Uno r4 wifi with LCD Display
This is my first post on this forum so please excuse when i'm doing something wrong.
I have a arduino uno r4 wifi and a 2.5" TFT LCD Display shield from elegoo. I tried some things with the display and my arduino leonardo before and everything works fine. But i cant get it to run on my uno r4 wifi. In the serial everything is displayed like the example of drawn rectangles and this stuff, but the display is always white and not displaying anything. Is out there a guide how to do it?
You haven't mentioned which library you're using, nor given a link to the display, so it's hard to say anything specifically.
In general, most if not all of the existing libraries have to be updated to work with the R4's. Some have been updated, some haven't. For my own personal use, I massaged the MCUFRIEND_kbv library and get reasonable performance out of it. You may end up having to do the same with whatever library you are using.
i have the following lcd display: https://www.amazon.de/dp/B01EUVJYME?psc=1&ref=ppx_yo2ov_dt_b_product_details
I saw there it is for the uno r3 but i dont see why it shouldn´t work on the r4.
when i try to compile the MCUFriend diagnose_TFT_support there are many errors: Error compiling for board Arduino UNO R4 WiFi
This is the complete error log:
Arduino: 1.8.18 (Windows 10), Board: "Arduino UNO R4 WiFi"
In file included from C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:38:0:
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1201:2: error: #error MCU unsupported
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void write24(uint16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:87:5: error: 'write8' was not declared in this scope
     write8(r);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:87:5: note: suggested alternative: 'write24'
     write8(r);
     write24
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'void MCUFRIEND_kbv::reset()':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:95:5: error: 'setWriteDir' was not declared in this scope
     setWriteDir();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:95:5: note: suggested alternative: 'setWriteError'
     setWriteDir();
     setWriteError
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:31: error: 'RD_PORT' was not declared in this scope
 #define RD_OUTPUT  PIN_OUTPUT(RD_PORT, RD_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1229:37: note: in expansion of macro 'RD_OUTPUT'
 #define CTL_INIT()   { GPIO_INIT(); RD_OUTPUT; WR_OUTPUT; CD_OUTPUT; CS_OUTPUT; RESET_OUTPUT; }
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:96:5: note: in expansion of macro 'CTL_INIT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:31: note: suggested alternative: 'R_PORT0'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:40: error: 'RD_PIN' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:40: note: suggested alternative: 'R_PFS'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:20: error: 'PIN_OUTPUT' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1208:20: note: suggested alternative: 'CD_OUTPUT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1211:31: error: 'WR_PORT' was not declared in this scope
 #define WR_OUTPUT  PIN_OUTPUT(WR_PORT, WR_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1229:48: note: in expansion of macro 'WR_OUTPUT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1211:31: note: suggested alternative: 'R_PORT0'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1211:40: error: 'WR_PIN' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1211:40: note: suggested alternative: 'R_PFS'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1214:31: error: 'CD_PORT' was not declared in this scope
 #define CD_OUTPUT  PIN_OUTPUT(CD_PORT, CD_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1229:59: note: in expansion of macro 'CD_OUTPUT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1214:31: note: suggested alternative: 'R_PORT0'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1214:40: error: 'CD_PIN' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1214:40: note: suggested alternative: 'M_PI'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:31: error: 'CS_PORT' was not declared in this scope
 #define CS_OUTPUT  PIN_OUTPUT(CS_PORT, CS_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1229:70: note: in expansion of macro 'CS_OUTPUT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:31: note: suggested alternative: 'R_PORT0'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:40: error: 'CS_PIN' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1217:40: note: suggested alternative: 'SPI'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1220:34: error: 'RESET_PORT' was not declared in this scope
 #define RESET_OUTPUT  PIN_OUTPUT(RESET_PORT, RESET_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1229:81: note: in expansion of macro 'RESET_OUTPUT'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1220:34: note: suggested alternative: 'RESET_IDLE'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1220:46: error: 'RESET_PIN' was not declared in this scope
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1220:46: note: suggested alternative: 'RESET_IDLE'
     CTL_INIT();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:29: error: 'CS_PORT' was not declared in this scope
 #define CS_IDLE    PIN_HIGH(CS_PORT, CS_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:97:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:29: note: suggested alternative: 'R_PORT0'
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:38: error: 'CS_PIN' was not declared in this scope
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:38: note: suggested alternative: 'SPI'
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:20: error: 'PIN_HIGH' was not declared in this scope
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1216:20: note: suggested alternative: 'PIN_MISO'
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:29: error: 'RD_PORT' was not declared in this scope
 #define RD_IDLE    PIN_HIGH(RD_PORT, RD_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:98:5: note: in expansion of macro 'RD_IDLE'
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:29: note: suggested alternative: 'R_PORT0'
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:38: error: 'RD_PIN' was not declared in this scope
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:38: note: suggested alternative: 'R_PFS'
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1210:29: error: 'WR_PORT' was not declared in this scope
 #define WR_IDLE    PIN_HIGH(WR_PORT, WR_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:99:5: note: in expansion of macro 'WR_IDLE'
     WR_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1210:29: note: suggested alternative: 'R_PORT0'
     WR_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1210:38: error: 'WR_PIN' was not declared in this scope
     WR_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1210:38: note: suggested alternative: 'R_PFS'
     WR_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1219:32: error: 'RESET_PORT' was not declared in this scope
 #define RESET_IDLE    PIN_HIGH(RESET_PORT, RESET_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:100:5: note: in expansion of macro 'RESET_IDLE'
     RESET_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1219:32: note: suggested alternative: 'RESET_IDLE'
     RESET_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1219:44: error: 'RESET_PIN' was not declared in this scope
     RESET_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1219:44: note: suggested alternative: 'RESET_IDLE'
     RESET_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1218:23: error: 'PIN_LOW' was not declared in this scope
 #define RESET_ACTIVE  PIN_LOW(RESET_PORT, RESET_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:102:5: note: in expansion of macro 'RESET_ACTIVE'
     RESET_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1218:23: note: suggested alternative: 'PIN_LED'
     RESET_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void writecmddata(uint16_t, uint16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:28: error: 'CS_PORT' was not declared in this scope
 #define CS_ACTIVE  PIN_LOW(CS_PORT, CS_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:111:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:28: note: suggested alternative: 'R_PORT0'
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:37: error: 'CS_PIN' was not declared in this scope
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:37: note: suggested alternative: 'SPI'
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:20: error: 'PIN_LOW' was not declared in this scope
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1215:20: note: suggested alternative: 'PIN_LED'
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:28: error: 'CD_PORT' was not declared in this scope
