Just got a Uno R4 and trying to use the small JST header. The 3.3v and ground postions are intact to the board but the last 2 pins for SDA and SCL are not connected to any pin of the PCB. Did I just get a bad Uno R4? It's authentic Uno R4 not clone.
How did you determine that?
The JST connector is for the Wire1 I2C bus, SCL and SDA only connect to the processor itself connect to the processor through level translators Q1 and Q2. The A4/SDA A5/SCL Wire bus is completely separate.
Note, the UNO R4 has no JST connector, that is only on the UNO R4 WiFi.
I updated the title, I meant the Uno R4 Wifi.
The full advanced pinout of the R4 WiFi accurately shows the SDA/SCL pins and none are on the SPI or even the ESP32 header...
You can find IIC SDA1/SCL1 (Wire) on A4/A5 or D18/D9, IIC0 SDA/SCL (Wire1) on the QWIIC connector, and SCI (Simple IIC) SDA2/SCL2 (Wire2) on D1/D0.
They all work, just note that because Wire2 is SCI it can only be an I2C bus controller and you need to use TwoWire (or equivalent) to start it...
#include <Wire.h>
int sda_pin = 1;
int scl_pin = 0;
TwoWire Wire2(scl_pin, sda_pin, ADDRESS_MODE_7_BITS, true);
Wire2.begin();
