Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\abrde\AppData\Local\Temp\arduino_build_953827/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf6
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf6
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
[code]
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
- Unplug your Arduino board from the computer.
- Tools > Port
- Note the ports, if any, listed in the menu.
- Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
- Plug your Arduino board into the computer.
- Tools > Port - The new port listed in the menu is your Arduino board.
Using Port : COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf3
Same problem persist. Its been happening since i have uploaded the code for Bluetooth control bot vehicle.
Do you have the Bluetooth module connected to pins 0 and 1 on your Uno?
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 1918 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
C:\Users\abrde\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\abrde\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\abrde\AppData\Local\Temp\arduino_build_448955/Blink.ino.hex:i
System wide configuration file is "C:\Users\abrde\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xae
No connection is given to the arduino. I am trying to upload basic blink code which is available in the example.
I also include Serial.begin(9600), but the result is same.
Is COM6 indeed the Arduino? You can check in Windows Device Manager what happens when you connect / disconnect the board?