 #define CD_COMMAND PIN_LOW(CD_PORT, CD_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:24: note: in expansion of macro 'CD_COMMAND'
 #define WriteCmd(x)  { CD_COMMAND; write16(x); CD_DATA; }
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:112:5: note: in expansion of macro 'WriteCmd'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:28: note: suggested alternative: 'R_PORT0'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:37: error: 'CD_PIN' was not declared in this scope
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1212:37: note: suggested alternative: 'M_PI'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: error: 'write16' was not declared in this scope
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: note: suggested alternative: 'write24'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1213:20: error: 'PIN_HIGH' was not declared in this scope
 #define CD_DATA    PIN_HIGH(CD_PORT, CD_PIN)
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:48: note: in expansion of macro 'CD_DATA'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1213:20: note: suggested alternative: 'PIN_MISO'
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1231:24: error: 'write16' was not declared in this scope
 #define WriteData(x) { write16(x); }
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:113:5: note: in expansion of macro 'WriteData'
     WriteData(dat);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1231:24: note: suggested alternative: 'write24'
     WriteData(dat);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:114:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void WriteCmdParamN(uint16_t, int8_t, uint8_t*)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:121:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:122:5: note: in expansion of macro 'WriteCmd'
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
     WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: error: 'write8' was not declared in this scope
         write8(u8);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:125:9: note: suggested alternative: 'write24'
         write8(u8);
         write24
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:128:13: note: in expansion of macro 'WriteCmd'
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
             WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:131:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'uint16_t read16bits()':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: error: 'READ_8' was not declared in this scope
     READ_8(ret);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:154:5: note: suggested alternative: 'READ_BGR'
     READ_8(ret);
     READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'uint16_t MCUFRIEND_kbv::readReg(uint16_t, int8_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:168:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:169:5: note: in expansion of macro 'WriteCmd'
     WriteCmd(reg);
     WriteCmd(reg);
     WriteCmd(reg);
     WriteCmd(reg);
     WriteCmd(reg);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1230:36: note: suggested alternative: 'write'
     WriteCmd(reg);
     WriteCmd(reg);
     WriteCmd(reg);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: error: 'setReadDir' was not declared in this scope
     setReadDir();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:170:5: note: suggested alternative: 'bitRead'
     setReadDir();
     bitRead
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:174:5: note: in expansion of macro 'RD_IDLE'
     RD_IDLE;
     RD_IDLE;
     RD_IDLE;
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:20: error: 'PIN_HIGH' was not declared in this scope
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\utility/mcufriend_shield.h:1207:20: note: suggested alternative: 'PIN_MISO'
     RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: error: 'setWriteDir' was not declared in this scope
     setWriteDir();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:176:5: note: suggested alternative: 'setWriteError'
     setWriteDir();
     setWriteError
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'int16_t MCUFRIEND_kbv::readGRAM(int16_t, int16_t, uint16_t*, int16_t, int16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:310:9: note: in expansion of macro 'CS_ACTIVE'
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
         CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:311:9: note: in expansion of macro 'WriteCmd'
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
         WriteCmd(_MR);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: error: 'setReadDir' was not declared in this scope
         setReadDir();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:312:9: note: suggested alternative: 'bitRead'
         setReadDir();
         bitRead
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: error: 'READ_8' was not declared in this scope
             READ_8(r);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:316:13: note: suggested alternative: 'READ_BGR'
             READ_8(r);
             READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: error: 'READ_16' was not declared in this scope
             READ_16(dummy);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:318:13: note: suggested alternative: 'READ_BGR'
             READ_16(dummy);
             READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: error: 'READ_8' was not declared in this scope
   if (_lcd_ID == 0x1511) READ_8(r);   //extra dummy for R61511
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:320:26: note: suggested alternative: 'READ_BGR'
                          READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: error: 'READ_8' was not declared in this scope
                 READ_8(r);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:323:17: note: suggested alternative: 'READ_BGR'
                 READ_8(r);
                 READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: error: 'READ_16' was not declared in this scope
                 READ_16(ret);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:331:17: note: suggested alternative: 'READ_BGR'
                 READ_16(ret);
                 READ_BGR
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:350:9: note: in expansion of macro 'RD_IDLE'
         RD_IDLE;
         RD_IDLE;
         RD_IDLE;
         RD_IDLE;
         RD_IDLE;
         RD_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: error: 'setWriteDir' was not declared in this scope
         setWriteDir();
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:352:9: note: suggested alternative: 'setWriteError'
         setWriteDir();
         setWriteError
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::drawPixel(int16_t, int16_t, uint16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:541:19: note: in expansion of macro 'CS_ACTIVE'
     if (is9797) { CS_ACTIVE; WriteCmd(_MW); write24(color); CS_IDLE;} else
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:541:30: note: in expansion of macro 'WriteCmd'
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:541:61: note: in expansion of macro 'CS_IDLE'
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In member function 'virtual void MCUFRIEND_kbv::fillRect(int16_t, int16_t, int16_t, int16_t, uint16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:615:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:616:5: note: in expansion of macro 'WriteCmd'
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
     WriteCmd(_MW);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: error: 'write8' was not declared in this scope
                  write8(r);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:659:18: note: suggested alternative: 'write'
                  write8(r);
                  write
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: error: 'write8' was not declared in this scope
             write8(hi);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:666:13: note: suggested alternative: 'write'
             write8(hi);
             write
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:671:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void pushColors_any(uint16_t, uint8_t*, int16_t, bool, uint8_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:682:5: note: in expansion of macro 'CS_ACTIVE'
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
     CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:684:9: note: in expansion of macro 'WriteCmd'
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
         WriteCmd(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: error: 'write16' was not declared in this scope
             write16(color);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:691:13: note: suggested alternative: 'write24'
             write16(color);
             write24
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: error: 'write16' was not declared in this scope
