When adding a arduino uno R4 wifi i have to update the board. This should take a few minutes but after about an half hour it’s still the same. Using chrome on a mac.
What goes wrong here? Any tips to verfy?
Thanks!
I would assume it is updated so shut down the app and try again.
Tried. But the new device isnt created…
if i continue here i get the update screen. But then it seems to get stuck. Can see the led, xt rx blink and get some animation on the screen but no improvement.
Arduino R4 is programmable from the offline and online ide. Did a reset of the arduino, Did write some sketches on it (blink and simple webserver, so bot the chips got some new data). Did even a restore for the usb connectivity…
tried a new board and got no problem. Updated fine in a few minutes. Is there another way to restore the arduino uno R4 to factory settings? Or is there another way to flash the update? Its the update for the “device provisioning 2.0”
Thanks!
The factory installed sketch is in the examples under the UNO R4 section of examples. It is in the LED Matrix collection.
Hi @Human82. I'm going to ask you to provide some additional information that might help us to identify the problem.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
agent-log.txt will start.agent-log.txt" file in any text editor.<CODE/> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.Please let us know if you have any questions or problems while following those instructions.
"P": "COM4",
"D": "Q29ubmVjdGlvbiB0byAiVGVjaG5pZWsiIGZhaWxlZA0KUmV0cnlpbmcgaW4gICI1MDAiIG1pbGxpc2Vjb25kcw0KU2VyaWFsQWdlbnRDbGFzczo6aGFuZGxlSW5pdCBFcnJvciByZWNlaXZpbmcgcGFja2V0DQo="
"P": "COM4",
"D": "V2lGaS5zdGF0dXMoKTogMA0K"
"P": "COM4",
"D": "Q3VycmVudCBXaUZpIEZpcm13YXJlOiAwLjYuMA0K"
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
sendraw COM4 VaoDAAMC02qqVQ==
close COM4
Closing serial port COM4
Shutting down reader on COM4
"Cmd": "Close",
"Desc": "Got unregister/close on port.",
"Port": "COM4",
"Baud": 9600
Shutting down writer on COM4
writerBuffered just got closed. make sure you make a new one. port:COM4
open COM4 9600 timedraw
"Cmd": "Open",
"Desc": "Got register/open on port.",
"Port": "COM4",
"Baud": 9600,
"BufferType": "timedraw"
sendraw COM4 VaoCAAraAAEgA4EYZDn/qlU=
sendraw COM4 VaoDAAMB4fGqVQ==
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
close COM4
"Cmd": "Close",
"Port": "COM4",
"Baud": 9600
"Cmd": "Serial",
"ProgrammerStatus": "Starting"
"Msg": "Flashing with command:C:/Users/tom.vrysen/.arduino-create/arduino/arduino-fwuploader/2.4.1/arduino-fwuploader.exe firmware list -b arduino:renesas_uno:unor4wifi",
"ProgrammerStatus": "Busy"
"Msg": "Board FQBN Module Version",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.1.0 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.2.0 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.2.1 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.3.0 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.4.1 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 0.5.2 ",
"Msg": "Arduino UNO R4 WiFi arduino:renesas_uno:unor4wifi ESP32-S3 ✔ 0.6.0 ",
"Msg": "",
"Flash": "Ok",
"ProgrammerStatus": "Done"
"Cmd": "Serial",
"Msg": "Flashing with command:C:/Users/tom.vrysen/.arduino-create/arduino/arduino-fwuploader/2.4.1/arduino-fwuploader.exe firmware get-version -a COM4 -b arduino:renesas_uno:unor4wifi",
"Msg": "Erase flash",
"Msg": "",
"Msg": "Done in 0.002 seconds",
"Msg": "Write 46588 bytes to flash (12 pages)",
"Msg": "\r[ ] 0% (0/12 pages)\r[== ] 8% (1/12 pages)\r[===== ] 16% (2/12 pages)\r[======= ] 25% (3/12 pages)\r[========== ] 33% (4/12 pages)\r[============ ] 41% (5/12 pages)\r[=============== ] 50% (6/12 pages)\r[================= ] 58% (7/12 pages)\r[==================== ] 66% (8/12 pages)\r[====================== ] 75% (9/12 pages)\r[========================= ] 83% (10/12 pages)\r[=========================== ] 91% (11/12 pages)\r[==============================] 100% (12/12 pages)",
"Msg": "Done in 3.142 seconds",
"Msg": "FIRMWARE-VERSION: 0.6.0",
"Msg": "Firmware version installed: 0.6.0",
"Flash": "Ok",
downloadtool bossac 1.9.1-arduino5 arduino keep
"DownloadStatus": "Pending",
"Msg": "Ensure that the files are executable"
"Msg": "Updating map with location C:\\Users\\tom.vrysen\\.arduino-create\\arduino\\bossac\\1.9.1-arduino5"
"DownloadStatus": "Success",
"Msg": "Map Updated"
"Cmd": "Serial",
"Msg": "Restarting in bootloader mode",
"Msg": "Flashing with command:C:/Users/tom.vrysen/.arduino-create/arduino/bossac/1.9.1-arduino5/bossac.exe -d --port=COM4 -U -e -w C:/Users/TOM~1.VRY/AppData/Local/Temp/arduino-create-agent1290439779/provisioningv2.bin -R",
"Msg": "Set binary mode",
"Msg": "version()=Arduino Bootloader (SAM-BA extended) 2.0 [Arduino:IKXYZ]",
"Msg": "Connected at 921600 baud",
"Msg": "identifyChip()=nRF52840-QIAA",
"Msg": "write(addr=0,size=0x34)",
"Msg": "writeWord(addr=0x30,value=0x400)",
