Hello,
I’m interested in creating following project.
I would like to monitor keyboard usage, if no key pressed for more than 60 minutes script should be executed.
I think biggest hurdle is monitoring usb keyboard.
I think Arduino + USB shield is the answer combined with this project
Any suggestions?
Would this project work with Uno R3?,
it specifies Leonardo only, I can’t seem to find USB Host Shield just clones, which I want to avoid.
Thank you
Can't you just monitor it in software on the host PC? Just a few lines in python could do the job.
Thank you, I would rather avoid doing that and keep it self contained but thank you
In that case, no that project is designed for a 32u4. It probably won't work for an 328P(Uno) without a ground-up rebuild.
system
Closed
5
