Using a 2D array properly
I have a big program I'm slightly adapting from someone else, so I won't post it all here, but I can show what my issue is.
I initialize a 2D array like this:
double Steps[][5] =  {
                        {1,3.555,1,1,76},
                        {2,3.675,0,1,76},
                        {3,7,0,0,0},
                        {4,2.755,1,1,83},
                        {5,2.295,1,0,83},
                        {6,2.875,0,0,83},
                        {7,2.295,0,1,83},
                        {8,1.410,0,1,90},
                        {9,1.410,1,1,90}
If I then do this:
Serial.println(Steps[0,0]);
Serial.println(Steps[0,1]);
Serial.println(Steps[0,2]);
Serial.println(Steps[0,3]);
Serial.println(Steps[0,4]);
it won't compile and gives the below error:
error: no matching function for call to 'println(double [5])'
If I do this:
Serial.println(*Steps[0,0]);
Serial.println(*Steps[0,1]);
Serial.println(*Steps[0,2]);
Serial.println(*Steps[0,3]);
Serial.println(*Steps[0,4]);
It compiles and prints
1.0
2.0
3.0
4.0
5.0
Which I can only assume is related to the array position in some way.
I have read up on pointer, arrays, referencing and dereferencing, but I still don't follow why this does what it does.
Can someone point me in the right direction here?
Thanks
I believe 2D arrays are read as arrayName [0][0], not arranyName[0,0]
uuggg, thank you. I've been staring at it for a day ands somehow didn't see that!!
To explain why this works in the second case, Steps[0,1] for example is seen by c++ as Steps[1], so println receives array of 5 doubles for which it has no overload. By dereferencing it *Steps[0,1] you get 1st element of Steps[1] which is 2 in this case, and since it is just a single double, println can print it.
