0x0120))
#define SCI_CKS_1_0  0  // Clock Select
#define SCI_MP       2  // Multi-Processor Mode
#define SCI_STOP     3  // Stop Bit Length
#define SCI_PM       4  // Parity Mode
#define SCI_PE       5  // Parity Enable
#define SCI_CHR      6  // Character Length (default 8 bit), in combination with the CHR1 bit in SCMR
#define SCI_CM       7  // Communication Mode
// Serial Control Register
#define SCI0_SCR ((volatile unsigned char  *)(SCIBASE + 0x0002))
#define SCI1_SCR ((volatile unsigned char  *)(SCIBASE + 0x0022))
#define SCI2_SCR ((volatile unsigned char  *)(SCIBASE + 0x0042))
#define SCI9_SCR ((volatile unsigned char  *)(SCIBASE + 0x0122))
#define SCR_CKE_1_0  0  // Clock Enable
#define SCR_TEIE     2  // Transmit End Interrupt Enable
#define SCR_MPIE     3  // Multi-Processor Interrupt Enable
#define SCR_RE       4  // Receive Enable
#define SCR_TE       5  // Transmit Enable
#define SCR_RIE      6  // Receive Interrupt Enable
#define SCR_TIE      7  // Transmit Interrupt Enable
// Serial Status Register
#define SCI0_SSR ((volatile unsigned char  *)(SCIBASE + 0x0004))
#define SCI1_SSR ((volatile unsigned char  *)(SCIBASE + 0x0024))
#define SCI2_SSR ((volatile unsigned char  *)(SCIBASE + 0x0044))
#define SCI9_SSR ((volatile unsigned char  *)(SCIBASE + 0x0124))
#define SSR_TEND      2  // Transmit End Flag
#define SSR_RDRF      6  // Receive Data Full Flag
#define SSR_TDRE      7  // Transmit Data Empty Flag
// Serial Status Register FIFO
#define SCI0_SSR_FIFO ((volatile unsigned char  *)(SCIBASE + 0x0004))
#define SCI1_SSR_FIFO ((volatile unsigned char  *)(SCIBASE + 0x0024))
#define SSR_DR        0  // Receive Data Ready Flag
#define SSR_RDF       6  // Receive FIFO Data Full Flag
#define SSR_TDFE      7  // Transmit FIFO Data Empty Flag
// Smart Card Mode Register - and other settings
#define SCI0_SCMR ((volatile unsigned char  *)(SCIBASE + 0x0006))
#define SCI1_SCMR ((volatile unsigned char  *)(SCIBASE + 0x0026))
#define SCI2_SCMR ((volatile unsigned char  *)(SCIBASE + 0x0046))
#define SCI9_SCMR ((volatile unsigned char  *)(SCIBASE + 0x0126))
#define SCMR_SMIF     0  // Smart Card Interface Mode Select; 0: Non-smart card interface mode
#define SCMR_SINV     2  // Transmitted/Received Data Invert
#define SCMR_SDIR     3  // Transmitted/Received Data Transfer Direction
#define SCMR_CHR1     4  // Character Length 1
#define SCMR_BCP2     7  // Base Clock Pulse 2
// Bit Rate Register
#define SCI0_BRR ((volatile unsigned char  *)(SCIBASE + 0x0001))
#define SCI1_BRR ((volatile unsigned char  *)(SCIBASE + 0x0021))
#define SCI2_BRR ((volatile unsigned char  *)(SCIBASE + 0x0041))
