URGENT Send SMS with SIM800L CMGS OK but didn't receive in the phone
Hello all,
I am facing a very weird issue with my project using the GSM module SIM800L...
According to the SIM800L AT commands guide, to send an SMS i have to use the "AT+CMGS=" command, and when the send was successfully the module returns "+CMGS: OK"...
And i have some string constants to store the different menu levels of my application...
The problem is, in the begin of the tests everything was working good for a while, and suddenly, some strings that are the menus i am not receiving in my phone anymore, but the module returns the "+CMGS... OK", and others strings are send normally... and i can't figure out why ...
Example:
If i send an SMS with the text "menu", the module has to answer with the menu...
The module answers that the send was sucessfully, but in my cellphone i do not receive anything...
If i send an SMS with any text that not represents a valid command, the module answer as "Opcao Desconhecida" (in english, Uknown Option), and this one i always receive the response in my cellphone, never fail...
in both case, i receive the module response that the message was sent successfully...
And the procedure to send both sms is exactly the same...
I will put parts of code here.
This is the header with the strings of menu (don't worry about the values, they are in portuguese).
String main_menu = "Menu \n 1 - Registrar Numero \n 2 - Listar Numeros \n 3 - Estado da Valvula \n 4 - Fechar Valvula \n 5 - Estado Alarme \n 6 - Desativar Alarme \n 7 - Valor dos Sensores \n 8 - Deletar Numero";
String menu_opt_1 = "Inserir Telefone (DDD + Numero). Exemplo:41987654321, ou '0'(zero) para cancelar";
String menu_opt_11 = "O numero esta correto (sim ou nao)? ";
String menu_opt_111 = "Formato de numero invalido. Insira novamente, ou '0'(zero) para cancelar.";
String menu_opt_1111 = "Ok, numero registrado.";
String menu_opt_11111 = "Registro cancelado.";
String menu_opt_2 = "Telefones Registrados:";
String menu_opt_22 = "Nenhum telefone registrado.";
String menu_opt_3 = "Estado da Valvula:";
String menu_opt_4 = "Fechando a Valvula... Aguarde resposta";
String menu_opt_5 = "Estado do Alarme:";
String menu_opt_6 = "Desantivando Alarme... Aguarde resposta";
String menu_opt_7_co = "Concentração de CO: ";
String menu_opt_7_lpg = "Concentração de LPG: ";
String not_valid = "Opcao desconhecida.";
This function formats the command that tells the module to send SMS with the text "command_response" to the phone "command_sender".
The parameters are passed to it by other functions, but basically is one of the strings above and the phone number to be sent
` void send_sms(String command_response, String command_sender)
  String module_response = "";
  module_response = send_AT_command("AT+CMGS=\"" + command_sender + "\"\n" + command_response + "\n" + (char)26);
  Serial.println(module_response);
And then, the function that send the command to GSM module via UART, and wait for the module response with "OK" or "ERROR"
String send_AT_command(String AT_command) //function to send via UART to GSM Module the string with the AT command
  String gsm_module_response = ""; //string to store the value read in UART from GSM Module
  Serial.println("Sending command " + AT_command);
  Serial2.println(AT_command); //Send the AT command via UART to GSM module
  while(!Serial2.available()); //wait until a data is available on serial buffer
  if(AT_command.indexOf("CMGS") > 0)
      while (gsm_module_response.indexOf("CMGS") < 0)
          gsm_module_response = Serial2.readString(); //read the data from the buffer and stores in the string variable
      //Serial.println(gsm_module_response);
      delay(100);
      return gsm_module_response;
don't worry with the Serial.prints, is for "debug"
any suggestion?
Why is this "URGENT"?
Post your entire sketch, not bits and pieces.
This project is part of my final undergraduate project that i have 4 weeks to finish...
Here it goes...