         write16(color);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:708:9: note: suggested alternative: 'write24'
         write16(color);
         write24
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:710:5: note: in expansion of macro 'CS_IDLE'
     CS_IDLE;
     CS_IDLE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp: In function 'void init_table(const void*, int16_t)':
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:875:13: note: in expansion of macro 'CS_ACTIVE'
             CS_ACTIVE;
             CS_ACTIVE;
             CS_ACTIVE;
             CS_ACTIVE;
             CS_ACTIVE;
             CS_ACTIVE;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:876:13: note: in expansion of macro 'CD_COMMAND'
             CD_COMMAND;
             CD_COMMAND;
             CD_COMMAND;
             CD_COMMAND;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: error: 'write8' was not declared in this scope
             write8(cmd);
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:877:13: note: suggested alternative: 'write24'
             write8(cmd);
             write24
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:880:17: note: in expansion of macro 'CD_DATA'
                 CD_DATA;
                 CD_DATA;
C:\Users\TEX\Documents\Arduino\libraries\MCUFRIEND_kbv\MCUFRIEND_kbv.cpp:888:13: note: in expansion of macro 'CS_IDLE'
             CS_IDLE;
             CS_IDLE;
exit status 1
Fehler beim Kompilieren für das Board Arduino UNO R4 WiFi.
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
I did say "most if not all of the existing libraries have to be updated to work with the R4's". That included MCUFRIEND_kbv. In order to use it myself, I had to go in and figure out what needed to be done to it in order to make it work (and work at a reasonable speed) with the R4's. The author of the library has not yet done so themselves (or expressed any apparent interest in other's attempts to fill the gap either).
The R4s use a completely different processor than the R3s. The low level port manipulation that works on the R3 simply doesn't on the R4 because of that. And because pinMode() and digitalWrite() calls are just so slow, over the years people have gone as close to the hardware as they can in order to achieve decent performance. Bring in new hardware, and you've got to bring in new software to support it. And for the R4, that is still a work in progress at best.
You said you were using a 2.5" LCD, but you linked to a 2.8" LCD. One that looks suspiciously like mine. If the back of yours looks like this
there's a chance that the changes I made to the MCUFRIEND_kbv library might work for you as well. But just a chance; there is no guarantee that the display driver in your display matches what's in mine and some just don't work for other reasons.
I'm happy to share the file I modified so that you can replace it in your library and try it out, but please understand that I am not offering to debug it or support it in any fashion whatsoever. If it works for you, great, enjoy. If it doesn't, oh well it didn't cost you anything to try.
If that sounds like something you'd like to persue, I'm happy to post the modified file here. If not, I wish you well in getting your display working. It's a very satisfying feeling when they finally do work.
Yeah sorry that i didn't explain everything right. I would really appreciate if you share your modified files. And ofcourse i will debug and try it by myself from this point. I am pretty new in the arduino scene and i appreciate that you helped me this far already!
In the MCUFRIEND_kbv library, replace the file utility/mcufriend_shield.h with what's below. If your display has an ILI9341 controller, it ought to Just Work. No guarantees on any others. Good luck!
//#define USE_SPECIAL             //check for custom drivers
#define WR_ACTIVE2  {WR_ACTIVE; WR_ACTIVE;}
#define WR_ACTIVE4  {WR_ACTIVE2; WR_ACTIVE2;}
#define WR_ACTIVE8  {WR_ACTIVE4; WR_ACTIVE4;}
#define RD_ACTIVE2  {RD_ACTIVE; RD_ACTIVE;}
#define RD_ACTIVE4  {RD_ACTIVE2; RD_ACTIVE2;}
#define RD_ACTIVE8  {RD_ACTIVE4; RD_ACTIVE4;}
#define RD_ACTIVE16 {RD_ACTIVE8; RD_ACTIVE8;}
#define WR_IDLE2  {WR_IDLE; WR_IDLE;}
#define WR_IDLE4  {WR_IDLE2; WR_IDLE2;}
#define RD_IDLE2  {RD_IDLE; RD_IDLE;}
#define RD_IDLE4  {RD_IDLE2; RD_IDLE2;}
#if defined(USE_SPECIAL)
#include "mcufriend_special.h"
#if !defined(USE_SPECIAL_FAIL)
#warning WE ARE USING A SPECIAL CUSTOM DRIVER
#endif
#endif
#if !defined(USE_SPECIAL) || defined (USE_SPECIAL_FAIL)
#if 0
//################################### UNO ##############################
#elif defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328PB__)       //regular UNO shield on UNO
//LCD pins  |D7 |D6 |D5 |D4 |D3 |D2 |D1 |D0 | |RD |WR |RS |CS |RST|
//AVR   pin |PD7|PD6|PD5|PD4|PD3|PD2|PB1|PB0| |PC0|PC1|PC2|PC3|PC4|
//UNO pins  |7  |6  |5  |4  |3  |2  |9  |8  | |A0 |A1 |A2 |A3 |A4 |
#define RD_PORT PORTC
#define RD_PIN  0
#define WR_PORT PORTC
#define WR_PIN  1
#define CD_PORT PORTC
#define CD_PIN  2
#define CS_PORT PORTC
#define CS_PIN  3
#define RESET_PORT PORTC
#define RESET_PIN  4
#define BMASK         0x03              //more intuitive style for mixed Ports
#define DMASK         0xFC              //does exactly the same as previous
#define write_8(x)    { PORTB = (PORTB & ~BMASK) | ((x) & BMASK); PORTD = (PORTD & ~DMASK) | ((x) & DMASK); }
#define read_8()      ( (PINB & BMASK) | (PIND & DMASK) )
#define setWriteDir() { DDRB |=  BMASK; DDRD |=  DMASK; }
#define setReadDir()  { DDRB &= ~BMASK; DDRD &= ~DMASK; }
#define write8(x)     { write_8(x); WR_STROBE; }
#define write16(x)    { uint8_t h = (x)>>8, l = x; write8(h); write8(l); }
#define READ_8(dst)   { RD_STROBE; dst = read_8(); RD_IDLE; }
#define READ_16(dst)  { uint8_t hi; READ_8(hi); READ_8(dst); dst |= (hi << 8); }
#define PIN_LOW(p, b)        (p) &= ~(1<<(b))
#define PIN_HIGH(p, b)       (p) |= (1<<(b))
#define PIN_OUTPUT(p, b)     *(&p-1) |= (1<<(b))
//################################### UNO R4  ##############################
#elif defined(ARDUINO_UNOR4_MINIMA) || defined(ARDUINO_UNOR4_WIFI)   // regular UNO shield on UNO R4
#define RD_PORT 0
#define RD_PIN  A0
#define WR_PORT 0
#define WR_PIN  A1
#define CD_PORT 0
#define CD_PIN  A2
#define CS_PORT 0
#define CS_PIN  A3
#define RESET_PORT 0
#define RESET_PIN  A4
#define RD_ACTIVE  { R_PORT0->PORR = bit(14); }
#define RD_IDLE    { R_PORT0->POSR = bit(14); }
#define WR_ACTIVE  { R_PORT0->PORR = bit(0); }
#define WR_IDLE    { R_PORT0->POSR = bit(0); }
#define CD_COMMAND { R_PORT0->PORR = bit(1); }
#define CD_DATA    { R_PORT0->POSR = bit(1); }
#define CS_ACTIVE  { R_PORT0->PORR = bit(2); }
#define CS_IDLE    { R_PORT0->POSR = bit(2); }
#if defined(ARDUINO_UNOR4_MINIMA)
static uint8_t toLowPins[64] = {
   0x00,0x20,0x10,0x30,0x08,0x28,0x18,0x38,0x04,0x24,0x14,0x34,0x0c,0x2c,0x1c,0x3c,
   0x40,0x60,0x50,0x70,0x48,0x68,0x58,0x78,0x44,0x64,0x54,0x74,0x4c,0x6c,0x5c,0x7c,
   0x80,0xa0,0x90,0xb0,0x88,0xa8,0x98,0xb8,0x84,0xa4,0x94,0xb4,0x8c,0xac,0x9c,0xbc,
   0xc0,0xe0,0xd0,0xf0,0xc8,0xe8,0xd8,0xf8,0xc4,0xe4,0xd4,0xf4,0xcc,0xec,0xdc,0xfc
static uint8_t toHighPins[4] = {
   0x00, 0x10, 0x08, 0x18
static uint8_t fromHighPins[] = {
   0x00, 0x02, 0x01, 0x03
#define write_8(x)    { R_PORT3->PODR = (R_PORT3->PODR & 0xFFE7) | toHighPins[x & 0x03]; \
                        R_PORT1->PODR = (R_PORT1->PODR & 0xFF03) | toLowPins[x >> 2]; \
#define read_8()      ( fromHighPins[(R_PORT3->PIDR >> 3) & 0x03] | toLowPins[(R_PORT1->PIDR & 0x00FC) >> 2] )
#define setWriteDir() { R_PORT1->PDR |=  0b11111100; R_PORT3->PDR |=  0b00011000; }
#define setReadDir()  { R_PORT1->PDR &= ~0b11111100; R_PORT3->PDR &= ~0b00011000; }
#else
                        R_PORT1->PODR = (R_PORT1->PODR & 0xE70F) | ((x & 0x3C) << 2) | ((x & 0xc0) << 5); \
#define read_8()      ( fromHighPins[(R_PORT3->PIDR >> 3) & 0x03] | ((R_PORT1->PIDR & 0x1800) >> 5) | ((R_PORT1->PIDR & 0xF0) >> 2) )
#define setWriteDir() { R_PORT1->PDR |=  0b0001100011110000; R_PORT3->PDR |=  0b00011000; }
#define setReadDir()  { R_PORT1->PDR &= ~0b0001100011110000; R_PORT3->PDR &= ~0b00011000; }
#endif
#define PIN_LOW(p, b) digitalWrite(b, 0)
#define PIN_HIGH(p, b) digitalWrite(b, 1)
#define PIN_OUTPUT(p, b) pinMode(b, OUTPUT)
//################################### MEGA2560 ##############################
#elif defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)       //regular UNO shield on MEGA2560
//AVR   pin |PH4|PH3|PE3|PG5|PE5|PE4|PH6|PH5| |PF0|PF1|PF2|PF3|PF4|
#define RD_PORT PORTF
#define RD_PIN  0
#define WR_PORT PORTF
#define WR_PIN  1
#define CD_PORT PORTF
#define CD_PIN  2
#define CS_PORT PORTF
#define CS_PIN  3
#define RESET_PORT PORTF
#define RESET_PIN  4
#define EMASK         0x38
#define GMASK         0x20
#define HMASK         0x78
#define write_8(x)   {  PORTH &= ~HMASK; PORTG &= ~GMASK; PORTE &= ~EMASK; \
                        PORTH |= (((x) & (3<<0)) << 5); \
                        PORTE |= (((x) & (3<<2)) << 2); \
                        PORTG |= (((x) & (1<<4)) << 1); \