#define SCI9_BRR ((volatile unsigned char  *)(SCIBASE + 0x0121))
// Modulation Duty Register
#define SCI0_MDDR ((volatile unsigned char  *)(SCIBASE + 0x0012))
#define SCI1_MDDR ((volatile unsigned char  *)(SCIBASE + 0x0032))
#define SCI2_MDDR ((volatile unsigned char  *)(SCIBASE + 0x0052))
#define SCI9_MDDR ((volatile unsigned char  *)(SCIBASE + 0x0132))
// Serial Extended Mode Register
#define SCI0_SEMR ((volatile unsigned char  *)(SCIBASE + 0x0007))
#define SCI1_SEMR ((volatile unsigned char  *)(SCIBASE + 0x0027))
#define SCI2_SEMR ((volatile unsigned char  *)(SCIBASE + 0x0047))
#define SCI9_SEMR ((volatile unsigned char  *)(SCIBASE + 0x0127))
#define SEMR_BRME     2  // Bit Rate Modulation Enable
#define SEMR_ABCSE    3  // Asynchronous Mode Extended Base Clock Select 1
#define SEMR_ABCS     4  // Asynchronous Mode Base Clock Select
#define SEMR_NFEN     5  // Digital Noise Filter Function Enable
#define SEMR_BGDM     6  // Baud Rate Generator Double-Speed Mode Select
#define SEMR_RXDESEL  7  // Asynchronous Start Bit Edge Detection Select
// Noise Filter Setting Register
#define SCI0_SNFR ((volatile unsigned char  *)(SCIBASE + 0x0008))
#define SCI1_SNFR ((volatile unsigned char  *)(SCIBASE + 0x0028))
#define SCI2_SNFR ((volatile unsigned char  *)(SCIBASE + 0x0048))
#define SCI9_SNFR ((volatile unsigned char  *)(SCIBASE + 0x0128))
// Line Status Register
#define SCI0_LSR ((volatile unsigned short *)(SCIBASE + 0x0018))
#define SCI1_LSR ((volatile unsigned short *)(SCIBASE + 0x0038))
// Serial Port Register
#define SCI0_SPTR ((volatile unsigned char  *)(SCIBASE + 0x001C))
#define SCI1_SPTR ((volatile unsigned char  *)(SCIBASE + 0x003C))
#define SCI2_SPTR ((volatile unsigned char  *)(SCIBASE + 0x005C))
#define SCI9_SPTR ((volatile unsigned char  *)(SCIBASE + 0x013C))
// ==== 29. I2C Bus Interface ====
#define IICBASE 0x40050000
// I2C Bus Control Register 1
#define IIC0_ICCR1 ((volatile unsigned char  *)(IICBASE + 0x3000))
#define IIC1_ICCR1 ((volatile unsigned char  *)(IICBASE + 0x3100)) // 0x9F
// I2C Bus Control Register 2
#define IIC0_ICCR2 ((volatile unsigned char  *)(IICBASE + 0x3001))
#define IIC1_ICCR2 ((volatile unsigned char  *)(IICBASE + 0x3101)) // 0x00
// I2C Bus Mode Register 1
#define IIC0_ICMR1 ((volatile unsigned char  *)(IICBASE + 0x3002))
#define IIC1_ICMR1 ((volatile unsigned char  *)(IICBASE + 0x3102)) // 0x28
// I2C Bus Mode Register 2
#define IIC0_ICMR2 ((volatile unsigned char  *)(IICBASE + 0x3003))
#define IIC1_ICMR2 ((volatile unsigned char  *)(IICBASE + 0x3103)) // 0x05
// I2C Bus Mode Register 3
#define IIC0_ICMR3 ((volatile unsigned char  *)(IICBASE + 0x3004))
