I'm trying to replace the InvenSense MPU-6050 sensor on an existing board with an Arduino Mega 2560, in order to simulate the outputs of the sensor artificially. I have desoldered the MPU, and set up the Arduino as a slave with the same address as the MPU (0x68) on the I2C bus.
First I need to figure out which data does the host MCU ask for, so I uploaded this code to the Arduino to echo the I2C data in the serial monitor:
#include <Wire.h>
Wire.begin(0x68);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
Serial.begin(9600); // start serial for output
void receiveEvent(int howMany) {
Serial.println("Receive Event");
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
void requestEvent(){
Serial.println("Request Event");
When I run the code, it gets stuck in the requestEvent() function, which means that the host MCU keeps asking for some data without writing anything first. As far as I know, the address of the desired register needs to be written first. Does the MPU send anything upon startup?
Thanks