                        PORTE |= (((x) & (1<<5)) >> 2); \
                        PORTH |= (((x) & (3<<6)) >> 3); \
#define read_8()      ( ((PINH & (3<<5)) >> 5)\
                      | ((PINE & (3<<4)) >> 2)\
                      | ((PING & (1<<5)) >> 1)\
                      | ((PINE & (1<<3)) << 2)\
                      | ((PINH & (3<<3)) << 3)\
#define setWriteDir() { DDRH |=  HMASK; DDRG |=  GMASK; DDRE |=  EMASK;  }
#define setReadDir()  { DDRH &= ~HMASK; DDRG &= ~GMASK; DDRE &= ~EMASK;  }
//################################### MEGA4809 NANO_EVERY  4808 ##############################
#elif defined(__AVR_ATmega4808__)   // Thinary EVERY-4808 with Nano-Shield_Adapter
#warning EVERY-4808 with Nano-Shield_Adapter
#define RD_PORT VPORTD  //
#define RD_PIN  0
#define WR_PORT VPORTD
#define WR_PIN  1
#define CD_PORT VPORTD
#define CD_PIN  2
#define CS_PORT VPORTD
#define CS_PIN  3
#define RESET_PORT VPORTF
#define RESET_PIN  2
#define AMASK         0xFF
#define write_8(x)    { VPORTA.OUT = ((x) << 6) | ((x) >> 2); }
#define read_8()      ( (VPORTA.IN >> 6) | (VPORTA.IN << 2) )
#define setWriteDir() { VPORTA_DIR |=  AMASK; }
#define setReadDir()  { VPORTA_DIR &= ~AMASK; }
//#define WRITE_DELAY   { WR_ACTIVE; WR_ACTIVE; }   //6.47s no_inline
#define WRITE_DELAY   { WR_ACTIVE2; WR_ACTIVE; }   //-Os=5.43s @20MHz always_inline. (-O1=5.41s, -O3=5.25s)
#define READ_DELAY    { RD_ACTIVE4; }              //ID=0x7789
#define write8(x)     { write_8(x); WRITE_DELAY; WR_STROBE; }
#define READ_8(dst)   { RD_STROBE; READ_DELAY; dst = read_8(); RD_IDLE; }
#define PIN_LOW(p, b)        (p).OUT &= ~(1<<(b))
#define PIN_HIGH(p, b)       (p).OUT |= (1<<(b))
#define PIN_OUTPUT(p, b)     (p).DIR |= (1<<(b))
//########################## MEGA4809 NANO_EVERY or UNO_WIFI_REV2 ##############################
#elif defined(__AVR_ATmega4809__) && (defined(ARDUINO_AVR_NANO_EVERY) || defined(ARDUINO_AVR_UNO_WIFI_REV2))
#if defined(ARDUINO_AVR_NANO_EVERY)
#warning EVERY-4809 with Nano-Shield_Adapter using VPORT.OUT and BLD/BST
//AVR   pin |PA1|PF4|PB2|PC6|PF5|PA0|PB0|PE3| |PD3|PD2|PD1|PD0|PF2|
#define RD_PIN  3
#define WR_PIN  2
#define CD_PIN  1
#define CS_PIN  0
#define RESET_PIN  2
#elif defined(ARDUINO_AVR_UNO_WIFI_REV2)
#warning UNO_WIFI_REV2 using VPORT.OUT and BLD/BST
#define RD_PIN  0
#define WR_PIN  1
#define CD_PIN  2
#define CS_PIN  3
#define RESET_PORT VPORTD
#define RESET_PIN  4
#endif
#define AMASK         (3<<0)
#define BMASK         (5<<0)
#define CMASK         (1<<6)
#define EMASK         (1<<3)
#define FMASK         (3<<4)
static __attribute((always_inline))
void write_8(uint8_t val)
    asm volatile("in __tmp_reg__,0x01" "\n\t"    //VPORTA.OUT
                 "BST %0,2" "\n\t" "BLD __tmp_reg__,0" "\n\t"
                 "BST %0,7" "\n\t" "BLD __tmp_reg__,1" "\n\t"
                 "out 0x01,__tmp_reg__" : : "a" (val));
    asm volatile("in __tmp_reg__,0x05" "\n\t"    //VPORTB.OUT
                 "BST %0,1" "\n\t" "BLD __tmp_reg__,0" "\n\t"
                 "BST %0,5" "\n\t" "BLD __tmp_reg__,2" "\n\t"
                 "out 0x05,__tmp_reg__" : : "a" (val));
    asm volatile("in __tmp_reg__,0x09" "\n\t"    //VPORTC.OUT
                 "BST %0,4" "\n\t" "BLD __tmp_reg__,6" "\n\t"
                 "out 0x09,__tmp_reg__" : : "a" (val));
    asm volatile("in __tmp_reg__,0x11" "\n\t"    //VPORTE.OUT
                 "BST %0,0" "\n\t" "BLD __tmp_reg__,3" "\n\t"
                 "out 0x11,__tmp_reg__" : : "a" (val));
    asm volatile("in __tmp_reg__,0x15" "\n\t"    //VPORTF.OUT
                 "BST %0,3" "\n\t" "BLD __tmp_reg__,5" "\n\t"
                 "BST %0,6" "\n\t" "BLD __tmp_reg__,4" "\n\t"
                 "out 0x15,__tmp_reg__" : : "a" (val));
#define read_8()      ( 0 \
                        | ((VPORTA_IN & (1<<0)) << 2)\
                        | ((VPORTA_IN & (1<<1)) << 6)\
                        | ((VPORTB_IN & (1<<0)) << 1)\
                        | ((VPORTB_IN & (1<<2)) << 3)\
                        | ((VPORTC_IN & CMASK) >> 2)\
                        | ((VPORTE_IN & EMASK) >> 3)\
                        | ((VPORTF_IN & (1<<5)) >> 2)\
                        | ((VPORTF_IN & (1<<4)) << 2)\
#define setWriteDir() { VPORTA_DIR |=  AMASK; VPORTB_DIR |=  BMASK; VPORTC_DIR |=  CMASK; VPORTE_DIR |=  EMASK; VPORTF_DIR |=  FMASK; }
#define setReadDir()  { VPORTA_DIR &= ~AMASK; VPORTB_DIR &= ~BMASK; VPORTC_DIR &= ~CMASK; VPORTE_DIR &= ~EMASK; VPORTF_DIR &= ~FMASK; }
//################################### TEENSY++2.0 ##############################
#elif defined(__AVR_AT90USB1286__)       //regular UNO shield on TEENSY++ 2.0 thanks tysonlt
//AVR   pin |PD7|PD6|PD5|PD4|PD3|PD2|PE1|PE0| |PF0|PF1|PF2|PF3|PF4|
#define RD_PIN  0
#define WR_PIN  1
#define CD_PIN  2
#define CS_PIN  3
#define RESET_PIN  4
#define EMASK         0x03              //more intuitive style for mixed Ports
#define write_8(x)    { PORTE = (PORTE & ~EMASK) | ((x) & EMASK); PORTD = (PORTD & ~DMASK) | ((x) & DMASK); }
#define read_8()      ( (PINE & EMASK) | (PIND & DMASK) )
#define setWriteDir() { DDRE |=  EMASK; DDRD |=  DMASK; }
#define setReadDir()  { DDRE &= ~EMASK; DDRD &= ~DMASK; }
//################################# ZERO and M0_PRO ############################
#elif defined(__SAMD21G18A__)   //regular UNO shield on ZERO or M0_PRO
#include "sam.h"
 // configure macros for the control pins
#define RD_PORT PORT->Group[0]
#define RD_PIN  2
#define WR_PORT PORT->Group[1]
#define WR_PIN  8
#define CD_PORT PORT->Group[1]
#define CD_PIN  9
#define CS_PORT PORT->Group[0]
#define CS_PIN  4
#define RESET_PORT PORT->Group[0]
#define RESET_PIN  5
 // configure macros for data bus
#define DMASK 0x0030C3C0
 //  #define write_8(x) PORT->Group[0].OUT.reg = (PORT->Group[0].OUT.reg & ~DMASK)|(((x) & 0x0F) << 6)|(((x) & 0x30) << 10)|(((x) & 0xC0)<<14)
#if defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_ZERO)   // American ZERO
//LCD pins   |D7  |D6  |D5  |D4  |D3  |D2  |D1  |D0  | |RD |WR |RS  |CS  |RST |
//SAMD21 pin |PA21|PA20|PA15|PA8 |PA9 |PA14|PA7 |PA6 | |PA2|PB8|PB9 |PA4 |PA5 |
#define write_8(x) {\
	PORT->Group[0].OUTCLR.reg = DMASK;\
	PORT->Group[0].OUTSET.reg = (((x) & 0x0B) << 6)\
                               |(((x) & (1<<2)) << 12)\
	                           |(((x) & (1<<4)) << 4)\
	                           |(((x) & (1<<5)) << 10)\
	                           |(((x) & 0xC0) << 14);\
#define read_8()   (((PORT->Group[0].IN.reg >> 6) & 0x0B)\
                   |((PORT->Group[0].IN.reg >> 12) & (1<<2))\
                   |((PORT->Group[0].IN.reg >> 4) &  (1<<4))\
                   |((PORT->Group[0].IN.reg >> 10) & (1<<5))\
                   |((PORT->Group[0].IN.reg >> 14) & 0xC0))
#else   //default to an M0_PRO on v1.6.5 or 1.7.6
//SAMD21 pin |PA21|PA20|PA15|PA14|PA9 |PA8 |PA7 |PA6 | |PA2|PB8|PB9 |PA4 |PA5 |
	PORT->Group[0].OUTSET.reg = (((x) & 0x0F) << 6)\
                               |(((x) & 0x30) << 10)\
#define read_8()   (((PORT->Group[0].IN.reg >> 6) & 0x0F)|((PORT->Group[0].IN.reg >> 10) & 0x30)|((PORT->Group[0].IN.reg >> 14) & 0xC0))
#endif
#define setWriteDir() { PORT->Group[0].DIRSET.reg = DMASK; \
	                  PORT->Group[0].WRCONFIG.reg = (DMASK & 0xFFFF) | (0<<22) | (1<<28) | (1<<30); \
	                  PORT->Group[0].WRCONFIG.reg = (DMASK>>16) | (0<<22) | (1<<28) | (1<<30) | (1<<31); \
#define setReadDir()  { PORT->Group[0].DIRCLR.reg = DMASK; \
	                  PORT->Group[0].WRCONFIG.reg = (DMASK & 0xFFFF) | (1<<17) | (1<<28) | (1<<30); \
	                  PORT->Group[0].WRCONFIG.reg = (DMASK>>16) | (1<<17) | (1<<28) | (1<<30) | (1<<31); \
#define write8(x)     { write_8(x); WR_ACTIVE; WR_STROBE; }
 // Shield Control macros.
#define PIN_LOW(port, pin)    (port).OUTCLR.reg = (1<<(pin))
#define PIN_HIGH(port, pin)   (port).OUTSET.reg = (1<<(pin))
#define PIN_OUTPUT(port, pin) (port).DIR.reg |= (1<<(pin))
//####################################### GRAND CENTRAL M4 ############################
#elif defined(__SAMD51P20A__)      //regular UNO shield on GRAND CENTRAL M4
//SAMD51 pin |PD21|PD20|PC21|PC20|PC19|PC18|PB2|PB18| |PA2|PA5|PB3|PC0|PC1|
#define WRITE_DELAY { WR_ACTIVE4; }
#define IDLE_DELAY  { WR_IDLE2; }
#define READ_DELAY  { RD_ACTIVE8;}
#define RD_PIN  2
#define WR_PORT PORT->Group[0]
#define WR_PIN  5
#define CD_PIN  3
#define CS_PORT PORT->Group[2]
#define CS_PIN  0
#define RESET_PORT PORT->Group[2]
#define RESET_PIN  1
#define BMASK         ((1<<18)|(1<<2))   //BMASK has bits in H and L for WRCONFIG
#define CMASK         (0x0F << 18)       //CMASK only has bits in H
#define DMASK         (0x03 << 20)
#define WRMASK        ((0<<22) | (1<<28) | (1<<30)) //
#define RDMASK        ((1<<17) | (1<<28) | (1<<30)) //
#define write_8(x)   {  PORT->Group[1].OUTCLR.reg = BMASK; PORT->Group[2].OUTCLR.reg = CMASK; PORT->Group[3].OUTCLR.reg = DMASK; \
                        PORT->Group[1].OUTSET.reg  = (((x) & (1<<0)) << 18) | (((x) & (1<<1)) << 1); \
                        PORT->Group[2].OUTSET.reg  = (((x) & (15<<2)) << 16); \
                        PORT->Group[3].OUTSET.reg  = (((x) & (3<<6)) << 14); \
