I am using Arduino IDE 2.3.10 under Win 11 with 32GB of memory. I am using a PICO-W 2MB flash, 256K SRAM. When I attempt to compile and upload the Blink code, I get:
Sketch uses 312836 bytes (17%) of program storage space. Maximum is 1830912 bytes.
Global variables use 69596 bytes (26%) of dynamic memory, leaving 192548 bytes for local variables. Maximum is 262144 bytes.
"C:\Users\jjpur\AppData\Local\Arduino15\packages\rp2040\tools\pqt-python3\1.0.1-base-3a57aed-1/python3" -I "C:\Users\jjpur\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\6.0.0/tools/uf2conv.py" --serial "COM1" --family RP2040 --deploy "C:\Users\jjpur\AppData\Local\arduino\sketches\21CFE464E6DF968BDBC043FE9F0AF139/Blink.ino.uf2"
Resetting COM1
Converting to uf2, output size: 659968, start address: 0x2000
Scanning for RP2040 devices
Unable to build drive list
Failed uploading: uploading error: exit status 1
I am using a data cable and the OS responds when I plug/unplug the cable. I know it's going to be something stupid, but I'm not seeing it.
