Hi guys, I'm doing a project in graduate school which uses AD converting and get analog signals with BNC Cables. I'm going to save data to the computer as text files. Actually, analog signals are neural signals(which is voltage up to 300 micro V)
Problem 1.
As I cut the BNC cable, there are two cables, red and black.
Where should I connect these cables to get analog signals in teensy board?
Problem 2.
After getting the analog signal, how do I write that data? measure frequency is 50k Hz.
I'd normally expect BNC connections to be coaxial - a core and a shield, so I'm a bit confused by your description. Maybe post a photo?
In any case, you won't be able to connect the wires directly, because your 300µV signal will be too tiny for the teensy to detect.
The Teensy has (I think) 10 bit ADCs so it can differentiate 1024 analogue levels.
Even with the minimum allowable external reference voltage (it's about 1 volt I think) the smallest voltage the ADCs can detect is approx 1mV (3 x larger than your max signal).
This means you'll need an analogue signal amplifier to bring your tiny signals into the teensy's workable range.
Hello Everyone! I know it's been a long time but I need help with the same topic
HSpark, did you find a solution connecting the BNC plug to the Teensy's ADC ?
Thanks