#define read_8()      ( ((PORT->Group[1].IN.reg & (1<<18)) >> 18)\
                      | ((PORT->Group[1].IN.reg & (1<<2)) >> 1)\
                      | ((PORT->Group[2].IN.reg & (15<<18)) >> 16)\
                      | ((PORT->Group[3].IN.reg & (3<<20)) >> 14)\
#define setWriteDir() { \
                        PORT->Group[1].DIRSET.reg = BMASK; \
                        PORT->Group[1].WRCONFIG.reg = (BMASK & 0xFFFF) | WRMASK; \
                        PORT->Group[1].WRCONFIG.reg = (BMASK >> 16) | WRMASK | (1<<31); \
                        PORT->Group[2].DIRSET.reg = CMASK; \
                        PORT->Group[2].WRCONFIG.reg = (CMASK >> 16) | WRMASK | (1<<31); \
                        PORT->Group[3].DIRSET.reg = DMASK; \
                        PORT->Group[3].WRCONFIG.reg = (DMASK >> 16) | WRMASK | (1<<31); \
#define setReadDir()  { \
                        PORT->Group[1].DIRCLR.reg = BMASK; \
                        PORT->Group[1].WRCONFIG.reg = (BMASK & 0xFFFF) | RDMASK; \
                        PORT->Group[1].WRCONFIG.reg = (BMASK >> 16) | RDMASK | (1<<31); \
                        PORT->Group[2].DIRCLR.reg = CMASK; \
                        PORT->Group[2].WRCONFIG.reg = (CMASK >> 16) | RDMASK | (1<<31); \
                        PORT->Group[3].DIRCLR.reg = DMASK; \
                        PORT->Group[3].WRCONFIG.reg = (DMASK >> 16) | RDMASK | (1<<31); \
#define write8(x)     { write_8(x); WRITE_DELAY; WR_STROBE; IDLE_DELAY; }
#define READ_8(dst)   { RD_STROBE; READ_DELAY; dst = read_8(); RD_IDLE2; RD_IDLE; }
#define PIN_OUTPUT(port, pin) (port).DIRSET.reg = (1<<(pin))
//####################################### DUE ############################
#elif defined(__SAM3X8E__)      //regular UNO shield on DUE
//SAM3XE pin |PC23|PC24|PC25|PC26|PC28|PB25|PC21|PC22| |PA16|PA24|PA23|PA22|PA6 |
#define WRITE_DELAY { WR_ACTIVE; }
#define IDLE_DELAY  { WR_IDLE; }
#define READ_DELAY  { RD_ACTIVE;}
#define RD_PORT PIOA
#define RD_PIN  16
#define WR_PORT PIOA
#define WR_PIN  24
#define CD_PORT PIOA
#define CD_PIN  23
#define CS_PORT PIOA
#define CS_PIN  22
#define RESET_PORT PIOA
#define RESET_PIN  6
#define BMASK         (1<<25)
#define CMASK         (0xBF << 21)
#define write_8(x)   {  PIOB->PIO_CODR = BMASK; PIOC->PIO_CODR = CMASK; \
                        PIOB->PIO_SODR = (((x) & (1<<2)) << 23); \
                        PIOC->PIO_SODR = (((x) & (1<<0)) << 22) \
                                       | (((x) & (1<<1)) << 20) \
                                       | (((x) & (1<<3)) << 25) \
                                       | (((x) & (1<<4)) << 22) \
                                       | (((x) & (1<<5)) << 20) \
                                       | (((x) & (1<<6)) << 18) \
                                       | (((x) & (1<<7)) << 16); \
#define read_8()      ( ((PIOC->PIO_PDSR & (1<<22)) >> 22)\
                      | ((PIOC->PIO_PDSR & (1<<21)) >> 20)\
                      | ((PIOB->PIO_PDSR & (1<<25)) >> 23)\
                      | ((PIOC->PIO_PDSR & (1<<28)) >> 25)\
                      | ((PIOC->PIO_PDSR & (1<<26)) >> 22)\
                      | ((PIOC->PIO_PDSR & (1<<25)) >> 20)\
                      | ((PIOC->PIO_PDSR & (1<<24)) >> 18)\
                      | ((PIOC->PIO_PDSR & (1<<23)) >> 16)\
#define setWriteDir() { PIOB->PIO_OER = BMASK; PIOC->PIO_OER = CMASK; }
                          PMC->PMC_PCER0 = (1 << ID_PIOB)|(1 << ID_PIOC);\
						  PIOB->PIO_ODR = BMASK; PIOC->PIO_ODR = CMASK;\
#define READ_8(dst)   { RD_STROBE; READ_DELAY; dst = read_8(); RD_IDLE; RD_IDLE; }
#define PIN_LOW(port, pin)    (port)->PIO_CODR = (1<<(pin))
#define PIN_HIGH(port, pin)   (port)->PIO_SODR = (1<<(pin))
#define PIN_OUTPUT(port, pin) (port)->PIO_OER = (1<<(pin))
//################################### LEONARDO ##############################
#elif defined(__AVR_ATmega32U4__)       //regular UNO shield on Leonardo
//AVR   pin |PE6|PD7|PC6|PD4|PD0|PD1|PB5|PB4| |PF7|PF6|PF5|PF4|PF1|
#define RD_PIN  7
#define WR_PIN  6
#define CD_PIN  5
#define CS_PIN  4
#define RESET_PIN  1
#define BMASK         (3<<4)
#define DMASK         ((1<<7)|(1<<4)|(3<<0))
#define EMASK         (1<<6)
static inline                   //hope we use r24
void write_8(uint8_t x)
    PORTB &= ~BMASK;
    PORTC &= ~CMASK;
    PORTD &= ~DMASK;
    PORTE &= ~EMASK;
    PORTB |= (((x) & (3 << 0)) << 4);
    PORTD |= (((x) & (1 << 2)) >> 1);
    PORTD |= (((x) & (1 << 3)) >> 3);
    PORTD |= (((x) & (1 << 4)) << 0);
    PORTC |= (((x) & (1 << 5)) << 1);
    PORTD |= (((x) & (1 << 6)) << 1);
    PORTE |= (((x) & (1 << 7)) >> 1);
#define read_8()      ( ((PINB & (3<<4)) >> 4)\
| ((PIND & (1<<1)) << 1)\
| ((PIND & (1<<0)) << 3)\
| ((PIND & (1<<4)) >> 0)\
| ((PINC & (1<<6)) >> 1)\
| ((PIND & (1<<7)) >> 1)\
| ((PINE & (1<<6)) << 1)\
#define setWriteDir() { DDRB |=  BMASK; DDRC |=  CMASK; DDRD |=  DMASK; DDRE |=  EMASK;  }
#define setReadDir()  { DDRB &= ~BMASK; DDRC &= ~CMASK; DDRD &= ~DMASK; DDRE &= ~EMASK;  }
//################################### UNO SHIELD on BOBUINO ##############################
#elif defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega644P__) //UNO shield on BOBUINO
#warning regular UNO shield on BOBUINO
//AVR   pin |PB3|PB2|PB1|PB0|PD3|PD2|PD6|PD5| |PA7|PA6|PA5|PA4|PA3|
#define RD_PORT PORTA
#define RD_PIN  7
#define WR_PORT PORTA
#define WR_PIN  6
#define CD_PORT PORTA
#define CD_PIN  5
#define CS_PORT PORTA
#define CS_PIN  4
#define RESET_PORT PORTA
#define RESET_PIN  3
#define BMASK         0x0F              //
#define DMASK         0x6C              //
#define write_8(x)    { PORTB = (PORTB & ~BMASK) | ((x) >> 4); \
        PORTD = (PORTD & ~DMASK) | ((x) & 0x0C) | (((x) & 0x03) << 5); }
#define read_8()      ( (PINB << 4) | (PIND & 0x0C) | ((PIND & 0x60) >> 5) )
//####################################### TEENSY 4.0 ############################
#elif defined(__IMXRT1062__) // regular UNO shield on a Teensy 4.x
#warning regular UNO shield on a Teensy 4.0
//LCD pins  |D7  |D6  |D5 |D4 |D3 |D2 |D1  |D0  | |RD  |WR  |RS  |CS  |RST |  A5
//MXRT pin  |7.17|7.10|9.8|9.6|9.5|9.4|7.11|7.16| |6.18|6.19|6.23|6.22|6.17|6.16
//4.x pins  |7   |6   |5  |4  |3   |2  |9  |8   | |14  |15  |16  |17  |18  |
#if 0
#define WRITE_DELAY { WR_ACTIVE8;WR_ACTIVE8; }
#define IDLE_DELAY  { WR_IDLE2;WR_IDLE; }
#define READ_DELAY  { RD_ACTIVE16;RD_ACTIVE16; }
#else
#error unspecified delays
#endif
#define RD_PORT GPIO6
#define RD_PIN 18
#define WR_PORT GPIO6
#define WR_PIN 19
#define CD_PORT GPIO6
#define CD_PIN 23
#define CS_PORT GPIO6
#define CS_PIN 22
#define RESET_PORT GPIO6
#define RESET_PIN 17
// configure macros for the data pins
#define GMASK ((1<<17)|(1<<10)|(1<<11)|(1<<16))
#define IMASK ((1<<8)|(1<<6)|(1<<5)|(1<<4))
#define write_8(d) { \
        GPIO7_DR_CLEAR = GMASK; GPIO9_DR_CLEAR = IMASK; \
        GPIO7_DR_SET = (((d) & (1 << 0)) << 16) \
                     | (((d) & (1 << 1)) << 10) \
                     | (((d) & (1 << 6)) << 4) \
                     | (((d) & (1 << 7)) << 10); \
        GPIO9_DR_SET = (((d) & (1 << 2)) << 2) \
                     | (((d) & (1 << 3)) << 2) \
                     | (((d) & (1 << 4)) << 2) \
                     | (((d) & (1 << 5)) << 3); \
#define read_8()   ((((GPIO7_PSR & (1 << 16)) >> 16) \
                   | ((GPIO7_PSR & (1 << 11)) >> 10) \
                   | ((GPIO9_PSR & (1 << 4)) >> 2) \
                   | ((GPIO9_PSR & (1 << 5)) >> 2) \
                   | ((GPIO9_PSR & (1 << 6)) >> 2) \
                   | ((GPIO9_PSR & (1 << 8)) >> 3) \
                   | ((GPIO7_PSR & (1 << 10)) >> 4) \
                   | ((GPIO7_PSR & (1 << 17)) >> 10)))
#define setWriteDir() {GPIO7_GDIR |=  GMASK;GPIO9_GDIR |=  IMASK; }
#define setReadDir()  {GPIO7_GDIR &= ~GMASK;GPIO9_GDIR &= ~IMASK; }
#define GPIO_INIT() {for (int i = 2; i <= 9; i++) pinMode(i, OUTPUT); for (int i = A0; i <= A4; i++) pinMode(i, OUTPUT);}
#define PASTE(x, y) x ## y
#define PIN_LOW(port, pin) PASTE(port, _DR_CLEAR) = (1<<(pin))
#define PIN_HIGH(port, pin) PASTE(port, _DR_SET) = (1<<(pin))
#define PIN_OUTPUT(port, pin) PASTE(port, _GDIR) |= (1<<(pin))
//################################ TEENSY 3.x and LC ############################
#elif defined(__MK20DX128__) || defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__) || defined(__MKL26Z64__)
#warning regular UNO shield on a Teensy 3.x or LC
//MK20,64,66|PD2|PD4|PD7|PA13|PA12|PD0|PC3|PD3| |PD1|PC0|PB0|PB1|PB3|
//MKL26Z prt|PD2|PD4|PD7|PA2 |PA1 |PD0|PC3|PD3| |PD1|PC0|PB0|PB1|PB3|
//3.6 pins  |7  |6  |5  |4   |3   |2  |9  |8  | |14 |15 |16 |17 |18 |
#if 0
#elif defined(__MKL26Z64__) // TeensyLC 48MHz.  Thanks DaveLapp
#define IDLE_DELAY  { }
#elif defined(__MK20DX128__) || defined(__MK20DX256__) // Teensy3.0 || 3.2 96MHz
#define WRITE_DELAY { WR_ACTIVE2; }
#define READ_DELAY  { RD_ACTIVE8; RD_ACTIVE; }
#elif defined(__MK64FX512__) // Teensy3.5 120MHz thanks to PeteJohno
#define READ_DELAY  { RD_ACTIVE8; }
#elif defined(__MK66FX1M0__) // Teensy3.6 180MHz untested.   delays can possibly be reduced.