#define IIC1_ICMR3 ((volatile unsigned char  *)(IICBASE + 0x3104)) // 0x00
// I2C Bus Function Enable Register
#define IIC0_ICFER ((volatile unsigned char  *)(IICBASE + 0x3005))
#define IIC1_ICFER ((volatile unsigned char  *)(IICBASE + 0x3105)) // 0x77
// I2C Bus Status Enable Register
#define IIC0_ICSER ((volatile unsigned char  *)(IICBASE + 0x3006))
#define IIC1_ICSER ((volatile unsigned char  *)(IICBASE + 0x3106)) // 0x00
// I2C Bus Interupt Enable Register
#define IIC0_ICIER ((volatile unsigned char  *)(IICBASE + 0x3007))
#define IIC1_ICIER ((volatile unsigned char  *)(IICBASE + 0x3107)) // 0xB3 Interrupts
// I2C Bus Status Register 1
#define IIC0_ICSR1 ((volatile unsigned char  *)(IICBASE + 0x3008))
#define IIC1_ICSR1 ((volatile unsigned char  *)(IICBASE + 0x3108)) // 0x00
// I2C Bus Status Register 2
#define IIC0_ICSR2 ((volatile unsigned char  *)(IICBASE + 0x3009))
#define IIC1_ICSR2 ((volatile unsigned char  *)(IICBASE + 0x3109)) // 0x00
// I2C Bus Bit Rate Low-Level Register
#define IIC0_ICBRL ((volatile unsigned char  *)(IICBASE + 0x3010))
#define IIC1_ICBRL ((volatile unsigned char  *)(IICBASE + 0x3110)) // 0xFB
// I2C Bus Bit Rate High-Level Register
#define IIC0_ICBRH ((volatile unsigned char  *)(IICBASE + 0x3011))
#define IIC1_ICBRH ((volatile unsigned char  *)(IICBASE + 0x3111)) // 0xFA
// I2C Bus Transmit Data Register
#define IIC0_ICDRT ((volatile unsigned char  *)(IICBASE + 0x3012))
#define IIC1_ICDRT ((volatile unsigned char  *)(IICBASE + 0x3112))
// I2C Bus Receive Data Register
#define IIC0_ICDRR ((volatile unsigned char  *)(IICBASE + 0x3013))
#define IIC1_ICDRR ((volatile unsigned char  *)(IICBASE + 0x3113))
// Slave Address Register L0-2
#define IIC0_SARL0 ((volatile unsigned char  *)(IICBASE + 0x300A))
#define IIC1_SARL0 ((volatile unsigned char  *)(IICBASE + 0x310A))
#define IIC0_SARL1 ((volatile unsigned char  *)(IICBASE + 0x300C))
#define IIC1_SARL1 ((volatile unsigned char  *)(IICBASE + 0x310C))
#define IIC0_SARL2 ((volatile unsigned char  *)(IICBASE + 0x300E))
#define IIC1_SARL2 ((volatile unsigned char  *)(IICBASE + 0x310E))
// Slave Address Register U0-2
#define IIC0_SARU0 ((volatile unsigned char  *)(IICBASE + 0x300B))
#define IIC1_SARU0 ((volatile unsigned char  *)(IICBASE + 0x310B))
#define IIC0_SARU1 ((volatile unsigned char  *)(IICBASE + 0x300D))
#define IIC1_SARU1 ((volatile unsigned char  *)(IICBASE + 0x310D))
#define IIC0_SARU2 ((volatile unsigned char  *)(IICBASE + 0x300F))
#define IIC1_SARU2 ((volatile unsigned char  *)(IICBASE + 0x310F))
// I2C Bus Wakeup Unit Register
#define IIC0_ICWUR  ((volatile unsigned char  *)(IICBASE + 0x3016))
#define IIC0_ICWUR2 ((volatile unsigned char  *)(IICBASE + 0x3017))
