Hi all,
Is it possible to upload a sketch to the giga via its onboard wifi (kinda OTA)?
thanks for any help!
Hi all,
yes. with Arduino IoT Cloud or by doing it as the Cloud.
Giga is a big version of Portenta H7 so same solutions apply
Thanks for that!
I am more into independent update like used with ArduinoOTA. i use it with ESP32-Wroom and its great. i was wondering if it works on the Giga as well...
thanks for that.
The best way is to test that in person...bought a couple of boards and will start the investigation process...
Hi, you finally found a solution, because I'm racking my brains but I still haven't managed it
Hi, I use this GitHub - arduino-libraries/Arduino_Portenta_OTA: OTA on the Arduino Portenta. to download from my own file server.
Hi, I'm also interested and working on a way to upload sketches for the GIGA R1. It seems there is no Wifi OTA libary working yet for Arduino. I trying to work with another wireless seriell solution. I have 2 Avisaro WLAN modules, so can connect two Arduino's via RX/TX and send/receive signals. And I've two USB/Serial converter. Unfortunately they do not work as expected. So, I'm not ready yet. However, I'm always interested to programm the GIGA wireless.
I used the instructions here and it works
Thanks for your input. I did the procedure but I'm not sure whether it works. Can you help further with an basic exemple script like attached ? So far, I can only use OTA for ESP8266 etc.
```cpp
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#ifndef STASSID
#define STASSID "xxxxxxxxxxxx"
#define STAPSK "xxxxxxxxxxxx"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) {
Serial.println("Auth Failed");
} else if (error == OTA_BEGIN_ERROR) {
Serial.println("Begin Failed");
} else if (error == OTA_CONNECT_ERROR) {
Serial.println("Connect Failed");
} else if (error == OTA_RECEIVE_ERROR) {
Serial.println("Receive Failed");
} else if (error == OTA_END_ERROR) {
Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
ArduinoOTA.handle();
Thanks, however it did not work for me, until I added delay(1000) after the Serial.begin(115200) loop.