Main:
/*------------------------ Headers -----------------------*/
#include <Arduino.h>
#include "SmsMenu.h"
#include "GsmModuleFunctions.h"
#include "GasSensorFunctions.h"
#include "AlarmFunctions.h"
/*-------------------- Defining Pins -------------------- */
/*------------------ Defining Constants ----------------- */
/*---------------------- Variables ---------------------- */
/*------------------ Functions' Scopes ------------------ */
  delay(100);
  Serial.begin(115200); //debug
  gsm_config();
  //gas_sensors_config();
  //sensors_reading();
  //check_alarm();
  sms_check();
This is the lib for GSM functions
/*-------------------------- Headers --------------------------*/
#define TINY_GSM_MODEM_SIM800
#include "TinyGsmClient.h"
/*---------------------- PINS to be used ----------------------*/
#define LED_GSM_INIT_STATUS 19
/*------------------------- Constants -------------------------*/
#define MAX_PHONES 5
/*---------------------- Functions Scope ----------------------*/
void sms_check();
void gsm_config();
String send_AT_command(String AT_command);
bool check_if_sms_received_sent(String *sms_received, String *sender_phone);
void check_sms_sender_phone(String sms_text_received, String *sms_sender_phone);
void check_sms_text(String *sms_text_received);
void execution(String command, String command_sender, int *index, int *list_index, String list[]);
void send_sms(String command_response, String command_sender);
/*------------------------- Variables -------------------------*/
TinyGsm gsm_modem(Serial2);
String sms_text = "";
String phone = "";
String phone_list[MAX_PHONES] = {"","","","",""};
int menu_index = 0;
int phone_list_index = 0;
void sms_check() {
  if(check_if_sms_received_sent(&sms_text, &phone))
    Serial.println("\nSMS Received...");
    Serial.println("\nSender: " + phone );
    Serial.println("Message:\n'" + sms_text + "'\n");
    execution(sms_text, phone, &menu_index, &phone_list_index, phone_list);
    Serial.println("Deleting all messages in memory.\n");
    gsm_module_response = send_AT_command("AT+CMGD=1,4");
    while(gsm_module_response.indexOf("OK") < 0)
      Serial.println("Could not delete the messages\n");
      delay(100);
    Serial.print("Module response:" + gsm_module_response);
    Serial.println("All messages deleted.\n");
void gsm_config()
  pinMode(LED_GSM_INIT_STATUS, OUTPUT);
  digitalWrite(LED_GSM_INIT_STATUS, LOW);
  Serial2.begin(9600);
  Serial.println("Start GSM module configuration...\n");
  gsm_module_response = send_AT_command("AT&F0");
  while(!gsm_modem.restart())
    Serial.println("\nWait the GSM modem to restart.");
    delay(100);
  Serial.println("\nGSM modem restart successfully!\n");
  Serial.println("Setting the baud rate.\n");
  gsm_module_response = send_AT_command("AT+IPR=9600");
    Serial.println("Cannot set the fixed baud rate at 9600.\n");
    delay(100);
  Serial.println("Baud rate set to 9600.\n");
  Serial.println("Selecting not to display URC for timestamp.\n");
  gsm_module_response = send_AT_command("AT+CLTS=0");
    Serial.println("Could not configurate to not display URC for timestamp.\n");
    delay(100);
  Serial.println("No URC for timestamp will be displayed.\n");
  Serial.println("Setting how new SMS will be indicated.\n");
  gsm_module_response = send_AT_command("AT+CNMI=2,0,0,0,0");
    Serial.println("Could not configure how new SMS indications will be indicated.\n");
    delay(100);
  Serial.println("New SMS indication configuration set.\n");
  Serial.println("Selecting SMS mode as Text Mode.\n");
  gsm_module_response = send_AT_command("AT+CMGF=1");
    Serial.println("Could not configurate to Text Mode.\n");
    delay(100);
  Serial.println("SMS text mode selected.\n");
    delay(100);
  Serial.println("GSM Module configuration finished");
  digitalWrite(LED_GSM_INIT_STATUS, HIGH);
      delay(100);
  delay(100);
bool check_if_sms_received_sent (String *sms_received, String *sender_phone)
  *sms_received = send_AT_command("AT+CMGL=\"ALL\""); //AT command syntax: "AT+CMGL=(stat)" -> stat = "ALL" -> list all messages
                                                      //returns "+CMTI: SM" if a SMS is arriving in the listing
  if((*sms_received).indexOf("+CMTI:\"SM\"") >= 0) //if a sms is arriving in the reading, do the listing again.
