I am running Arduino 1.8.5 (with all possible updates) on Ubuntu 16.04.
This is my one and only Uno, first time upload.
Upon uploading I keep getting: avrdude: ser_open(): can’t open device “/dev/ttyACHO”: Permission denied
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 726 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied
An error occurred while uploading the sketch
option enabled in File -> Preferences.
RXTX was installed through Synaptic. (ver: 2.2pre2-13)
Board info shows: BN: Arduino/Genuino Uno
VID: 2341
PID: 0043
fester@Office-Ubuntu://home/fester/Arduino/arduino-1.8.5$ ls -l /dev/ttyACM
ls: cannot access '/dev/ttyACM': No such file or directory
fester@Office-Ubuntu://home/fester/Arduino/arduino-1.8.5$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 003: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 003 Device 002: ID 045e:00f6 Microsoft Corp. Comfort Optical Mouse 1000
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
fester@Office-Ubuntu://home/fester/Arduino/arduino-1.8.5$ sudo chmod a+rw /dev/ttyACM0
[sudo] password for fester:
fester@Office-Ubuntu://home/fester/Arduino/arduino-1.8.5$ sudo usermod -a -G dialout fester
fester@Office-Ubuntu://home/fester/Arduino/arduino-1.8.5$ sudo chown fester /dev/ttyACM*
……..next I tried running as root.
root@Office-Ubuntu:~# ./arduino
Picked up JAVA_TOOL_OPTIONS:
(java:6470): Gtk-WARNING **: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.9BD7BZ': No such file or directory
(java:6470): Gtk-WARNING **: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
As far as I’m concerned, the upload worked when I was root.
…....then I tried running as a user again and got:
Assuming I shouldn’t always be running as root, how do I get the permissions to work when running as a user?
