Up until now I only made some simple example projects and a robot.
For my first "real" project I would need 2 lcd modules 20x4 characters.
A lcd module that would match my needs would be the sainsmart 20x4 I2C lcd module. The specs mention "I2C Address: 0x3F or 0x27". So, is the adress changable of do you have one or the other? If I buy 2 of these, can I allways use both of them?
Other brands also mentioned these I2C adresses or mentione only one of them.
So what if I would like to use 4 of these LCD modules?
The address is usually set with solder bridges on the I2C backpack (small board on the back of the LCD).
Sainsmart doesn't give any info there. It seems that the bridges are on the back if the backpack (see pictures).
Another option (if you can't change the address) is to use an 8-channel I2C muxer (Adafruit).
Leo..
andyr74:
I am not familiar with the Sainsmart module.
Have you asked Sainsmart about this, they sold you the display, they ought to be the ones providing you with support ?
Indeed, probably selectable through solder bridge, address select pin (tie to Vcc or GND to select the address), or even an on-board jumper. Check the data sheet on your specific device.
I didn't buy a module yet. I'm still in process of thinking everything out.
I would like to start with 2 lcd modules and maybe later when required expand to 4.
I don't see any user accessable solder pads on the Sainsmart backpack.
Setting the address could involve scratching off the protective paint and re-routing traces.
Leo..
Wawa:
Leo..
For the sunfounder LCD module, I see (under the blue backlight regulator) 2 x 3 "solder holes" which should set the adress.
Can I just solder the holes togheter or should I use some wire to connect both?