#define WRITE_DELAY { WR_ACTIVE8; }
#define READ_DELAY  { RD_ACTIVE16; }
#else
#endif
#define RD_PORT GPIOD
#define RD_PIN 1
#define WR_PORT GPIOC
#define WR_PIN 0
#define CD_PORT GPIOB
#define CD_PIN 0
#define CS_PORT GPIOB
#define CS_PIN 1
#define RESET_PORT GPIOB
#define RESET_PIN 3
#if defined(__MKL26Z64__)     //TeensyLC.  Thanks DaveLapp
#define AMASK ((1<<1)|(1<<2))  //PA2,PA1 vs PA13,PA12 on 3.x
#define CMASK ((1<<3))
#define DMASK ((1<<0)|(1<<2)|(1<<3)|(1<<4)|(1<<7))
        GPIOA_PCOR = AMASK; GPIOC_PCOR = CMASK; GPIOD_PCOR = DMASK; \
        GPIOA_PSOR = (((d) & (1 << 3)) >> 2) \
                     | (((d) & (1 << 4)) >> 2); \
        GPIOC_PSOR = (((d) & (1 << 1)) << 2); \
        GPIOD_PSOR = (((d) & (1 << 0)) << 3) \
                     | (((d) & (1 << 2)) >> 2) \
                     | (((d) & (1 << 5)) << 2) \
                     | (((d) & (1 << 6)) >> 2) \
                     | (((d) & (1 << 7)) >> 5); \
#define read_8() ((((GPIOD_PDIR & (1<<3)) >> 3) \
                   | ((GPIOC_PDIR & (1 << 3)) >> 2) \
                   | ((GPIOD_PDIR & (1 << 0)) << 2) \
                   | ((GPIOA_PDIR & (1 << 1)) << 2) \
                   | ((GPIOA_PDIR & (1 << 2)) << 2) \
                   | ((GPIOD_PDIR & (1 << 7)) >> 2) \
                   | ((GPIOD_PDIR & (1 << 4)) << 2) \
                   | ((GPIOD_PDIR & (1 << 2)) << 5)))
#else
#define AMASK ((1<<12)|(1<<13))
        GPIOA_PSOR = (((d) & (1 << 3)) << 9) \
                     | (((d) & (1 << 4)) << 9); \
                   | ((GPIOA_PDIR & (1 << 12)) >> 9) \
                   | ((GPIOA_PDIR & (1 << 13)) >> 9) \
#endif
#define setWriteDir() {GPIOA_PDDR |= AMASK;GPIOC_PDDR |= CMASK;GPIOD_PDDR |= DMASK; }
#define setReadDir() {GPIOA_PDDR &= ~AMASK;GPIOC_PDDR &= ~CMASK;GPIOD_PDDR &= ~DMASK; }
#define READ_8(dst)   { RD_STROBE; READ_DELAY; dst = read_8(); RD_IDLE; } //PJ adjusted
//#define GPIO_INIT() {SIM_SCGC5 |= 0x3E00;}  //PORTA-PORTE
#define PIN_LOW(port, pin) PASTE(port, _PCOR) = (1<<(pin))
#define PIN_HIGH(port, pin) PASTE(port, _PSOR) = (1<<(pin))
#define PIN_OUTPUT(port, pin) PASTE(port, _PDDR) |= (1<<(pin))
//####################################### STM32 ############################
// NUCLEO:   ARDUINO_NUCLEO_xxxx from ST Core or ARDUINO_STM_NUCLEO_F103RB from MapleCore
// BLUEPILL: ARDUINO_NUCLEO_F103C8 / ARDUINO_BLUEPILL_F103C8 from ST Core or ARDUINO_GENERIC_STM32F103C from MapleCore
// MAPLE_REV3: n/a from ST Core or ARDUINO_MAPLE_REV3 from MapleCore
// ST Core:   ARDUINO_ARCH_STM32
// MapleCore: __STM32F1__
#elif defined(__STM32F1__) || defined(ARDUINO_ARCH_STM32)   //MapleCore or ST Core
#define IS_NUCLEO64 ( defined(ARDUINO_STM_NUCLEO_F103RB) \
                   || defined(ARDUINO_NUCLEO_F030R8) || defined(ARDUINO_NUCLEO_F091RC) \
                   || defined(ARDUINO_NUCLEO_F103RB) || defined(ARDUINO_NUCLEO_F303RE) \
                   || defined(ARDUINO_NUCLEO_F401RE) || defined(ARDUINO_NUCLEO_F411RE) \
                   || defined(ARDUINO_NUCLEO_F446RE) || defined(ARDUINO_NUCLEO_L053R8) \
                   || defined(ARDUINO_NUCLEO_L152RE) || defined(ARDUINO_NUCLEO_L476RG) \
                   || defined(ARDUINO_NUCLEO_F072RB) \
#define IS_NUCLEO144 ( defined(ARDUINO_NUCLEO_F207ZG) \
                   || defined(ARDUINO_NUCLEO_F429ZI) || defined(ARDUINO_NUCLEO_F767ZI) \
                   || defined(ARDUINO_NUCLEO_L496ZG) || defined(ARDUINO_NUCLEO_L496ZG_P) \
                   || defined(ARDUINO_NUCLEO_H743ZI) \
// F1xx, F4xx, L4xx have different registers and styles.  General Macros
#if defined(__STM32F1__)   //weird Maple Core
#define REGS(x) regs->x
#else                      //regular ST Core
#define REGS(x) x
#endif
#define PIN_HIGH(port, pin)   (port)-> REGS(BSRR) = (1<<(pin))
#define PIN_LOW(port, pin)    (port)-> REGS(BSRR) = (1<<((pin)+16))
#define PIN_MODE2(reg, pin, mode) reg=(reg&~(0x3<<((pin)<<1)))|(mode<<((pin)<<1))
#define GROUP_MODE(port, reg, mask, val)  {port->REGS(reg) = (port->REGS(reg) & ~(mask)) | ((mask)&(val)); }
// Family specific Macros.  F103 needs ST and Maple compatibility
// note that ILI9320 class of controller has much slower Read cycles
#if 0
#elif defined(__STM32F1__) || defined(ARDUINO_BLUEPILL_F103C8) || defined(ARDUINO_BLUEPILL_F103CB) || defined(ARDUINO_NUCLEO_F103RB)
#define WRITE_DELAY { }
#if defined(__STM32F1__)  //MapleCore crts.o does RCC.  not understand regular syntax anyway
#define GPIO_INIT()
#else
#define GPIO_INIT()   { RCC->APB2ENR |= RCC_APB2ENR_IOPAEN | RCC_APB2ENR_IOPBEN | RCC_APB2ENR_IOPCEN | RCC_APB2ENR_IOPDEN | RCC_APB2ENR_AFIOEN; \
        AFIO->MAPR |= AFIO_MAPR_SWJ_CFG_1;}
#endif
#define GP_OUT(port, reg, mask)           GROUP_MODE(port, reg, mask, 0x33333333)
#define GP_INP(port, reg, mask)           GROUP_MODE(port, reg, mask, 0x44444444)
#define PIN_OUTPUT(port, pin) {\
        if (pin < 8) {GP_OUT(port, CRL, 0xF<<((pin&7)<<2));} \
        else {GP_OUT(port, CRH, 0xF<<((pin&7)<<2));} \
#define PIN_INPUT(port, pin) { \
        if (pin < 8) { GP_INP(port, CRL, 0xF<<((pin&7)<<2)); } \
        else { GP_INP(port, CRH, 0xF<<((pin&7)<<2)); } \
// should be easy to add F030, F091, F303, L053, ...
#elif defined(STM32F030x8)
#define READ_DELAY  { RD_ACTIVE; }
#define GPIO_INIT()   { RCC->AHBENR |= RCC_AHBENR_GPIOAEN | RCC_AHBENR_GPIOBEN | RCC_AHBENR_GPIOCEN; }
#define PIN_OUTPUT(port, pin) PIN_MODE2((port)->MODER, pin, 0x1)
#elif defined(STM32F072xB)
#elif defined(STM32F091xC)
#elif defined(STM32F207xx)
#warning DELAY macros untested yet
#define WRITE_DELAY { WR_ACTIVE8; } //120MHz
#define READ_DELAY  { RD_ACTIVE16;}
#define GPIO_INIT()   { RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN | RCC_AHB1ENR_GPIOCEN | RCC_AHB1ENR_GPIODEN | RCC_AHB1ENR_GPIOEEN | RCC_AHB1ENR_GPIOFEN; }
#elif defined(STM32F303xE)
#define READ_DELAY  { RD_ACTIVE8; }  //thanks MasterT
#define GPIO_INIT()   { RCC->AHBENR |= RCC_AHBENR_GPIOAEN | RCC_AHBENR_GPIOBEN | RCC_AHBENR_GPIOCEN; \
                      /* AFIO->MAPR |= AFIO_MAPR_SWJ_CFG_1; */ }
#define PIN_OUTPUT(port, pin) PIN_MODE2((port)->MODER, pin, 0x1) //thanks fpiSTM
#elif defined(STM32F401xE)
#define WRITE_DELAY { WR_ACTIVE2; } //84MHz
#define GPIO_INIT()   { RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN | RCC_AHB1ENR_GPIOBEN | RCC_AHB1ENR_GPIOCEN; }
#elif defined(STM32F411xE)
#define WRITE_DELAY { WR_ACTIVE2; WR_ACTIVE; } //100MHz
#define READ_DELAY  { RD_ACTIVE4; RD_ACTIVE2; }
#elif defined(STM32F429xx)
#define WRITE_DELAY { WR_ACTIVE8; } //180MHz
#elif defined(STM32F446xx)
#elif defined(STM32F767xx)
#define WRITE_DELAY { WR_ACTIVE8;WR_ACTIVE2; } //216MHz
#define READ_DELAY  { RD_ACTIVE16;RD_ACTIVE16;RD_ACTIVE4;}
#elif defined(STM32H743xx)   // thanks MagicianT
#warning STM32H743xx< DELAY macros untested yet
#define WRITE_DELAY { WR_ACTIVE8;WR_ACTIVE2; } //F_CPU=400MHz
#define GPIO_INIT()   { RCC->AHB4ENR |= RCC_AHB4ENR_GPIOAEN | RCC_AHB4ENR_GPIOCEN | RCC_AHB4ENR_GPIODEN | RCC_AHB4ENR_GPIOEEN | RCC_AHB4ENR_GPIOFEN; }
#elif defined(STM32L053xx)
#define WRITE_DELAY { } //32MHz M0+
#define GPIO_INIT()   { RCC->IOPENR |= RCC_IOPENR_GPIOAEN | RCC_IOPENR_GPIOBEN | RCC_IOPENR_GPIOCEN; }
#elif defined(STM32L152xE)
#define WRITE_DELAY { } //32MHz M3
#elif defined(STM32L476xx)
#define WRITE_DELAY { WR_ACTIVE2; } //80MHz
#define READ_DELAY  { RD_ACTIVE4; RD_ACTIVE; }
#define GPIO_INIT()   { RCC->AHB2ENR |= RCC_AHB2ENR_GPIOAEN | RCC_AHB2ENR_GPIOBEN | RCC_AHB2ENR_GPIOCEN; }
#elif defined(STM32L496xx)
#define GPIO_INIT()   { RCC->AHB2ENR |= RCC_AHB2ENR_GPIOAEN | RCC_AHB2ENR_GPIOCEN | RCC_AHB2ENR_GPIODEN | RCC_AHB2ENR_GPIOEEN | RCC_AHB2ENR_GPIOFEN; }
#else
#error unsupported STM32
#endif