// ==== 31. Serial Peripheral Interface (SPI) ====
#define SPIBASE 0x40070000
// SPI Control Register
#define SPI0_SPCR    ((volatile unsigned char  *)(SPIBASE + 0x2000))
#define SPI1_SPCR    ((volatile unsigned char  *)(SPIBASE + 0x2100))
#define SPCR_SPMS   0  // SPI Mode Select
#define SPCR_TXMD   1  // Communications Operating Mode
#define SPCR_MODFEN 2  // Mode Fault Error Detection Enable
#define SPCR_MSTR   3  // SPI Master/Slave Mode Select
#define SPCR_SPEIE  4  // SPI Error Interrupt Enable
#define SPCR_SPTIE  5  // Transmit Buffer Empty Interrupt Enable
#define SPCR_SPE    6  // SPI Function Enable
#define SPCR_SPRIE  7  // SPI Receive Buffer Full Interrupt Enable
// SPI Slave Select Polarity Register
#define SPI0_SSLP    ((volatile unsigned char  *)(SPIBASE + 0x2001))
#define SPI1_SSLP    ((volatile unsigned char  *)(SPIBASE + 0x2101))
#define SSLP_SSL0P  0  // SSL0 Signal Polarity Setting
#define SSLP_SSL0P  1  // SSL1 Signal Polarity Setting
#define SSLP_SSL0P  2  // SSL2 Signal Polarity Setting
#define SSLP_SSL0P  3  // SSL3 Signal Polarity Setting
// SPI Pin Control Register
#define SPI0_SPPCR   ((volatile unsigned char  *)(SPIBASE + 0x2002))
#define SPI1_SPPCR   ((volatile unsigned char  *)(SPIBASE + 0x2102))
#define SPPCR_SPLP   0  // SPI Loopback - data inverted
#define SPPCR_SPLP2  1  // SPI Loopback 2 - data not inverted
#define SPPCR_MOIFV  4  // MOSI Idle Fixed Value
#define SPPCR_MOIFE  5  // MOSI Idle Value Fixing Enable
// SPI Status Register
#define SPI0_SPSR    ((volatile unsigned char  *)(SPIBASE + 0x2003))
#define SPI1_SPSR    ((volatile unsigned char  *)(SPIBASE + 0x2103))
#define SPSR_OVRF   0  // Overrun Error Flag
#define SPSR_IDLNF  1  // SPI Idle Flag
#define SPSR_MODF   2  // Mode Fault Error Flag
#define SPSR_PERF   3  // Parity Error Flag
#define SPSR_UDRF   4  // Underrun Error Flag
#define SPSR_SPTEF  5  // SPI Transmit Buffer Empty Flag
#define SPSR_SPRF   7  // SPI Receive Buffer Full Flag
// SPI Data Register
#define SPI0_SPDR    ((volatile unsigned int   *)(SPIBASE + 0x2004))
#define SPI1_SPDR    ((volatile unsigned int   *)(SPIBASE + 0x2104))
#define SPI0_SPDR_HA ((volatile unsigned short *)(SPIBASE + 0x2004))
#define SPI1_SPDR_HA ((volatile unsigned short *)(SPIBASE + 0x2104))
// SPI Bit Rate Register
#define SPI0_SPBR    ((volatile unsigned char  *)(SPIBASE + 0x200A))
#define SPI1_SPBR    ((volatile unsigned char  *)(SPIBASE + 0x210A))
#define SPBR_0_7     0  // 0x00 = 24MHz; 0x01 = 12MHz; 0x02 = 8.0MHz; 0x03 = 6.0MHz; 0x04 = 4.8MHz; 0x05 = 4.0MHz
#define SPI_BR_24MHz  0x00
#define SPI_BR_12MHz  0x01
#define SPI_BR_8M0Hz  0x02
#define SPI_BR_6M0Hz  0x03
