Using a Laptop Bluetooth Module with Arduino
Hello everyone, I am planning to build a rc car using an arduino uno r3 board, ESC, and a bluetooth module. I plan to control the car using an android phone. I am able to buy all the parts at a reasonable price except the bluetooth module.
I found a bluetooth module that a salvaged from an old Toshiba laptop, and I was just wondering if it is compatible with the arduino. I searched around for some time, but was unable to find info about this. The module is : Toshiba PA3750U - 1BTM G86C0002X710. If it turns out that it's incompatible, what else could I use as cheap bluetooth module for my arduino project?
Thanks in advance!
nabilkabour:
Probably because you haven't been looking very hard
http://es.aliexpress.com/store/product/HC05-HC-05-master-slave-6pin-JY-MCU-anti-reverse-integrated-Bluetooth-serial-pass-through-module/1185416_1738587842.html
You may be interested in this RemoteXY thread.
HC05 / HC06 bluetooth modules are not expensive.
...R
You probably know that it will only work on a max 10m radius (from your phone).
