Unojoy potentiometers are dependent from each other
When I upload Unojoy code in my R3, potentiometers are dependent from each other. When I turn potentiometer on A0, the values of others also change. Is there any fix for this?
Here are codes:
#include "UnoJoy.h"
void setup(){
  setupPins();
  setupUnoJoy();
void loop(){
  // Always be getting fresh data
  dataForController_t controllerData = getControllerData();
  setControllerData(controllerData);
void setupPins(void){
  // Set all the digital pins as inputs
  // with the pull-up enabled, except for the
  // two serial line pins
  for (int i = 2; i <= 12; i++){
    pinMode(i, INPUT);
    digitalWrite(i, HIGH);
  pinMode(A4, INPUT);
  digitalWrite(A4, HIGH);
  pinMode(A5, INPUT);
  digitalWrite(A5, HIGH);
dataForController_t getControllerData(void){
  // Set up a place for our controller data
  //  Use the getBlankDataForController() function, since
  //  just declaring a fresh dataForController_t tends
  //  to get you one filled with junk from other, random
  //  values that were in those memory locations before
  dataForController_t controllerData = getBlankDataForController();
  // Since our buttons are all held high and
  //  pulled low when pressed, we use the "!"
  //  operator to invert the readings from the pins
  controllerData.triangleOn = !digitalRead(2);
  controllerData.circleOn = !digitalRead(3);
  controllerData.squareOn = !digitalRead(4);
  controllerData.crossOn = !digitalRead(5);
  controllerData.dpadUpOn = !digitalRead(6);
  controllerData.dpadDownOn = !digitalRead(7);
  controllerData.dpadLeftOn = !digitalRead(8);
  controllerData.dpadRightOn = !digitalRead(9);
  controllerData.l1On = !digitalRead(10);
  controllerData.r1On = !digitalRead(11);
  controllerData.selectOn = !digitalRead(12);
  controllerData.startOn = !digitalRead(A4);
  controllerData.homeOn = !digitalRead(A5);
  // Set the analog sticks
  //  Since analogRead(pin) returns a 10 bit value,
  //  we need to perform a bit shift operation to
  //  lose the 2 least significant bits and get an
  //  8 bit number that we can use
  controllerData.leftStickX = analogRead(A0) >> 2;
  controllerData.leftStickY = analogRead(A1) >> 2;
  controllerData.rightStickX = analogRead(A2) >> 2;
  controllerData.rightStickY = analogRead(A3) >> 2;
  // And return the data!
  return controllerData;
Library:
/*  UnoJoy.h
 *   Alan Chatham - 2012
 *    RMIT Exertion Games Lab
 *  This library gives you a standard way to create Arduino code that talks
 *   to the UnoJoy firmware in order to make native USB game controllers.
 *  Functions:
 *   setupUnoJoy()
 *   getBlankDataForController()
 *   setControllerData(dataForController_t dataToSet)
 *   NOTE: You cannot use pins 0 or 1 if you use this code - they are used by the serial communication.
 *         Also, the setupUnoJoy() function starts the serial port at 38400, so if you're using
 *         the serial port to debug and it's not working, this may be your problem.
 *   === How to use this library ===
 *   If you want, you can move this file into your Arduino/Libraries folder, then use it like a normal library.
 *   However, since you'll need to refer to the details of the dataForController_t struct in this file, I would suggest you use
 *    it by adding it to your Arduino sketch manually (in Arduino, go to Sketch->Add file...)
 *  To use this library to make a controller, you'll need to do 3 things:
 *   Call setupUnoJoy(); in the setup() block
 *   Create and populate a dataForController_t type variable and fill it with your data
 *         The getBlankDataForController() function is good for that.
 *   Call setControllerData(yourData); where yourData is the variable from above,
 *         somewhere in your loop(), once you're ready to push your controller data to the system.
 *         If you forget to call sendControllerData in your loop, your controller won't ever do anything
 *  You can then debug the controller with the included Processing sketch, UnoJoyProcessingVisualizer
 *  To turn it into an actual USB video game controller, you'll reflash the
 *   Arduino's communication's chip using the instructions found in the 'Firmware' folder,
 *   then unplug and re-plug in the Arduino.
 *  Details about the dataForController_t type are below, but in order to create and use it,
 *   you'll declare it like:
 *      dataForController_t sexyControllerData;
 *   and then control button presses and analog stick movement with statements like:
 *      sexyControllerData.triangleOn = 1;   // Marks the triangle button as pressed
 *      sexyControllerData.squareOn = 0;     // Marks the square button as unpressed
 *      sexyControllerData.leftStickX = 90;  // Analog stick values can range from 0 - 255
#ifndef UNOJOY_H
#define UNOJOY_H
    #include <stdint.h>
    #include <util/atomic.h>
    #include <Arduino.h>
    // This struct is the core of the library.
