urgent help
Hello , I am using a peice of code in my project to send an SMS now what should i do if i wanted to
replace the number in
mySerial.println(“AT+CMGS=+YYxxxxxxxxx\”\r”);
with a variable which can store the number , For example
num=+xxxxxxxxxxx;
mySerial.println(“AT+CMGS=\num\”\r”);
THE CODE IS AS :-
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
delay(100);
if (Serial.available()>0)
switch(Serial.read())
case 's':
SendMessage();
case 'r':
RecieveMessage();
if (mySerial.available()>0)
Serial.write(mySerial.read());
void SendMessage()
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS="+93XXXXXXX"\r"); // Replace x with mobile number
mySerial.println("I am SMS from GSM Module");// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
void RecieveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
BUT WONT THAT REWRITE THE AT+CMGS COMMAND AGAIN AND AGAIN ?? !!
like this :-
char num[15]={+92xxxxxxxx};
mySerial.print(“AT+CMGF=1”);
mySerial.print(“\r”);
mySerial.print(“AT+CMGS="”);
mySerial.print(“num");
delay(300);
please do guide me a lil bit if i got the array right im a little weak in programing
i tried it the code is compiling right but the serial monitor gives an error on sending the s for send message , I wrote this :-
mySerial.println("AT+CMGS=");
mySerial.print(num);
mySerial.print("\r");
where num is as :-
char* num="+92xxxxxxxxx";
    char num[] = "1234567890";
    int size1 = sizeof(num) - 1;
    for (int i = 0; i < size1; i++)
        Serial.println(num[i]);
    Serial.println("done");
Try something like
char* num = "+92xxxxxxxxx";
  Serial.print("AT+CMGS=");
  Serial.println(num);
void loop() {}