"Msg": "writeWord(addr=0x20,value=0)",
"Msg": "chipErase(addr=0)",
"Msg": "",
"Msg": "Write 181936 bytes to flash (45 pages)",
"Msg": "\r[ ] 0% (0/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0, size=0x1000)",
"Msg": "write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1000, size=0x1000)",
"Msg": "\r[= ] 4% (2/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x2000, size=0x1000)",
"Msg": "\r[== ] 6% (3/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x3000, size=0x1000)",
"Msg": "\r[== ] 8% (4/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x4000, size=0x1000)",
"Msg": "\r[=== ] 11% (5/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x5000, size=0x1000)",
"Msg": "\r[==== ] 13% (6/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x6000, size=0x1000)",
"Msg": "\r[==== ] 15% (7/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x7000, size=0x1000)",
"Msg": "\r[===== ] 17% (8/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x8000, size=0x1000)",
"Msg": "\r[====== ] 20% (9/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x9000, size=0x1000)",
"Msg": "\r[====== ] 22% (10/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xa000, size=0x1000)",
"Msg": "\r[======= ] 24% (11/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xb000, size=0x1000)",
"Msg": "\r[======== ] 26% (12/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xc000, size=0x1000)",
"Msg": "\r[======== ] 28% (13/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xd000, size=0x1000)",
"Msg": "\r[========= ] 31% (14/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xe000, size=0x1000)",
"Msg": "\r[========== ] 33% (15/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0xf000, size=0x1000)",
"Msg": "\r[========== ] 35% (16/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x10000, size=0x1000)",
"Msg": "\r[=========== ] 37% (17/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x11000, size=0x1000)",
"Msg": "\r[============ ] 40% (18/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x12000, size=0x1000)",
"Msg": "\r[============ ] 42% (19/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x13000, size=0x1000)",
"Msg": "\r[============= ] 44% (20/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x14000, size=0x1000)",
"Msg": "\r[============== ] 46% (21/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x15000, size=0x1000)",
"Msg": "\r[============== ] 48% (22/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x16000, size=0x1000)",
"Msg": "\r[=============== ] 51% (23/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x17000, size=0x1000)",
"Msg": "\r[================ ] 53% (24/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x18000, size=0x1000)",
"Msg": "\r[================ ] 55% (25/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x19000, size=0x1000)",
"Msg": "\r[================= ] 57% (26/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1a000, size=0x1000)",
"Msg": "\r[================== ] 60% (27/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1b000, size=0x1000)",
"Msg": "\r[================== ] 62% (28/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1c000, size=0x1000)",
"Msg": "\r[=================== ] 64% (29/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1d000, size=0x1000)",
"Msg": "\r[==================== ] 66% (30/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1e000, size=0x1000)",
"Msg": "\r[==================== ] 68% (31/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x1f000, size=0x1000)",
"Msg": "\r[===================== ] 71% (32/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x20000, size=0x1000)",
"Msg": "\r[====================== ] 73% (33/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x21000, size=0x1000)",
"Msg": "\r[====================== ] 75% (34/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x22000, size=0x1000)",
"Msg": "\r[======================= ] 77% (35/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x23000, size=0x1000)",
"Msg": "\r[======================== ] 80% (36/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x24000, size=0x1000)",
"Msg": "\r[======================== ] 82% (37/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x25000, size=0x1000)",
"Msg": "\r[========================= ] 84% (38/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x26000, size=0x1000)",
"Msg": "\r[========================== ] 86% (39/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x27000, size=0x1000)",
"Msg": "\r[========================== ] 88% (40/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x28000, size=0x1000)",
"Msg": "\r[=========================== ] 91% (41/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x29000, size=0x1000)",
"Msg": "\r[============================ ] 93% (42/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x2a000, size=0x1000)",
