Hey
Sorry guys. I never received a topic reply for some reason even though I selected to be notified.
Heres what I am trying for and what I have found so far.
I have used the below code to get the analog values from my lcd shield
Mark Bramwell, July 2010
This program will test the LCD panel and the buttons.When you push the button on the shield?
the screen will show the corresponding one.
Connection: Plug the LCD Keypad to the UNO(or other controllers)
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int a=0;
int bkl = 6;
byte bklIdle = 10;
byte bklOn = 100;
int bklDelay = 10000;
unsigned long bklTime = 0;
pinMode(bkl, OUTPUT);
digitalWrite(bkl, HIGH);
lcd.begin(16, 2);
pinMode(A0, INPUT);
a = analogRead(0);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" analogRead() ");
lcd.setCursor(0,1);
lcd.print(" value is :");
lcd.print(a);
delay(250);
I then used the following code and modified the values to match my analog values on this line "int adc_key_val[5] ={0, 99, 257, 409, 643 };"
It works well but for some reason I could never get the select key to register
char msgs[5][16] = {"Select Key OK ",
"Right Key OK ",
"Up Key OK ",
"Down Key OK ",
"Left Key OK" };
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
pinMode(A1, OUTPUT); // analog 1 to digital 15
digitalWrite(A1, HIGH);
pinMode(A2, OUTPUT); // analog 2 to digital 16
digitalWrite(A2, HIGH);
pinMode(A3, OUTPUT); // analog 3 to digital 17
digitalWrite(A3, HIGH);
pinMode(A4, OUTPUT); // analog 4 to digital 18
digitalWrite(A4, HIGH);
lcd.clear();
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.print("ADC key testing");
adc_key_in = analogRead(0); // read the value from the sensor
key = get_key(adc_key_in); // convert into key press
if (key != oldkey) // if keypress is detected
delay(50); // wait for debounce time
if (key != oldkey)
lcd.setCursor(0, 1);
oldkey = key;
if (key >=0){
lcd.print(msgs[key]);
delay(100);
// Convert ADC value to key number
int get_key(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)k = -1; // No valid key pressed
return k;
The following is the code I am trying to use but with ADC buttons on the shield instead of a dedicated board
