Upload Program
I receive this type of error at uploading the program on arduino.
Arduino: 1.6.11 (Windows 8.1), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
Sketch uses 940 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfc
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfc
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Did you select the right board?
Did you select the right COM port?
Did you install the drivers?
Real or clone Arduino?