#define SPI_BR_4M8Hz  0x04
#define SPI_BR_4M0Hz  0x05
// SPI Data Control Register
#define SPI0_SPDCR   ((volatile unsigned char  *)(SPIBASE + 0x200B))
#define SPI1_SPDCR   ((volatile unsigned char  *)(SPIBASE + 0x210B))
#define SPDCR_SPRDTD 4  // SPI Receive/Transmit Data Select
#define SPDCR_SPLW   5  // SPI Word Access/Halfword Access Specification
// SPI Clock Delay Register
#define SPI0_SPCKD   ((volatile unsigned char  *)(SPIBASE + 0x200C))
#define SPI1_SPCKD   ((volatile unsigned char  *)(SPIBASE + 0x210C))
// SPI Slave Select Negation Delay Register
#define SPI0_SSLND   ((volatile unsigned char  *)(SPIBASE + 0x200D))
#define SPI1_SSLND   ((volatile unsigned char  *)(SPIBASE + 0x210D))
// SPI Next-Access Delay Register
#define SPI0_SPND    ((volatile unsigned char  *)(SPIBASE + 0x200E))
#define SPI1_SPND    ((volatile unsigned char  *)(SPIBASE + 0x210E))
// SPI Control Register 2
#define SPI0_SPCR2   ((volatile unsigned char  *)(SPIBASE + 0x200F))
#define SPI1_SPCR2   ((volatile unsigned char  *)(SPIBASE + 0x210F))
#define SPCR2_SPPE   0  // Parity Enable
#define SPCR2_SPOE   1  // Parity Mode
#define SPCR2_SPIIE  2  // SPI Idle Interrupt Enable
#define SPCR2_PTE    3  // Parity Self-Testing
#define SPCR2_SCKASE 4  // RSPCK Auto-Stop Function Enable
// SPI Command Register 0
#define SPI0_SPCMD0  ((volatile unsigned short *)(SPIBASE + 0x2010))
#define SPI1_SPCMD0  ((volatile unsigned short *)(SPIBASE + 0x2110))
#define SPCMD0_CPHA      0  // RSPCK Phase Setting
#define SPCMD0_CPOL      1  // RSPCK Polarity Setting
#define SPCMD0_BRDV_0_1  2  // Bit Rate Division Setting
#define SPCMD0_SSLA_0_2  4  // SSL Signal Assertion Setting
#define SPCMD0_SPB_0_3   8  // SPI Data Length Setting
#define SPCMD0_LSBF     12  // SPI LSB First
#define SPCMD0_SPNDEN   13  // SPI Next-Access Delay Enable
#define SPCMD0_SLNDEN   14  // SSL Negation Delay Setting Enable
#define SPCMD0_SCKDEN   15  // RSPCK Delay Setting Enable
#define SPI_BITS_08 0b0100 // 8 bits
#define SPI_BITS_09 0b1000 // 9 bits
#define SPI_BITS_10 0b1001 // 10 bits
#define SPI_BITS_11 0b1010 // 11 bits
#define SPI_BITS_12 0b1011 // 12 bits
#define SPI_BITS_13 0b1100 // 13 bits
#define SPI_BITS_14 0b1101 // 14 bits
#define SPI_BITS_15 0b1110 // 15 bits
#define SPI_BITS_16 0b1111 // 16 bits
#define SPI_BITS_20 0b0000 // 20 bits
#define SPI_BITS_24 0b0001 // 24 bits
#define SPI_BITS_32 0b0010 // 32 bits.
#define SPI_MASTER 1
#define SPI_SLAVE  0
#define SPI_IRQEN  1
#define SPI_POLL   0
#define SPI1       1
#define SPI0       0
// ==== Local Defines ====
#define TRUE 1
#define FALSE 0
  // initialize digital pin LED_BUILTIN as an output.
