Hi, I have an Arduino Portenta Machine Controller, and after uploading a sketch, I lost the connection to it. Now, Windows gives me a warning that the device is faulty. I've tried different cables and PCs, but the Arduino still isn't recognized, and nothing changes in Device Manager. Any idea what might be wrong?
I am using Windows 10 and the progam is to interpet Gcode i sent from pythin through usb to the arduino.
I'm not familiar with the Portenta Machine Control. If it has a reset button, will tapping or double tapping result in reactions in Windows device manager?
i belive it is sth with the baut rate i for fun presst the reste button over and over again and it suddelnly popt up again an exaple code wokr with 9600 baut
@sim719
You might also want to just double check that your USB cable is firmly and solidly plugged in at both computer end and at Portenta end.
I had a similar issue working with my uno rev 3 and I discovered that my connection via usb plug to uno was almost fully plugged in! After unplugging and reconnecting the connection, my issue of identical misery went away! ![]()