    //  You'll create an instance of this and manipulate it,
    //  then use the setControllerData function to send that data out.
    //  Don't change this - the order of the fields is important for
    //  the communication between the Arduino and it's communications chip.
	typedef struct dataForController_t
		uint8_t triangleOn : 1;  // Each of these member variables
		uint8_t circleOn : 1;    //  control if a button is off or on
		uint8_t squareOn : 1;    // For the buttons,
		uint8_t crossOn : 1;     //  0 is off
		uint8_t l1On : 1;        //  1 is on
		uint8_t l2On : 1;
		uint8_t l3On : 1;        // The : 1 here just tells the compiler
		uint8_t r1On : 1;        //  to only have 1 bit for each variable.
                                 //  This saves a lot of space for our type!
		uint8_t r2On : 1;
		uint8_t r3On : 1;
		uint8_t selectOn : 1;
		uint8_t startOn : 1;
		uint8_t homeOn : 1;
		uint8_t dpadLeftOn : 1;
		uint8_t dpadUpOn : 1;
		uint8_t dpadRightOn : 1;
		uint8_t dpadDownOn : 1;
        uint8_t padding : 7;     // We end with 7 bytes of padding to make sure we get our data aligned in bytes
		uint8_t leftStickX : 8;  // Each of the analog stick values can range from 0 to 255
		uint8_t leftStickY : 8;  //  0 is fully left or up
		uint8_t rightStickX : 8; //  255 is fully right or down
		uint8_t rightStickY : 8; //  128 is centered.
                                 // Important - analogRead(pin) returns a 10 bit value, so if you're getting strange
                                 //  results from analogRead, you may need to do (analogRead(pin) >> 2) to get good data
	} dataForController_t;
    // Call setupUnoJoy in the setup block of your program.
    //  It sets up the hardware UnoJoy needs to work properly
    void setupUnoJoy(void);
    // You can also call the set
    void setupUnoJoy(int);
    // This sets the controller to reflect the button and
    // joystick positions you input (as a dataForController_t).
    // The controller will just send a zeroed (joysticks centered)
    // signal until you tell it otherwise with this function.
    void setControllerData(dataForController_t);
    // This function gives you a quick way to get a fresh
    //  dataForController_t with:
    //    No buttons pressed
    //    Joysticks centered
    // Very useful for starting each loop with a blank controller, for instance.
    // It returns a dataForController_t, so you want to call it like:
    //    myControllerData = getBlankDataForController();
    dataForController_t getBlankDataForController(void);
//----- End of the interface code you should be using -----//
//----- Below here is the actual implementation of
  // This dataForController_t is used to store
  //  the controller data that you want to send
  //  out to the controller.  You shouldn't mess
  //  with this directly - call setControllerData instead
  dataForController_t controllerDataBuffer;
  // This updates the data that the controller is sending out.
  //  The system actually works as following:
  //  The UnoJoy firmware on the ATmega8u2 regularly polls the
  //  Arduino chip for individual bytes of a dataForController_t.
  void setControllerData(dataForController_t controllerData){
    // Probably unecessary, but this guarantees that the data
    //  gets copied to our buffer all at once.
    ATOMIC_BLOCK(ATOMIC_FORCEON){
      controllerDataBuffer = controllerData;
  // serialCheckInterval governs how many ms between
  //  checks to the serial port for data.
  //  It shouldn't go above 20 or so, otherwise you might
  //  get unreliable data transmission to the UnoJoy firmware,
  //  since after it sends a request, it waits 25 ms for a response.
  //  If you really need to make it bigger than that, you'll have to
  //  adjust that timeout in the UnoJoy ATmega8u2 firmware code as well.
  volatile int serialCheckInterval = 1;
  // This is an internal counter variable to count ms between
  //  serial check times
  int serialCheckCounter = 0;
  // This is the setup function - it sets up the serial communication
  //  and the timer interrupt for actually sending the data back and forth.
  void setupUnoJoy(void){
    // First, let's zero out our controller data buffer (center the sticks)
    controllerDataBuffer = getBlankDataForController();
    // Start the serial port at the specific, low-error rate UnoJoy uses.
    //  If you want to change the rate, you'll have to change it in the
    //  firmware for the ATmega8u2 as well.  250,000 is actually the best rate,
    //  but it's not supported on Macs, breaking the processing debugger.
    Serial.begin(38400);
    // Now set up the Timer 0 compare register A
    //  so that Timer0 (used for millis() and such)
    //  also fires an interrupt when it's equal to
    //  128, not just on overflow.
    // This will fire our timer interrupt almost
    //  every 1 ms (1024 us to be exact).
    OCR0A = 128;
    TIMSK0 |= (1 << OCIE0A);
  // If you really need to change the serial polling
  //  interval, use this function to initialize UnoJoy.
