Using an Arduino + transistor to control current flow
Hi guys,
I'm fairly new to all this. The project I'm working on relies on an Arduino to power on and off a transistor, and therefor control the flow of another circuit. However, I don't think that transistors are my best bet for this, as they require the same ground + VCC. What could I use for this? Thanks!
Circuit diagram:
I think they are your only bet, unless you want to use a relay.
At what voltage is the current source you want to control?
That circuit is wrong in any case. You want to control it with an Arduino pin, no?
Use a relay or Opto FET, H11F1M/H11F2M/H11F3M
https://www.mouser.com/datasheet/2/149/H11F3M-189245.pdf
Yep, use an opto.
Thanks for the responses, everyone.
I did some research on the opto fets you mentioned; would this work in my circuit?
Also, I didn't mean to put "VCC" on my original post; I meant to put "Arduino pin" instead.
Thanks in advance.
You will need to limit the LED current with a ~220R resistor.
What is the source of your signal and what are you driving ?
An H11F3M has an on resistance of ~450Ω so your load needs to be Hi Z.
An H11F1M is ~200Ω