"Msg": "\r[============================ ] 95% (43/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x2b000, size=0x1000)",
"Msg": "\r[============================= ] 97% (44/45 pages)write(addr=0x34,size=0x1000)",
"Msg": "writeBuffer(scr_addr=0x34, dst_addr=0x2c000, size=0x1000)",
"Msg": "\r[==============================] 100% (45/45 pages)",
"Msg": "Done in 11.541 seconds",
"Msg": "reset()",
"Flash": "Ok",
"Cmd": "Open",
"Port": "COM4",
"Baud": 9600,
"P": "COM4",
"D": "QkxFIEF2YWlsYWJsZQ0K"
"P": "COM4",
"D": "TmV0d29yayBzZXR0aW5ncyByZWNlaXZlZDoNCldJRkkNClNTSUQ6IFRlY2huaWVrDQo="
"P": "COM4",
"D": "KioqKiogQXJkdWlubyBJb1QgQ2xvdWQgLSAyLjYuMSAqKioqKg0KRGV2aWNlIElEOiA5ZDBjNDRiZC1lNDI1LTQwYmMtODAwMC03ZjJiODAxZDY2ZGENCk1RVFQgQnJva2VyOiBpb3QuYXJkdWluby5jYzo4ODg1"
"P": "COM4",
"D": "DQpOZXR3b3JrIENvbmZpZ3VyYXRvcjogMC4zLjANCg=="
"P": "COM4",
"D": "V2lGaS5zdGF0dXMoKTogMg0K"
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"D": "Qw=="
"P": "COM4",
"D": "dXJyZW50IFdpRmkgRmlybXdhcmU6IDAuNi4wDQo="
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
"P": "COM4",
This is wath i got after completing the steps you asked when i try to update.
Update got stuck while updating. Didn’t got the message i got with a new arduino R4 wifi trying the same update to deconnect from usb en reconnect.
Thanks for the effort!
@ptillisch did you find anything in the logs? As far as i can see the update was succesfull but then i got stuck. Is there a way to fix this?
These are data being sent over the serial port by the "provisioning" sketch program that runs on the UNO R4 WiFi board when creating an Arduino Cloud IoT Device for the board. The data is encoded as Base64.
After decoding, we can understand what the board is sending:
"P": "COM4",
"D": "Connection to "Techniek" failed
Retrying in "500" milliseconds
SerialAgentClass::handleInit Error receiving packet
"P": "COM4",
"D": "WiFi.status(): 0
"P": "COM4",
"D": "Current WiFi Firmware: 0.6.0
Unfortunately I don't know how to interpret this.
The "Connection to "Techniek" failed" is clear: this means the board is attempting to connect to the Wi-Fi access point with the SSID of "Techniek" and failing. I attempted to reproduce the fault by turning off my access point so that the UNO R4 WiFi will fail to connect, the "Updating Your Board for Improved Setup" process still completes successfully for me.
So I don't have any reason to believe that the failure of your board to connect to the Wi-Fi access point is the cause of the problem you are experiencing. However, it would be worth looking into why it is failing to connect just in case that might be a factor.
What looks more interesting is this part of the logs:
During the Device creation process, Arduino Cloud sends commands to the board over the serial port, as you can see here:
(VaoDAAMB4fGqVQ== is the command encoded as CBOR)
the "SerialAgentClass::handleInit Error receiving packet" error indicates that the program running on UNO R4 WiFi was not able to recognize the command sent by Arduino Cloud. The commands look perfectly fine though.
Maybe the data is being corrupted somehow? If you have any external circuitry, modules, or shields attached to the UNO R4 WiFi board, disconnect everything so that you are only working with the board alone and then try again. That will eliminate the possibility that any external circuitry might be interfering with the board's operation.
If you have a different USB cable, try switching the cable you use. We have had several reports of strange problems that turned out to be caused by using low quality/defective/damaged cables with the UNO R4 WiFi board. I believe the problem with these cables is that the Wi-Fi radio on the board can draw significant amounts of current while performing communication operations. If the cable is not able to provide sufficient current, this can case the board to misbehave. It is a bit confusing because these events only last for a very short moment, so the board can appear to be perfectly happy with an insufficient cable. The board's inability to connect to the Wi-Fi access point might exacerbate this problem because it might be that the radio draws more current under these conditions.
The wifi it wants to connect to is from a school who asked to get there board running again. Wrote a simpele webserver sketch to it. The board connected to my network at home after that. So i taught the data from there wifi was erased. There is nothing connected to the board. As cable i used the same as i used to try updating a new board. It’s a official arduino cable where i can switch to usb or usb c. Tried both but no luck.
the teacher who gave it to me mentioned his students tried to work with it from the online and offline ide. Did write some different sketches to it and a reset. But somehow its not erased completely.
Is it possible to completely reset the board? Any other suggestions?
@ptillisch any suggestions?