  //  interval is the polling frequency, in ms.
  void setupUnoJoy(int interval){
    serialCheckInterval = interval;
    setupUnoJoy();
  // This interrupt gets called approximately once per ms.
  //  It counts how many ms between serial port polls,
  //  and if it's been long enough, polls the serial
  //  port to see if the UnoJoy firmware requested data.
  //  If it did, it transmits the appropriate data back.
  ISR(TIMER0_COMPA_vect){
    serialCheckCounter++;
    if (serialCheckCounter >= serialCheckInterval){
      // If there is incoming data stored in the Arduino serial buffer
      while (Serial.available() > 0) {
        pinMode(13, OUTPUT);
        //digitalWrite(13, HIGH);
        // Get incoming byte from the ATmega8u2
        byte inByte = Serial.read();
        // That number tells us which byte of the dataForController_t struct
        //  to send out.
        Serial.write(((uint8_t*)&controllerDataBuffer)[inByte]);
        //digitalWrite(13, LOW);
  // Returns a zeroed out (joysticks centered)
  //  dataForController_t variable
  dataForController_t getBlankDataForController(void){
    // Create a dataForController_t
    dataForController_t controllerData;
    // Make the buttons zero
    controllerData.triangleOn = 0;
    controllerData.circleOn = 0;
    controllerData.squareOn = 0;
    controllerData.crossOn = 0;
    controllerData.l1On = 0;
    controllerData.l2On = 0;
    controllerData.l3On = 0;
    controllerData.r1On = 0;
    controllerData.r2On = 0;
    controllerData.r3On = 0;
    controllerData.dpadLeftOn = 0;
    controllerData.dpadUpOn = 0;
    controllerData.dpadRightOn = 0;
    controllerData.dpadDownOn = 0;
    controllerData.selectOn = 0;
    controllerData.startOn = 0;
    controllerData.homeOn = 0;
    //Set the sticks to 128 - centered
    controllerData.leftStickX = 128;
    controllerData.leftStickY = 128;
    controllerData.rightStickX = 128;
    controllerData.rightStickY = 128;
#endif
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
#include "UnoJoy.h"
  setupPins();
  setupUnoJoy();
void setupPins(void) {
  for (int i = 2; i <= 12; i++)pinMode(i, INPUT_PULLUP);
  pinMode(A4, INPUT_PULLUP);
  pinMode(A5, INPUT_PULLUP);
dataForController_t getControllerData(void) {
  delay(1);
  delay(1);
  delay(1);
OR
#include "UnoJoy.h"
  setupPins();
  setupUnoJoy();
  delay(10);
void setupPins() {
void getControllerData() {
  byte GetButt = PORTD;
  controllerData.triangleOn = !GetButt & (1 << 2);
  controllerData.circleOn = !GetButt & (1 << 3);
  controllerData.squareOn = !GetButt & (1 << 4);
  controllerData.crossOn = !GetButt & (1 << 5);
  controllerData.dpadUpOn = !GetButt & (1 << 6);
  controllerData.dpadDownOn = !GetButt & (1 << 7);
  GetButt = PORTB;
  controllerData.dpadLeftOn = !GetButt & (1);
  controllerData.dpadRightOn = !GetButt & (2);
  controllerData.l1On = !GetButt & (4);
  controllerData.r1On = !GetButt & (8);
  controllerData.selectOn = !GetButt & (16);
  GetButt = PORTC;
  controllerData.startOn = !GetButt & (1 << 4);
  controllerData.homeOn = !GetButt & (1 << 5);
This sounds like a hardware problem.
What value are the pots you are using?
If their value is higher than 10K, this could explain the problem.
Possible fixes could include adding capacitors and/or discarding the first result of analogRead() and using the second read.
What does that mean? Can you explain?
I use 1K pots
Hi, @Mirinoyatov_Yaxyobek
Welcome to the forum.
Can you post some images of your project?
So we can see your component layout.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Sure. Here it is:
As power supply I use my laptop Acer EX-2519
try it
Do you have a DMM? (Digital MultiMeter)
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
@TomGeorge Yes
@Delta_G and @kolaha I don't understand you. Can you explain me in easier way?
P.S. I tested this on another board and same weird thing happens (but not in TinkerCad).
what can i explain ? i offered you two variant of your sketch modified by me. you should upload one and look what is changed, then upload second and again watching, then say me if your problem is solved, remain, or got worse.
I tried both codes and nothing changed.
Same weird thing even in Arduino mode: potentiometers are dependent. My 2nd chinese board acts in the same way. Maybe the problem is from PC side? It worked perfectly 3 monthes ago.
OK I somehow found a fix but a weird one: All pots should be connected or madness will happen.
Thank you all for your help and responses, I wouldn't find a solution without your help.