  /*if((*sms_received).indexOf("CMGS") >= 0)
  Serial.println(*sms_received);
  //Serial.println((*sms_received).length());
  if((*sms_received).indexOf("OK") >= 0)
    if((*sms_received).length() <= 6) //6
      Serial.println("No new messages to be read.\n");
      return false;
      Serial.println("Reading message.\n");
      check_sms_sender_phone(*sms_received, *&sender_phone);
      check_sms_text(*&sms_received);
      return true;
  Serial.println("Error with AT command... Could not check if it has SMS.\n");
  return false;
  String text_extracted = "";
  int i = 0;
  *sms_sender_phone = "";
  if(sms_text_received.indexOf("CMGL") >= 0)
    //SMS line example: +CMGL: 1,"REC UNREAD","+5518999999999","","18/11/30,11:36:14-08"
    text_extracted = sms_text_received.substring(sms_text_received.indexOf(",") + 1);
    text_extracted = text_extracted.substring(text_extracted.indexOf(",") + 2);
    for(i = 0; (i < text_extracted.length()) && (text_extracted.charAt(i) != '"'); i++)
      *sms_sender_phone = (*sms_sender_phone) + text_extracted.charAt(i);
  else if(sms_text_received.indexOf("CMT") >= 0)
    //SMS line example: +CMT: "+5541999999999","","21/09/12,14:35:24-12"
    text_extracted = sms_text_received.substring(sms_text_received.indexOf('"') + 1);
void check_sms_text (String *sms_text_received)
  int i = 0;
  if((*sms_text_received).indexOf("CMGL") >= 0)
    SMS received example syntax:
    [\n
    +CMGL: 1,"REC UNREAD","+5518999999999","","18/11/30,11:36:14-08"\n
    Hello\n
    \n
    OK\n
    *sms_text_received = (*sms_text_received).substring((*sms_text_received).indexOf("\n") + 1);
    text_extracted = *sms_text_received;
    *sms_text_received = "";
    for(i = 0; i < (text_extracted.length() - 8); i++)
      *sms_text_received = *sms_text_received + text_extracted.charAt(i);
  else if((*sms_text_received).indexOf("CMT") >= 0)
    [\n
    OK\n
    \n
    +CMT: "+5541984339642","","21/09/13,19:25:26-12"\n
    Testando\n
    \n
    for(i = 0; i <= (text_extracted.length() - 3); i++)
  String command_response = "";
  int i;
  command.toUpperCase();
  if((*index) == 0)
    if(command == "MENU")
      command_response = main_menu;
      //command_response = "Menu OK";
      //*index = 0;
    else if((command == "REGISTER") || (command == "1"))
      command_response = menu_opt_1;
      *index = 1;
    else if((command == "LIST") || (command == "2"))
      if((*list_index) == 0)
        command_response = menu_opt_22;
        command_response = menu_opt_2 + "\n";
        for(i = 0; i < (*list_index); i++)
          if(i == 0)
            command_response = command_response + (i + 1) + " - " + list[i] + "\n";
        Serial.println(command_response);
        //*index = 0;
    else if((command == "VSTATE") || (command == "3"))
      command_response = menu_opt_3;
      *index = 3;
    else if((command == "VCLOSE") || (command == "4"))
      command_response = menu_opt_4;
      *index = 4;
    else if((command == "ASTATE") || (command == "5"))
      command_response = menu_opt_5;
      *index = 5;
    else if((command == "ADEACTIVE") || (command == "6"))
      command_response = menu_opt_6;
      *index = 6;
    /*else if((command == "SVALUE") || (command == "7"))
      command_response = menu_opt_7;
      *index = 7;
    /*else if((command == "DELETE") || (command == "8"))
      command_response = menu_opt_8;
      *index = 8;
      command_response = not_valid;
  else if((*index) == 1)
    if(command.length() == 11)
      command_response = menu_opt_11 + "+55" + command;
      list[*list_index] = "+55" + command;
      Serial.print("List index: ");
      Serial.println(*list_index);
      *index = 11;
    else if(command == "0")
      command_response = menu_opt_11111;
      *index = 0;
      command_response = menu_opt_111;
      *index = 1;
  else if ((*index) == 11)
    if(command == "SIM")
      command_response = menu_opt_1111;
      (*list_index)++;
      /*Serial.print("List index: ");
      Serial.println(*list_index);*/
      *index = 0;
    else if(command == "NAO")
      list[*list_index] = "";
      *index = 1;
  send_sms(command_response, command_sender);
Menu Strings lib:
` String main_menu = "Menu \n 1 - Registrar Numero \n 2 - Listar Numeros \n 3 - Estado da Valvula \n 4 - Fechar Valvula \n 5 - Estado Alarme \n 6 - Desativar Alarme \n 7 - Valor dos Sensores \n 8 - Deletar Numero";
String not_valid = "Opcao desconhecida.";`
