Hello,
I am trying to use a Firmata protocol to communicate with my PLC (M-duino 57R+).
I am trying to link Arduino, Python and LabVIEW with different libraries and I have been able to make it work on an Arduino Uno.
I just received my PLC and I just want to launch the StandardFirmata (File>Examples>Firmata>StandardFirmata) code in Arduino, but I got an error:
Arduino: 1.8.19 (Windows 10), Board: "M-Duino family, M-Duino 57R+"
C:\Program Files (x86)\Arduino\libraries\Firmata\utility\SerialFirmata.cpp: In member function 'Stream* SerialFirmata::getPortFromId(byte)':
C:\Program Files (x86)\Arduino\libraries\Firmata\utility\SerialFirmata.cpp:249:15: error: 'Serial2' was not declared in this scope
return &Serial2;
C:\Program Files (x86)\Arduino\libraries\Firmata\utility\SerialFirmata.cpp:249:15: note: suggested alternative: 'Serial1'
return &Serial2;
Serial1
C:\Program Files (x86)\Arduino\libraries\Firmata\utility\SerialFirmata.cpp:253:15: error: 'Serial3' was not declared in this scope
return &Serial3;
C:\Program Files (x86)\Arduino\libraries\Firmata\utility\SerialFirmata.cpp:253:15: note: suggested alternative: 'Serial1'
return &Serial3;
Serial1
exit status 1
Error compiling for board M-Duino family.
option enabled in File -> Preferences.
As of now, I have been able to get analog data from a potentiometer with a serial communication thanks to the code below:
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(I0_2);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
delay(100);
By the way, I am using Arduino 1.8.19 and I use the M-duino family board on COM4. I also tried on my work pc and personal pc to see if it was a firewall issue and I get the same error.
Thank you for your help
