Using Arduino PID library - Reseting integrals
Hello
I'm using the PID library found here: Arduino Playground - PIDLibrary
Is there some way to easily reset the integrals when using this library?
Can you please provide an example of what you want to do ?
Christoffer:
You can use this trick to force both Output and ITerm (the integral term) to 0.0:
PID.SetOutputLimits(0.0, 1.0);  // Forces minimum up to 0.0
PID.SetOutputLimits(-1.0, 0.0);  // Forces maximum down to 0.0
PID.SetOutputLimits(PIDMinimum, PIDMaximum);  // Set the limits back to normal
You have to do it in two steps because if Min >= Max the call does nothing. This trick only works in AUTOMATIC mode.
Since you have the source code you could always add a method to reset ITerm. Typically you would set it to the latest Output value.
johnwasser:
Nice!
That's just what I need, thanks for the help :slight_smile:
Old thread, but similar challenge. I took this approach, does it seem acceptable?
myPID_R.SetMode(MANUAL);
OutputR = 0;
myPID_R.SetMode(AUTOMATIC);
