I got Arduino Uno. While uploading the code- I get the following error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x34
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x34
PS- I already tried reseting the device.
The problem has arisen since I tried to upload a code which I think never got completely uploaded.
I also encountered a problem downloading sketch.
I got the error code:
Arduino: 1.6.13 (Windows 7), Board: "Arduino Nano, ATmega168"
Sketch uses 444 bytes (3%) of program storage space. Maximum is 14,336 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 1,015 bytes for local variables. Maximum is 1,024 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x46
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Things you can do:
Check if the right COM port is selected
Check if the right board is selected
If you are using a not genuine Arduino you should download the necessary USB to serial chips driver
NewStudent:
Things you can do:
It was working before. The problem is the new one.
PS I already tried all this measures
