Hello! I am new to Arduino, and I am trying to program an easy countdown timer for a board game. I want this countdown to be immediately restarted every time someone presses a button (getting a new fresh time for every player's move).
To that end I am using an Octopus Segment LED Brick to display the numbers, and a simple switch button that should interrupt the main loop (the countdown) and set it back again to its first value.
So my question is - how should this re-starting function look like? I read somewhere that I should use return for that, but I don't know how to write it and only get error messages.
Just one warning before pasting here my project:
Since I am not familiar with Arduino's syntax I don't know - and couldn't find - how to trigger this very display (that runs over I2C) with millis(), so I ended up just writing the numbers to be displayed and separated them with 1sec delays. That's why it looks so seedy in the countdown section.
A second question regarding this would be: is it possible to jump back to a certain point of the loop and start over from that position? I could use this to eventually change the duration of the game; i.e. restart the loop at 00:59 instead of at 01:30, and so on and so forth.
Here's my code:
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment();
const int buttonPin = 2; // the number of the button pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the button status
int interrupcion = 0; // variable for interruption
pinMode (ledPin, OUTPUT);
pinMode (buttonPin, INPUT);
attachInterrupt(interrupcion, funcionRestart, CHANGE);
matrix.begin(0x70); // starts the LED display's matrix
int pulsador = digitalRead( buttonPin ); // "pulsador" is buttonPin
while( pulsador == HIGH )
matrix.writeDigitNum(0, 0); // 01:30
matrix.writeDigitNum(1, 1);
matrix.drawColon(true);
matrix.writeDigitNum(3, 3);
matrix.writeDigitNum(4, 0);
matrix.writeDisplay();
matrix.writeDigitNum(0, 0); // 01:29
matrix.writeDigitNum(3, 2);
matrix.writeDigitNum(4, 9);
matrix.writeDigitNum(0, 0); // 01:28
matrix.writeDigitNum(4, 8);
matrix.writeDigitNum(0, 0); // 01:27
matrix.writeDigitNum(4, 7);
matrix.writeDigitNum(0, 0); // 01:26
matrix.writeDigitNum(4, 6);
matrix.writeDigitNum(0, 0); // 01:25
matrix.writeDigitNum(4, 5);
matrix.writeDigitNum(0, 0); // 01:24
matrix.writeDigitNum(4, 4);
matrix.writeDigitNum(0, 0); // 01:23
matrix.writeDigitNum(4, 3);
matrix.writeDigitNum(0, 0); // 01:22
matrix.writeDigitNum(4, 2);
matrix.writeDigitNum(0, 0); // 01:21
matrix.writeDigitNum(4, 1);
matrix.writeDigitNum(0, 0); // 01:20
matrix.clear(); // in order to try it out, the countdown is only set to 10 sec. There's no final position (00:00) yet.
pulsador = digitalRead( buttonPin);
void funcionRestart() { // lights up the LED any time a change in the button is performed. This function should cause the loop to restart.
digitalWrite(ledPin, HIGH);
delay(10000);
digitalWrite(ledPin, LOW);
Thank in advance for any possible help!
