Hello everybody.
I assembled a Midi foot controller.
For those who do not understand, I will explain. I wanted to switch presets in Ableton live 11 by pressing a button.
The project was assembled on the basis of Arduino Leonardo.
Everything works great.
The problem is this: When you press the buttons, the signal can pass twice, as can be seen from the LED on the board, and accordingly turn off and on the assigned action.
The buttons are all instant, operational, and work perfectly.
Due to my illiteracy in development, I can assume that you need to reduce the sensitivity of the analog button.
Later I realized that there was no button bouncing in the code.
Help me add debounce switching to the code.
Link to the project source GitHub - hugbed/midi-controller: DIY midi controller (Arduino ATmega32U4)
Example:
Midi-controller with 10 inputs and a hardcoded intensity.
Modification: 29/10/2017
Description:
- Support 10 switches (Use uint16_t instead of uint8_t for flags).
- Hard-coded intensity
Author: Hugo Bédard
Original example:
This examples shows how to make a simple seven keys MIDI keyboard with volume control
Created: 4/10/2015
Author: Arturo Guadalupi <a.guadalupi@arduino.cc>
http://www.arduino.cc/en/Tutorial/MidiDevice
#include <MIDIUSB.h>
#include <pitchToFrequency.h>
#include <pitchToNote.h>
#define NUM_BUTTONS 10
const uint8_t button1 = 21;
const uint8_t button2 = 20;
const uint8_t button3 = 19;
const uint8_t button4 = 18;
const uint8_t button5 = 15;
const uint8_t button6 = 14;
const uint8_t button7 = 16;
const uint8_t button8 = 10;
const uint8_t button9 = 8;
const uint8_t button10 = 9;
const uint8_t buttons[NUM_BUTTONS] = {
button1,
button2,
button3,
button4,
button5,
button6,
button7,
button8,
button9,
button10
const byte notePitches[NUM_BUTTONS] = {
pitchC3,
pitchD3,
pitchE3,
pitchF3,
pitchG3,
pitchA3,
pitchB3,
pitchC4,
pitchD4,
pitchE4
uint16_t pressedButtons = 0x00;
uint16_t previousButtons = 0x00;
uint8_t intensity = 64;
for (int i = 0; i < NUM_BUTTONS; i++)
pinMode(buttons[i], INPUT);
readButtons();
playNotes();
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
void readButtons()
if (digitalRead(buttons[i]) == LOW)
bitWrite(pressedButtons, i, 1);
delay(50);
bitWrite(pressedButtons, i, 0);
void playNotes()
if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))
if (bitRead(pressedButtons, i))
bitWrite(previousButtons, i , 1);
noteOn(0, notePitches[i], intensity);
MidiUSB.flush();
bitWrite(previousButtons, i , 0);
noteOff(0, notePitches[i], 0);
MidiUSB.flush();
// First parameter is the event type (0x09 = note on, 0x08 = note off).
// Second parameter is note-on/note-off, combined with the channel.
// Channel can be anything between 0-15. Typically reported to the user as 1-16.
// Third parameter is the note number (48 = middle C).
// Fourth parameter is the velocity (64 = normal, 127 = fastest).
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
