Here are two more symptoms since I posted the first msg of this thread.
- First -
Checked verbose output during upload in File->Preferences:
- Held the shift key while selecting
after selecting File->Upload from menu and the following output was generated -
Binary sketch size: 1602 bytes (of a 258048 byte maximum)
G:\Dev\Arduino\Ver1_Software\arduino-1.0\hardware/tools/avr/bin/avrdude -CG:\Dev\Arduino\Ver1_Software\arduino-1.0\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\.\COM3 -b115200 -D -Uflash:w:D:\DOCUME~1\larryh\LOCALS~1\Temp\build4790036421831321667.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "G:\Dev\Arduino\Ver1_Software\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: A [41]
avrdude: Recv: V [56]
avrdude: Recv: R [52]
avrdude: Recv: I [49]
avrdude: Recv: S [53]
avrdude: Recv: P [50]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: t [74]
avrdude: stk500v2_getsync(): found AVRISP programmer
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500 Version 2.x firmware
Programmer Model: AVRISP
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude: Recv:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
/* unplugged USB cable here */
avrdude: ser_send(): write error: sorry no info avail
Each "avrdude: Send: . ..." line was output to the IDE status window when the Red "RX" LED contiues to flash every 5 seconds.
- Here is second symptom:
Using the Loop-Back Test Instructions at
http://arduino.cc/forum/index.php/topic,73748.0.html
and Tools->Serial Monitor of IDE, the first entry in text box is echoed back except for the last character of line. None of subsequent lines are echoed at all when send button of Serial Monitor window is clicked.
Except for the jumper connections used for the Loop-Back Test, nothing (except USB cable) is connected to board during other test runs.
Should the TX LED flash during the Upload operation?
Does the "CPU used" need to be specified anywhere in program source code?
Larry
