Hello all
I have a whole pile of Mini Pro's here..... and all of a sudden, I cannot write to any of them?
I usually connect them via an Uno using TX-RX, and that works well.
Sometimes you need to press the reset button at the correct time for a successful upload.
BUT... not they all hang halfway through the upload and I cannot work out why.
The read fine, then half way along the writing sequence, I get an upload error.
Tried 4 different Mini pros, different lead (I have a FTDI lead here that I have never got to work).
Nothing. Not sure what has changed. Never seen it hang mid upload before/
Also tried using the CH340 drivers.... no difference.
Any ideas?
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Sketch uses 7,532 bytes (24%) of program storage space. Maximum is 30,720 bytes.
Global variables use 445 bytes (21%) of dynamic memory, leaving 1,603 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Steve\AppData\Local\Temp\build6967324727188064902.tmp/X582_SF_PSU_controller_v14_Full_comms_rebuild.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\Steve\AppData\Local\Temp\build6967324727188064902.tmp/X582_SF_PSU_controller_v14_Full_comms_rebuild.cpp.hex"
avrdude: writing flash (7532 bytes):
Writing | ################avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Hmm. Well, spent the whole evening on this and I am stumped. Deleted all the USB drivers from the laptop and re-installed them... no difference.
Tried programming 4 different Mini Pro's (2 of which are new) with different known working code... all fail at the same place.
Been programming them like this for ages now. Not sure what changed.
Using programmer 1.6.5 by the way... as I always have. Could that be it? I have had issues updating programmers before on this old Vaio, so I stuck with the known working version.
Don't want to really uninstall unless its definitely that?
Well... tried 1.8.5 and that doesn't work either.
I am stumped.
