use (if) cases when LED is high/ LOW
I want a certain thing to happen but only when the LED is HIGH. How do I do this with an if case? Because I can't get it to work in my main code.
int LED = 3;
int LED2 = 4;
void setup(){
 pinMode(LED, OUTPUT);
 pinMode(LED2, OUTPUT);
void loop(){
 digitalWrite(LED, HIGH);
 if(LED, HIGH){
  digitalWrite(LED2, HIGH);
 else{
  delay(5000);
  digitalWrite(LED, LOW);
const byte pinOfYourLed = 3;
if (digitalRead(pinOfYourLed) == HIGH) {
 // it's HIGH
  // it's not HIGH (probably LOW)
J-M-L:
// it's HIGH
Okay I'll try this out! Thank you for the quick help!
 if(LED, HIGH){
You've just set it HIGH - why would you want to test it (badly) to see if it is HIGH?
TheMemberFormerlyKnownAsAWOL:
Доверяй, но проверяй. (trust but verify :slight_smile: :grin: )
J-M-L:
But can you really trust digitalRead() ?
that's a good question indeed!
rico459:
int LED = 3;
int LED2 = 4;
void setup(){
void loop(){
if(LED, HIGH){
else{
 delay(5000);
@rico459
your above code doesn't make any sense.
you turn LED on, and you test it if it is ON, which will always be true. (the else statement will never execute).