#if 0
#elif defined(ARDUINO_GENERIC_STM32F103C) || defined(ARDUINO_BLUEPILL_F103C8) || defined(ARDUINO_BLUEPILL_F103CB)
#warning Uno Shield on BLUEPILL
//LCD pins  |D7 |D6 |D5 |D4 |D3 |D2 |D1 |D0 | |RD |WR |RS |CS |RST| |SD_SS|SD_DI|SD_DO|SD_SCK|
//STM32 pin |PA7|PA6|PA5|PA4|PA3|PA2|PA1|PA0| |PB0|PB6|PB7|PB8|PB9| |PA15 |PB5  |PB4  |PB3   | **ALT-SPI1**
#define RD_PORT GPIOB
//#define RD_PIN  5
#define RD_PIN  0  //hardware mod to Adapter.  Allows use of PB5 for SD Card
#define WR_PORT GPIOB
#define WR_PIN  6
#define CD_PIN  7
#define CS_PIN  8
#define RESET_PIN  9
#define write_8(d)    { GPIOA->REGS(BSRR) = 0x00FF << 16; GPIOA->REGS(BSRR) = (d) & 0xFF; }
#define read_8()      (GPIOA->REGS(IDR) & 0xFF)
//                                         PA7 ..PA0
#define setWriteDir() {GP_OUT(GPIOA, CRL, 0xFFFFFFFF); }
#define setReadDir()  {GP_INP(GPIOA, CRL, 0xFFFFFFFF); }
#elif IS_NUCLEO64 // Uno Shield on NUCLEO-64
#warning Uno Shield on NUCLEO-64
#define RD_PORT GPIOA    //PA0
#define RD_PIN  0
#define WR_PORT GPIOA    //PA1
#define WR_PIN  1
#define CD_PORT GPIOA    //PA4
#define CD_PIN  4
#define CS_PORT GPIOB    //PB0
#define CS_PIN  0
#define RESET_PORT GPIOC //PC1
#define RESET_PIN  1
#define AMASK ((1<<9)|(1<<10)|(1<<8))        //#0, #2, #7
#define BMASK ((1<<3)|(1<<5)|(1<<4)|(1<<10)) //#3, #4, #5, #6
#define CMASK ((1<<7))                       //#1
        GPIOA->REGS(BSRR) = AMASK << 16; \
        GPIOB->REGS(BSRR) = BMASK << 16; \
        GPIOC->REGS(BSRR) = CMASK << 16; \
        GPIOA->REGS(BSRR) = (  ((d) & (1<<0)) << 9) \
                            | (((d) & (1<<2)) << 8) \
                            | (((d) & (1<<7)) << 1); \
        GPIOB->REGS(BSRR) = (  ((d) & (1<<3)) << 0) \
                            | (((d) & (1<<4)) << 1) \
                            | (((d) & (1<<5)) >> 1) \
                            | (((d) & (1<<6)) << 4); \
        GPIOC->REGS(BSRR) = (  ((d) & (1<<1)) << 6); \
#define read_8() (       (  (  (GPIOA->REGS(IDR) & (1<<9)) >> 9) \
                            | ((GPIOC->REGS(IDR) & (1<<7)) >> 6) \
                            | ((GPIOA->REGS(IDR) & (1<<10)) >> 8) \
                            | ((GPIOB->REGS(IDR) & (1<<3)) >> 0) \
                            | ((GPIOB->REGS(IDR) & (1<<5)) >> 1) \
                            | ((GPIOB->REGS(IDR) & (1<<4)) << 1) \
                            | ((GPIOB->REGS(IDR) & (1<<10)) >> 4) \
                            | ((GPIOA->REGS(IDR) & (1<<8))  >> 1)))
#if defined(ARDUINO_NUCLEO_F103RB) || defined(ARDUINO_STM_NUCLEO_F103RB) //F103 has unusual GPIO modes
//                                 PA10,PA9,PA8                       PB10                   PB5,PB4,PB3                             PC7
#define setWriteDir() {GP_OUT(GPIOA, CRH, 0xFFF); GP_OUT(GPIOB, CRH, 0xF00); GP_OUT(GPIOB, CRL, 0xFFF000); GP_OUT(GPIOC, CRL, 0xF0000000); }
#define setReadDir()  {GP_INP(GPIOA, CRH, 0xFFF); GP_INP(GPIOB, CRH, 0xF00); GP_INP(GPIOB, CRL, 0xFFF000); GP_INP(GPIOC, CRL, 0xF0000000); }
#else      //F0xx, F3xx, F4xx, L0xx, L1xx, L4xx use MODER
//                                   PA10,PA9,PA8           PB10,PB5,PB4,PB3                      PC7
#define setWriteDir() { setReadDir(); \
                        GPIOA->MODER |=  0x150000; GPIOB->MODER |=  0x100540; GPIOC->MODER |=  0x4000; }
#define setReadDir()  { GPIOA->MODER &= ~0x3F0000; GPIOB->MODER &= ~0x300FC0; GPIOC->MODER &= ~0xC000; }
#endif
#elif IS_NUCLEO144 // Uno Shield on NUCLEO-144
#warning Uno Shield on NUCLEO-144
#define RD_PORT GPIOA    //PA3
#define RD_PIN  3
#define WR_PORT GPIOC    //PC0
#define WR_PIN  0
#define CD_PORT GPIOC    //PC3
#define CD_PIN  3
#define CS_PORT GPIOF    //PF3
#define CS_PIN  3
#define RESET_PORT GPIOF //PF5
#define RESET_PIN  5
#define DMASK ((1<<15))                         //#1
#define EMASK ((1<<13)|(1<<11)|(1<<9))          //#3, #5, #6
#define FMASK ((1<<12)|(1<<15)|(1<<14)|(1<<13)) //#0, #2, #4, #7
        GPIOD->REGS(BSRR) = DMASK << 16; \
        GPIOE->REGS(BSRR) = EMASK << 16; \
        GPIOF->REGS(BSRR) = FMASK << 16; \
        GPIOD->REGS(BSRR) = (  ((d) & (1<<1)) << 14); \
        GPIOE->REGS(BSRR) = (  ((d) & (1<<3)) << 10) \
                            | (((d) & (1<<5)) << 6) \
                            | (((d) & (1<<6)) << 3); \
        GPIOF->REGS(BSRR) = (  ((d) & (1<<0)) << 12) \
                            | (((d) & (1<<2)) << 13) \
                            | (((d) & (1<<4)) << 10) \
                            | (((d) & (1<<7)) << 6); \
#define read_8() (       (  (  (GPIOF->REGS(IDR) & (1<<12)) >> 12) \
                            | ((GPIOD->REGS(IDR) & (1<<15)) >> 14) \
                            | ((GPIOF->REGS(IDR) & (1<<15)) >> 13) \
                            | ((GPIOE->REGS(IDR) & (1<<13)) >> 10) \
                            | ((GPIOF->REGS(IDR) & (1<<14)) >> 10) \
                            | ((GPIOE->REGS(IDR) & (1<<11)) >> 6) \
                            | ((GPIOE->REGS(IDR) & (1<<9))  >> 3) \
                            | ((GPIOF->REGS(IDR) & (1<<13)) >> 6)))
//                                             PD15                PE13,PE11,PE9          PF15,PF14,PF13,PF12
                        GPIOD->MODER |=  0x40000000; GPIOE->MODER |=  0x04440000; GPIOF->MODER |=  0x55000000; }
#define setReadDir()  { GPIOD->MODER &= ~0xC0000000; GPIOE->MODER &= ~0x0CCC0000; GPIOF->MODER &= ~0xFF000000; }
#elif defined(ARDUINO_MAPLE_REV3) // Uno Shield on MAPLE_REV3 board
#warning Uno Shield on MAPLE_REV3 board
#define RD_PORT GPIOC
#define RD_PIN  0
#define WR_PIN  1
#define CD_PIN  2
#define CS_PORT GPIOC
#define CS_PIN  3
#define RESET_PIN  4
        GPIOA->REGS(BSRR) = 0x0703 << 16; \
        GPIOB->REGS(BSRR) = 0x00E0 << 16; \
        GPIOA->REGS(BSRR) = (  ((d) & (1<<0)) << 10) \
                            | (((d) & (1<<2)) >> 2) \
                            | (((d) & (1<<3)) >> 2) \
                            | (((d) & (1<<6)) << 2) \
                            | (((d) & (1<<7)) << 2); \
        GPIOB->REGS(BSRR) = (  ((d) & (1<<1)) << 6) \
                            | (((d) & (1<<5)) << 1); \
#define read_8()  (     (   (  (GPIOA->REGS(IDR) & (1<<10)) >> 10) \
                            | ((GPIOB->REGS(IDR) & (1<<7)) >> 6) \
                            | ((GPIOA->REGS(IDR) & (1<<0)) << 2) \
                            | ((GPIOA->REGS(IDR) & (1<<1)) << 2) \
                            | ((GPIOB->REGS(IDR) & (1<<6)) >> 1) \
                            | ((GPIOA->REGS(IDR) & (1<<8)) >> 2) \
                            | ((GPIOA->REGS(IDR) & (1<<9)) >> 2)))
//                                 PA10,PA9,PA8                   PA1,PA0                     PB7,PB6,PB5
#define setWriteDir() {GP_OUT(GPIOA, CRH, 0xFFF); GP_OUT(GPIOA, CRL, 0xFF); GP_OUT(GPIOB, CRL, 0xFFF00000); }
#define setReadDir()  {GP_INP(GPIOA, CRH, 0xFFF); GP_INP(GPIOA, CRL, 0xFF); GP_INP(GPIOB, CRL, 0xFFF00000); }
#else
#error REGS group
#endif
#ifndef IDLE_DELAY
#endif
//################################### ESP32 ##############################
#elif defined(ESP32)       //regular UNO shield on TTGO D1 R32 (ESP32)
#define LCD_RD  2  //LED
#define LCD_WR  4
#define LCD_RS 15  //hard-wired to A2 (GPIO35)
#define LCD_CS 33  //hard-wired to A3 (GPIO34)
#define LCD_RST 32 //hard-wired to A4 (GPIO36)
#define LCD_D0 12
#define LCD_D1 13
#define LCD_D2 26
#define LCD_D3 25
#define LCD_D4 17
#define LCD_D5 16
#define LCD_D6 27
#define LCD_D7 14
#define RD_PORT GPIO.out
#define RD_PIN  LCD_RD
#define WR_PORT GPIO.out
#define WR_PIN  LCD_WR
#define CD_PORT GPIO.out
#define CD_PIN  LCD_RS
#define CS_PORT GPIO.out1.val
#define CS_PIN  LCD_CS
