i'm usine a photo cell to turn a relay on for 1 second the value i'm using is 100 so when the value gets to 100 the relay turns on for a second. The problem is that it fluctuates around 100 for a couple minutes so that relay goes on and off how do i prevent that in that sketch
turn it on when it get to 100
turn it off when it drops to a number well below 100, like 90
creating a 'dead band'
It? What is it?
Add a servo with a big hammer attached. Position the servo so that the hammer whacks the photo cell. Stop any nonsense it's putting out permanently.
Or post your code, damn it.
OK then I like the hammer idea
Im using the relay to control the dead bolt in my front door to lock it at dusk. Using serial monitor I chose the value of 100. When I ran my sketch I could hear my dead bolt trying to lock every few seconds for a few min. The photo cells value goes up and down for a few min like 100 then 99 then 101 then 100 then 98. So every time it gets to 100 the relay #2 operates
There are other things in my code but Im only having trouble with the photocell
// Push Buttons for Relay Number 1 -----> Pin 10
// Push Buttons for Relay Number 3 -----> Pin 11
// Push Buttons for Relay Number 4 -----> Pin 12
// Photo Cell ----> Pin A0
//Relay Number 1 -----> Pin 6
//Relay Number 2 -----> Pin 7
//Relay Number 3 -----> Pin 8
//Relay Number 4 -----> Pin 9
//RFID Connection:
//ENABLE -----> Pin 2
//RFID TX ---- Pin RX
//VCC ----> 5v
//GND -----> Arduino GND
//Constants
#define NumberOfIDs 20 //This defines the amount of IDs in the access list
#define ON_TIME 1000 //time in milliseconds the relay #1 stays energized
#define ON_TIME_2 1000 //time in milliseconds the relay #2 stays energized
#define ON_TIME_3 1000 //time in milliseconds the relay #3 stays energized
#define ON_TIME_4 1000 //time in milliseconds the relay #4 stays energized
#define Relay2_operateValue 100
//External Equipment
#define ENABLE 2 //Pin connected to the Enable pin of RFID
#define RELAY1 6 //Pin that is connected to the relay #1
#define RELAY2 7 //Pin that is connected to the relay #2
#define RELAY3 8 //Pin that is connected to the relay #3
#define RELAY4 9 //Pin that is connected to the relay #4
#define RELAY1_PUSH_BUTTON 10
#define RELAY3_PUSH_BUTTON 11
#define RELAY4_PUSH_BUTTON 12
//Analog Input
#define PHOTO_CELL A0
int val = 0;
int bytesread = 0;
String IDCode;
String accessList[NumberOfIDs]={"120075A418","12007389DA","690008BB23","6900076031","11003163FE","430051E429","0F032BBBD8","0F032BBA53"}; // !!!! HERE YOU WILL ADD THE IDs !!!!!
char code[10];
boolean IDFound,photoCellstate= false;
int button1State,button3State,button4State =0; // variable for reading the pushbutton status
int photoCellValue=1023;
pinMode(ENABLE,OUTPUT);
pinMode(RELAY1,OUTPUT);
pinMode(RELAY2,OUTPUT);
pinMode(RELAY3,OUTPUT);
pinMode(RELAY4,OUTPUT);
pinMode(RELAY1_PUSH_BUTTON, INPUT);
pinMode(RELAY3_PUSH_BUTTON, INPUT);
pinMode(RELAY4_PUSH_BUTTON, INPUT);
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
digitalWrite(ENABLE, LOW); // LOW Activates the RFID reader, HIGH deactivates it
digitalWrite(RELAY1,LOW);
digitalWrite(RELAY2,LOW);
digitalWrite(RELAY3,LOW);
digitalWrite(RELAY4,LOW);
// read the state of the pushbutton value:
button1State = digitalRead(RELAY1_PUSH_BUTTON);
button3State = digitalRead(RELAY3_PUSH_BUTTON);
button4State = digitalRead(RELAY4_PUSH_BUTTON);
photoCellValue = analogRead(PHOTO_CELL);
/**** EXTRACTION OF DATA FROM CARD ****/
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header [Header of data = 10]
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
IDCode = code;
IDCode = IDCode.substring(0,10);
bytesread = 0;
digitalWrite(ENABLE, HIGH); // deactivate the RFID reader for a moment so it will not flood
/*** INTERPRETATION OF DATA ***/
//At this point, data was read, and there is a IDcode in the IDCode variable
for(int i = 0;i<NumberOfIDs;i++) //check entered ID against saved IDs
if(IDCode.equals(accessList[i])){
IDFound = true;} //if the ID is in the access list, IDFound = true;
if(IDFound)
// energize Relay 1:
digitalWrite(RELAY1,HIGH); //energize the relay 1
delay(ON_TIME); //Relay stays energized for ON_TIME milliseconds
digitalWrite(RELAY1,LOW); //Immediately after delay, de-energize relay.
IDFound = false;
else{
} //end of data reading
delay(4000); // wait for a bit
// check if the push buttons are pressed.
// if it is, the button State is HIGH:
/***Relay Number 1 control ***/
if (button1State == HIGH) {
digitalWrite(RELAY1,HIGH);//energize the relay 1
else {
// de-energize Relay 1:
digitalWrite(RELAY1, LOW);
/***Relay Number 2 control ***/
if ((photoCellValue < Relay2_operateValue) && (photoCellstate==false)) {
// energize Relay 2:
digitalWrite(RELAY2,HIGH);//energize the relay 2
delay(ON_TIME_2); //Relay 2 stays energized for ON_TIME_2 milliseconds
digitalWrite(RELAY2,LOW); //Immediately after delay, de-energize relay.
photoCellstate=true;
if (photoCellValue > 400) {
// de-energize Relay 2:
photoCellstate=false;
/***Relay Number 3 control ***/
if (button3State == HIGH) {
// energize Relay 3:
digitalWrite(RELAY3,HIGH);//energize the relay 3
delay(ON_TIME_3); //Relay 3 stays energized for ON_TIME_3 milliseconds
digitalWrite(RELAY3,LOW); //Immediately after delay, de-energize relay.
else {
// de-energize Relay 3:
digitalWrite(RELAY3, LOW);
/***Relay Number 4 control ***/
if (button4State == HIGH) {
// energize Relay 4:
digitalWrite(RELAY4,HIGH);//energize the relay 4
delay(ON_TIME_4); //Relay 4 stays energized for ON_TIME_4 milliseconds
digitalWrite(RELAY4,LOW); //Immediately after delay, de-energize relay.
else {
// de-energize Relay 4:
digitalWrite(RELAY4, LOW);
Google "hysteresis"
As well as code to turn the relay on for just 1 second you need code that doesn't read the photocell again for a suitable time - perhaps 30 minutes.
...R
I have a delay at the end of the read should I increase that for 30 min
Trickyrick:
It's hard to follow your code. I don't see where the photocell is read. (A function called readPhotocell() would be nice and obvious).
I just meant there is no point reading the photocell if the lock is shut and you don't want to open it again immediately. You will have to figure out a suitable time interval yourself.
...R