  setup_timers();
// the loop function runs over and over again forever
  //while(1==1);                      // wait for a second
void setup_timers(void)
  *MSTP_MSTPCRD &= (0xFFFFFFFF - (0x01 << MSTPD6));  // Enable GTP16 timer module
                //   76543210
  *GPT163_GTSTP  = 0x10010010; // Stop Timers 7, 4 and 1  - Doesn't matter which timer is addressed
// Timer 7 - Sawtooth Mode to provide Buffer Delay for Direction Control to H-bridge
  //*GPT167_GTSSR = 0x80000000; // b31 CSTRT Software Source Counter Start Enable
  //*GPT167_GTPSR = 0x80000000; // b31 CSTOP Software Source Counter Stop Enable
  //*GPT167_GTCSR = 0x80000000; // b31 CCLR  Software Source Counter Clear Enable
  *GPT167_GTUDDTYC = 0x1;
  *GPT167_GTCNT  = 0x0000;     // Set Counter value to lineup transition with PWM
  *GPT167_GTCCRA = 11719;     //
  *GPT167_GTCCRB = 11719;     //
  //*GPT167_GTCCRC = 0x0000;     //
  //*GPT167_GTCCRD = 0x0000;     //
  *GPT167_GTPR   = 23438;     // 0X5FA8  24488
  *GPT167_GTPBR  = 23438;     // 0X5FA8  24488
  //*GPT167_GTBER  = 0x00150000; // PR, CCRB, and CCRA set to single buffer operation
  *GPT167_GTCR   = 0x101<<24;        // Set PreScale to /1024 - Set Sawtooth mode
  *GPT167_GTIOR  = 0x00000000;   // Clear I/O Control Register
  *GPT167_GTIOR |=  0b00011       ; // GTIOA[4:0] = 01001b - Initial output is low; Low Output at GTCCRA compare match; HIGH at end
  *GPT167_GTIOR |= (0b00011 << 16); // GTIOB[4:0] = 01001b - Initial output is low; Low Output at GTCCRB compare match; HIGH at end
  *GPT167_GTIOR |= 0x01000100; // Set OBE and OAE bits
  *PFS_P304PFS   = (0b00011 << 24);  // Select PSEL[4:0] for GTIOC7A - See Table 19.10
  *PFS_P304PFS  |= (0x1 << 16);      // Port Mode Control - Used as an I/O port for peripheral function
  *PFS_P303PFS   = (0b00011 << 24);  // Select PSEL[4:0] for GTIOC7B - See Table 19.10
  *PFS_P303PFS  |= (0x1 << 16);      // Port Mode Control - Used as an I/O port for peripheral function
// All timers
                //   76543210
//  *GPT164_GTSTR  = 0x10011000;  // Start Timers 7, 3 and 4  - Doesn't matter which timer is addressed
  *GPT164_GTSTR  = 0x10010010;  // Start Timers 7, 3 and 4  - Doesn't matter which timer is addressed
  *GPT167_GTCR   |= 0x1;        // Start Timer 7 with a PreScale of zero
  *GPT164_GTCLR  = 0x10010010;  // Clear Timers 7, 1 and 4  - Doesn't matter which timer is addressed
Sorry, I may not get time to look at this for a few more days... will do however as soon as I can.
Thanks.
Hi Susan
Thank you very much. Much appreciated.
M
With some tweaks - 1Hz with PWM on Pin 8 and inverted on Pin 9
The GPT timers can best be described as "fiddly"!
// No changes to "header" #defines as above in original code listing
  setup_timers();
  delay(1);                      // wait for a milli-second
  *GPT167_GTCR  |= 0x00000000;      // Make sure Timer 7 is stopped
  *GPT167_GTUDDTYC = 0x1;         // Counter couts up
//  *GPT167_GTCNT  = 0x0000;        // Set Counter value to lineup transition with PWM
  *GPT167_GTCCRA = 11719 << 1;         //
  *GPT167_GTCCRB = 11719 << 1;         //
  //*GPT167_GTCCRC = 0x0000;        // No buffering, so C,D and E,F not used
  *GPT167_GTPR   = 23438 << 1;      // Counter was on toggle on match, now on set/clear so need doubled value
//  *GPT167_GTPBR  = 23438;           //
  *GPT167_GTIOR |=  0b01001       ; // GTIOA[4:0] = 01001b - Initial output is LOW; LOW Output at GTCCRA compare match; HIGH at end
  *GPT167_GTIOR |= (0b00110 << 16); // GTIOB[4:0] = 00110b - Initial output is HIGH; High Output at GTCCRB compare match; LOW at end
//  *GPT167_GTCR   = 0x101<<24;       // Set PreScale to /1024 - Set Sawtooth mode
  *GPT167_GTCR  |= 0x05000001;      // Start Timer 7 with a PreScale of PCLCK/1024 - using |= to start has issues
Please let me know if this still has problems.
Best,
Susan.
Hi Susan
Thank you very much for your help!!! It is working now :slight_smile: :slight_smile:
Much more complicated than the UNO R3 :wink:
M