#define RESET_PORT GPIO.out1.val
#define RESET_PIN  LCD_RST
static inline uint32_t map_8(uint32_t d)
    return (
               0
               | ((d & (1 << 0)) << (LCD_D0 - 0))
               | ((d & (1 << 1)) << (LCD_D1 - 1))
               | ((d & (1 << 2)) << (LCD_D2 - 2))
               | ((d & (1 << 3)) << (LCD_D3 - 3))
               | ((d & (1 << 4)) << (LCD_D4 - 4))
               | ((d & (1 << 5)) << (LCD_D5 - 5))
               | ((d & (1 << 6)) << (LCD_D6 - 6))
               | ((d & (1 << 7)) << (LCD_D7 - 7))
static inline uint8_t map_32(uint32_t d)
    return (
               0
               | ((d & (1 << LCD_D0)) >> (LCD_D0 - 0))
               | ((d & (1 << LCD_D1)) >> (LCD_D1 - 1))
               | ((d & (1 << LCD_D2)) >> (LCD_D2 - 2))
               | ((d & (1 << LCD_D3)) >> (LCD_D3 - 3))
               | ((d & (1 << LCD_D4)) >> (LCD_D4 - 4))
               | ((d & (1 << LCD_D5)) >> (LCD_D5 - 5))
               | ((d & (1 << LCD_D6)) >> (LCD_D6 - 6))
               | ((d & (1 << LCD_D7)) >> (LCD_D7 - 7))
static inline void write_8(uint16_t data)
    GPIO.out_w1tc = map_8(0xFF);  //could define once as DMASK
    GPIO.out_w1ts = map_8(data);
static inline uint8_t read_8()
    return map_32(GPIO.in);
static void setWriteDir()
    pinMode(LCD_D0, OUTPUT);
    pinMode(LCD_D1, OUTPUT);
    pinMode(LCD_D2, OUTPUT);
    pinMode(LCD_D3, OUTPUT);
    pinMode(LCD_D4, OUTPUT);
    pinMode(LCD_D5, OUTPUT);
    pinMode(LCD_D6, OUTPUT);
    pinMode(LCD_D7, OUTPUT);
static void setReadDir()
    pinMode(LCD_D0, INPUT);
    pinMode(LCD_D1, INPUT);
    pinMode(LCD_D2, INPUT);
    pinMode(LCD_D3, INPUT);
    pinMode(LCD_D4, INPUT);
    pinMode(LCD_D5, INPUT);
    pinMode(LCD_D6, INPUT);
    pinMode(LCD_D7, INPUT);
#define READ_DELAY  { }
#define PIN_LOW(p, b)        (digitalWrite(b, LOW))
#define PIN_HIGH(p, b)       (digitalWrite(b, HIGH))
#define PIN_OUTPUT(p, b)     (pinMode(b, OUTPUT))
//################################## NANO33 BLE ############################
#elif defined(ARDUINO_ARDUINO_NANO33BLE)
#warning regular UNO shield on a Nano33 BLE
//BLE pin   |P0.23|P1.14|P1.13|P1.15|P1.12|P1.11|P0.27|P0.21| |P0.4|P0.5|P0.30|P0.29|P0.31|
//NANO pins |7    |6    |5    |4    |3    |2    |9    |8    | |A0  |A1  |A2   |A3   |A4   |
#define WRITE_DELAY { WR_ACTIVE8; }   //M4F @ 64MHz
#define RD_PORT NRF_P0
#define RD_PIN 4
#define WR_PORT NRF_P0
#define WR_PIN 5
#define CD_PORT NRF_P0
#define CD_PIN 30
#define CS_PORT NRF_P0
#define CS_PIN 29
#define RESET_PORT NRF_P0
#define RESET_PIN 31
#define P0MASK ((1<<23)|(1<<27)|(1<<21))   //NRF_P0
#define P1MASK ((1<<14)|(1<<13)|(1<<15)|(1<<12)|(1<<11))  //NRF_P1
        NRF_P0->OUTCLR = P0MASK; NRF_P1->OUTCLR = P1MASK; \
        NRF_P0->OUTSET = (((d) & (1 << 0)) << 21) \
                     | (((d) & (1 << 1)) << 26) \
                     | (((d) & (1 << 7)) << 16); \
        NRF_P1->OUTSET = (((d) & (1 << 2)) << 9) \
                     | (((d) & (1 << 4)) << 11) \
                     | (((d) & (1 << 5)) << 8) \
                     | (((d) & (1 << 6)) << 8); \
#define read_8()   ((((NRF_P0->IN & (1<<21)) >> 21) \
                   | ((NRF_P0->IN & (1 << 27)) >> 26) \
                   | ((NRF_P1->IN & (1 << 11)) >> 9) \
                   | ((NRF_P1->IN & (1 << 12)) >> 9) \
                   | ((NRF_P1->IN & (1 << 15)) >> 11) \
                   | ((NRF_P1->IN & (1 << 13)) >> 8) \
                   | ((NRF_P1->IN & (1 << 14)) >> 8) \
                   | ((NRF_P0->IN & (1 << 23)) >> 16)))
#define BUS_CNF(x) {\
    NRF_P0->PIN_CNF[21] = x;\
    NRF_P0->PIN_CNF[27] = x;\
    NRF_P1->PIN_CNF[11] = x;\
    NRF_P1->PIN_CNF[12] = x;\
    NRF_P1->PIN_CNF[15] = x;\
    NRF_P1->PIN_CNF[13] = x;\
    NRF_P1->PIN_CNF[14] = x;\
    NRF_P0->PIN_CNF[23] = x;\
#define setWriteDir() {BUS_CNF(3); }
#define setReadDir()  {BUS_CNF(0); }
//#define GPIO_INIT()   {for (int i = A0; i <= A4; i++) pinMode(i, OUTPUT);}
#define PIN_LOW(port, pin)    (port)->OUTCLR = (1<<(pin))
#define PIN_HIGH(port, pin)   (port)->OUTSET = (1<<(pin))
#define PIN_OUTPUT(port, pin) (port)->DIR |= (1<<(pin))
//############################# END OF BLOCKS ############################
#else
// Try to use the standard Arduino commands - test code for Renesas
#define RD_PORT 0
#define RD_PIN  A0
#define WR_PORT 0
#define WR_PIN  A1
#define CD_PORT 0
#define CD_PIN  A2
#define CS_PORT 0
#define CS_PIN  A3
#define write_8(x)    { digitalWrite(8, (x&0b00000001)); \
                        digitalWrite(9, (x&0b00000010)>>1); \
                        digitalWrite(2, (x&0b00000100)>>2); \
                        digitalWrite(3, (x&0b00001000)>>3); \
                        digitalWrite(4, (x&0b00010000)>>4); \
                        digitalWrite(5, (x&0b00100000)>>5); \
                        digitalWrite(6, (x&0b01000000)>>6); \
                        digitalWrite(7, (x&0b10000000)>>7); \
#define read_8()      ( digitalRead(8)|(digitalRead(9)<<1)|(digitalRead(2)<<2)|(digitalRead(3)<<3)|(digitalRead(4)<<4)| \
                        (digitalRead(5)<<5)|(digitalRead(6)<<6)|(digitalRead(7)<<7) )
#define setWriteDir() { pinMode(8, OUTPUT);  pinMode(9, OUTPUT); pinMode(2, OUTPUT);  pinMode(3, OUTPUT); \
                        pinMode(4, OUTPUT);  pinMode(5, OUTPUT); pinMode(6, OUTPUT);  pinMode(7, OUTPUT); }
#define setReadDir()  { pinMode(8, INPUT);  pinMode(9, INPUT); pinMode(2, INPUT);  pinMode(3, INPUT); \
                        pinMode(4, INPUT);  pinMode(5, INPUT); pinMode(6, INPUT);  pinMode(7, INPUT); }
#endif                          // regular UNO shields on Arduino boards
#endif                          //!defined(USE_SPECIAL) || defined (USE_SPECIAL_FAIL)
#ifndef RD_ACTIVE
#define RD_ACTIVE  PIN_LOW(RD_PORT, RD_PIN)
#endif
#ifndef RD_IDLE
#endif
#define RD_OUTPUT  PIN_OUTPUT(RD_PORT, RD_PIN)
#ifndef WR_ACTIVE
#define WR_ACTIVE  PIN_LOW(WR_PORT, WR_PIN)
#endif
#ifndef WR_IDLE
#endif
#define WR_OUTPUT  PIN_OUTPUT(WR_PORT, WR_PIN)
#ifndef CD_COMMAND
#endif
#ifndef CD_DATA
#endif
#define CD_OUTPUT  PIN_OUTPUT(CD_PORT, CD_PIN)
#ifndef CS_ACTIVE
#endif
#ifndef CS_IDLE
#endif
 // General macros.   IOCLR registers are 1 cycle when optimised.
#define WR_STROBE { WR_ACTIVE; WR_IDLE; }       //PWLW=TWRL=50ns
#define RD_STROBE { RD_IDLE; RD_ACTIVE; RD_ACTIVE; RD_ACTIVE; }      //PWLR=TRDL=150ns, tDDR=100ns
#if !defined(GPIO_INIT)
#define GPIO_INIT()
#endif
#define CTL_INIT()   { GPIO_INIT(); RD_OUTPUT; WR_OUTPUT; CD_OUTPUT; CS_OUTPUT; RESET_OUTPUT; }
Wow it works! Thank you very much for explaining me everything and saving my Christmas present! Thanks for being patient with me. If it´s okay i´ll mark your answer as the solution
You can´t imagine how happy i am now <3
That's excellent news! Whew! I was a little (or a lot) worried that it would turn out to be a different type of controller and maybe one of the ones that required tinkering with wait states to get it to work. And yes, feel free to mark my reply as the solution so that others will know that your problem has been resolved. Happy displaying!
Hello, I'm using also R4 Wifi plus your display (2,8"), but library Examples that use Touchscreen don't work, any suggestion to solve?
many thanks
David Prentice, author of the MCUFRIEND_kbv library, is sadly no longer with us. See: David Prentice RIP
Genius!! It worked brilliantly for me. Thank you so much
Thanks van_der_decken
Been looking for this solution for months. :grinning:
I have a ILI9486 display and it only shows a white screen. here
That's unfortunate. My ILI9486 display shield works just fine with an R4. I wish you the best of luck in figuring out why yours doesn't.
