UNO R4 WiFi + Modulino Thermo / Pixels – No I²C device detected (Wire or Wire1)
Hello everyone,
I'm trying to use the Arduino Plug and Make Kit with an Arduino UNO R4 WiFi , but I cannot get any of the Modulino devices to be detected on I²C.
I started with the Modulino Thermo example from the official documentation:
https://docs.arduino.cc/tutorials/modulino-thermo/how-general/
The sketch uploads correctly, but the readings are always:
Temperature (C) is: 0.00
Temperature (F) is: 32.00
Humidity (rH) is: 0.00
When I modified the sketch to check initialization, I get:
thermo.begin() = FAILED
What I tested
1. Qwiic connection (as intended for Modulino)
UNO R4 WiFi → Qwiic cable → Modulino Thermo
I ran an I²C scanner on Wire1 (since Qwiic uses Wire1 on UNO R4 WiFi).
Result:
No I2C devices found on Wire1
2. Manual wiring using the Modulino solder header
To rule out a bad Qwiic cable/connector, I wired the Thermo module manually:
Modulino GND → UNO GND
Modulino 3.3V → UNO 3.3V
Modulino SDA → UNO SDA
Modulino SCL → UNO SCL
Then I ran a standard Wire I²C scanner .
Result:
3. Tried another Modulino
I also tested the Modulino Pixels module with both connection methods.
Same result:
Summary
  • Board: Arduino UNO R4 WiFi
  • Kit: Arduino Plug and Make Kit
  • Modules tested: Modulino Thermo and Modulino Pixels
  • Tested both:
    • Qwiic connector (Wire1 )
    • Manual wiring via header (Wire )
  • Both I²C scanners detect no devices at all
Question
At this point I'm wondering:
  • Is there something special required to enable the I²C bus on the UNO R4 WiFi when using Modulino?
  • Could this indicate a faulty board or Qwiic interface?
  • Is there any recommended diagnostic step for the Plug and Make Kit hardware?
Any suggestions would be greatly appreciated.
Thanks!
You are using pull up resistors on the I2C lines to 3v3 are you?
What value are these?
