I want to use an Arduino nano to control the on/off status of the electromagnet, but right now I have no idea what steps should I do and other components that I need. so could someone help me, please!!
After looking through some posts, I am going to use MOSFETS as the switch to control the electromagnet on/off. However, I have no clue how to use this, someone can give me some clues please!!
Give us a link to the electromagnetic.
You would replace the motor with your electromagnetic in these circuits:
MOSFETs I have used with the Arduino:
https://forum.arduino.cc/index.php?action=dlattach;topic=445951.0;attach=373590
Thanks so much for your quick response!!
The electromagnet I am using is uxcell 5V 50N Electric Lifting Magnet Electromagnet Solenoid Lift Holding. I bought it from Amazon.
I am sorry, I do not understand what these circuits mean, so I need to choose one of them to apply to my board connection?
Circuit C1 should work for you.
Use an external 5v power supply to power the magnet; make sure you have a common ground to the Arduino.
What is the resistance of the magnet’s coil ?
TECHNICAL DETAILS
Nominal Voltage: 5V DC
Current Draw: 0.3 Amps at 5V
Holding Force: 5 Kg / 11 lb
Diameter: 25mm / ~0.8"
Center Diameter: 12mm / ~0.5"
Height: 20mm / ~0.8"
Lead Length: 280mm / ~11"
“ Electric time:Less than 7 minutes ;”
300mA is not that much current so most MOSFETs will work.
really appreciate your help!!!
actually, I am using Bluetooth module to connect with the Arduino nano, so I am wondering is that similar to control the LED status? to use high/low potential to control the D3 and other ports?
In circuit C1, a HIGH to the Gate turns on the MOSFET, the magnet would then be energized.
A LOW to the Gate turns the MOSFET off, the magnet would be de-energized.
Thank you so much for your help!!!!!
Really appreciate it!
I would say you need two things.
The first is one of these ready-made modules which makes the assembly a lot easier:
Aliexpress example
The second is a diode placed across the electromagnet according to the circuit pointed out previously. Unless you are using PWM, an ordinary 1N4001 (or 1N4004, 1N4007 etc) or equivalent will do just fine. ![]()
Thank you very much for your advice!!
I would suggest you to go with FETs i.e. 75N75, thaat way you can control ON//OFF and can also generate the PWM pulse, although it will involve soldering. IF you are not gud with electronics then go for above mentioned module.
