Upload fails: "not in sync: resp=0x00"
Hey I have the problem that my arduino doesnt want to connect with ide. I went threw all ur steps but it wont work. Cn u help me pls ?
This ist the error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Welcome to the forum
Which Arduino board are you using ?
Hi, Arduino Uno
Hi @ardtomake04. I'm going to ask you to post the full verbose output from an upload attempt.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Uncheck the box next to Show verbose output during: ☑ compilation in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: ☐ upload.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Attempt an upload, as you did before.
  6. Wait for the upload to fail.
  7. You will see a "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  8. Open a forum reply here by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block icon on toolbar
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the error output from the upload into the code block.
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to post the output.
Der Sketch verwendet 2460 Bytes (7%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 213 Bytes (10%) des dynamischen Speichers, 1835 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
"C:\Users\patri\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\patri\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM10" -b115200 -D "-Uflash:w:C:\Users\patri\AppData\Local\Temp\arduino\sketches\9BBD319EA257ECD2E09EC7ACC46A8C2C/TestSens.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\patri\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM10
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude done.  Thank you.
Fehlgeschlagenes Hochladen: Hochladefehler: exit status 1
Please try this experiment and then report back with the results:
  1. Connect the Arduino board to your computer with a USB cable.
  2. Press and release the button on the Arduino board that is marked "RESET".
Now please reply here on the forum thread with the answer to the following question:
  • Did you see the "L" LED blink multiple times quickly immediately after you released the "RESET" button?
it blinked 2 times and finished
OK, that is probably a good sign. The bootloader program that handles sketch uploads blinks the LED three times quickly when it is activated by resetting the board. Although your description of two blinks is a bit off, the blinks are very fast so it difficult to count them so I'll disregard that. The blink after reset eliminates some possible causes of the upload error. We now know two things:
  • The primary microcontroller on the board is running
  • The bootloader is present on the microcontroller.
Now we move on to investigating other possible causes of the error.
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
  1. Disconnect the USB cable of the Arduino board from your computer.
  2. Select Tools > Port from the Arduino IDE menus.
  3. Take note of the ports, if any, listed in the menu.
  4. Close the Tools menu.
    :exclamation: The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Connect the Arduino board to your computer with a USB cable.
  6. Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
So the right port is here COM10 that is listed new after connecting der arduino board to my computer via usb. The problem is still there
And I looked again after the reset option. And there were couple of times only two blinking and other times more than 3. So its a bit confusing
It is possible for a short or external circuitry connected to the Arduino board to interfere with the upload process, causing this type of upload error.
Make sure the board is not sitting on anything conductive that could short the contacts on the bottom of the board. Make sure there isn't any conductive debris (e.g., strands of wire or component leads) on the board or on the surface the board is sitting on.
If you have a shield or any external circuitry or components connected to your Arduino board, try this experiment:
  2. Disconnect any shields, modules, external circuitry, etc. from your board.
  3. Connect the Arduino board to your computer with a USB cable.
Now try uploading a sketch to the board again. Does the upload succeed?
This experiment will determine whether the upload error was caused by interference from your external circuitry. If so, you can then focus your attention on identifying the specific problem with the circuit and resolving it.
so i tried it and removed any modules but the problem is sadly still there ...
I have been proceeding on the assumption that you are using the UNO R3 board (or a 3rd party equivalent), but I should double check to make sure. Something that can be confusing is there are multiple boards with "UNO" in their name:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
So ive got this arduino from my university but i dont know exactly what it is.
Aha! This is a 3rd party derivative of the classic Nano board, not an UNO. Please try this:
  1. Select Tools > Board > Arduino AVR Boards > Arduino Nano from the Arduino IDE menus.
  2. Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE menus.
Now try uploading the sketch again. Hopefully this time it will be successful.
It worked ! :slight_smile: Thank u so much and sry for the misunderstanding.
You are welcome. I'm glad it is working now.
Regards,
Per
