USB and power adapter
hi, i'm able to get 4.47V from arduino output using my mac's USB port. is it possible to combine voltage from usb and the adapter if i require higher voltage?
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
Power
The Arduino Duemilanove can be powered via the USB connection or with an external power supply. The power source is selected automatically.
External (non-USB) power can come either from an AC-to-DC adapter (wall-wart) or battery. The adapter can be connected by plugging a 2.1mm center-positive plug into the board's power jack. Leads from a battery can be inserted in the Gnd and Vin pin headers of the POWER connector.
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
Yes but don't do it because if the USB gets unplugged then you loose the referance and earth points and you will damage something.
Have a look at this:- http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
