Hi! I have an AVR Dragon that I want to use as an ISP. I've hooked it up to an Arduino Uno, added the AVR Dragon to the programmers.txt list. I'm using a Mac by the way...
dragonisp.name=Dragon ISP
dragonisp.communication=usb
dragonisp.protocol=dragon_isp
dragonisp.program.protocol=dragon_isp
dragonisp.program.tool=avrdude
dragonisp.program.extra_params= -P usb
When I hit "burn bootloader" the AVR Dragon are flashing a few seconds before i get this error in Arduino IDE:
avrdude: usbdev_open(): did not find any USB device "usb"
Error while burning bootloader.
The weird thing is that the AVR dragon works fine in the Avrdude command line (v 5.11.1)!
sending this command:
avrdude -c dragon_isp -P usb -p atmega328p -U flash:w:main.hex:i
gives no error message, and the program are running on the mega328p (it blinks some LEDs)
How can I get the AVR dragon to work with Arduino IDE (1.6.5)?
I tried to add the extra parameters. Now I get a content mismatch error. The microcontroller is not dead, I'm still able to upload code with the Dragon. Is this the error you mentioned in the other post?
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega16 -cdragon_isp -Pusb -Uflash:w:/Users/hansi/Documents/Arduino/hardware/DIP-40/avr/bootloaders/optiboot/atmega16/optiboot_atmega16_16MHz_external.hex:i -Ulock:w:0x0f:m -e -Ulock:w:0x3f:m -Uhfuse:w:0xdc:m -Ulfuse:w:0xbf:m
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/hansi/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : dragon_isp
avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A200000F1A
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 255
firmware version: 1.00
hardware version: 1
S_MCU:
firmware version: 1.02
hardware version: 2
Serial number: 00:a2:00:00:0f:1a
Device ID: AVRDRAGON
AVR Part : ATmega16
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 10 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
Programmer Type : DRAGON_ISP
Description : Atmel AVR Dragon in ISP mode
Vtarget : 4.9 V
SCK period : 1.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.15s
avrdude: Device signature = 0x1e9403
avrdude: erasing chip
avrdude: reading input file "/Users/hansi/Documents/Arduino/hardware/DIP-40/avr/bootloaders/optiboot/atmega16/optiboot_atmega16_16MHz_external.hex"
avrdude: writing flash (16384 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 16384 bytes of flash written
avrdude: verifying flash memory against /Users/hansi/Documents/Arduino/hardware/DIP-40/avr/bootloaders/optiboot/atmega16/optiboot_atmega16_16MHz_external.hex:
avrdude: load data flash data from input file /Users/hansi/Documents/Arduino/hardware/DIP-40/avr/bootloaders/optiboot/atmega16/optiboot_atmega16_16MHz_external.hex:
avrdude: input file /Users/hansi/Documents/Arduino/hardware/DIP-40/avr/bootloaders/optiboot/atmega16/optiboot_atmega16_16MHz_external.hex contains 16384 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 16384 bytes of flash verified
avrdude: reading input file "0x0f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.15s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0f:
avrdude: load data lock data from input file 0x0f:
avrdude: input file 0x0f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.06s
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x3f"
Writing | ***failed;
################################################## | 100% 0.40s
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
Reading | ################################################## | 100% 0.05s
avrdude: verification error, first mismatch at byte 0x0000
0x0f != 0x3f
avrdude: verification error; content mismatch
avrdude done. Thank you.
hansibull:
No, when I use the dmjlambert workaround with my mkII(or any of the other programmer I tested it with, but I don't have a dragon) I don't get any error at all, it works fine. With my workaround I still get the avrdude: usbdev_open(): did not find any USB device "usb" error but that's the only one. Your dragon is now successfully erasing, writing the bootloader and the lock_bits but then it fails on writing the unlock_bits. Does this happen every time you try?
I suggest just use the IDE to burn the bootloader. If in preferences you turn on show verbose output during upload, you will see the 2 avrdude commands it tries to run. The first one it runs ok and the second one does not work. Paste the 2nd one onto the command line to finish the job. Then call it good.
Need to hear from pert on that, I don't know what sort of workaround you attempted to put in place. The IDE normally uses 2 avrdude commands to do burn bootloader. You would have to get it back into that normal state. Then just run the second command on the command line after using the IDE to attempt a burn bootloader.
Of course, it was the extra parameters in the programmers.txt file. Now I got two commands. The second command runs without any errors with avrdude.
So, I'm able to burn bootloader using the AVR dragon, but I need to use Avrdude externally to to the upload. Will there be a fix for the Arduino IDE, so these problems doesn't happend with the AVR dragon and the AVRISP MKII? I tested the latest hourly IDE build. it got the same Avrdude version as IDE 1.6.5
dmjlambert:
setting the lock bits then a -e to erase the chip, then setting the lock bits again. And before all that writing the flash. Looks weird to me.
I think avrdude is smart enough to do things in the right order even if the parameters are out of order. If you look at the output it is doing the erase first so it gets that right. I don't know what order the flash/lock bits and fuses are supposed to be done in but it works for me fine using every programmer I own.
I took a look at the avrdude command and found some issues that I think are causing hansibull's problem:
hansibull:
-patmega16
Are you burning the bootloader on an ATmega328P? If so it should be -patmega328p instead of -patmega16.
Ok, looks like you used my workaround, not djmlambert's. If you want my assistance it would be helpful if you actually would answer my questions.
Why did you comment out the program.tool line?
Can you find the programmers.txt file that is associated with the board you're trying to burn the bootloader to? Please paste the tools.avrdude.erase.pattern line. It looks like the efuse parameter is missing from yours. It should be:
hansibull:
Simple answer is you have to fix avrdude or patch something else to work around the avrdude issue.
If you read the links to the open issues, you will see that I've been trying to get this fixed for 6+ years.
If you are not using windows, you can create a simple (1 line) wrapper script that adds a blind delay of a couple of seconds before executing avrdude.
That is probably one of the easiest work arounds that "just works".
The real issue is not that the dragon doesn't work with the IDE. It is an avrdude issue that crops up based on the way the IDE is using avrdude and the code in avrdude along with the dragon being very slow to power-up and initialize the USB with the PC host.
When not burning a bootloader it will work just fine with the IDE.
The problem is triggered from a combination of the IDE is using separate commands to set the fuses and burn the bootloader, avrdude screwing up the USB bus when it exits, and the dragon being slow to reconnect to the PC host after the USB is reset. As a result, when the second avrdude command is run, the dragon has not re-enumerated with the PC host yet and so avrdude does not see it. This is an avrdude problem and that is where it needs to be fixed.
It is a 6 line change to fix it in avrdude.
Also you might want to know that avrdude is not using the best communication method when talking to the Dragon.
It uses some low level ways of communicating, so as a result, it is not as fast at doing things as a cheap ISP programmer.
An under $10 USBasp will program bootloaders faster than the dragon.
While I have the dragon working for me since I have installed a programmer type for it that works across all my installed IDE versions (I have 19+ versions of the Arduino IDE installed) and I'm using a patched version of avrdude that has the back to back command issue fixed, I don't even bother to use my dragon for burning bootloaders anymore since my cheap USBasp device will burn a bootloader in under 2 seconds and it is supported "out of the box" by the IDE.
The only time I use the Dragon is if I want to do source level debugging or programming using debugwire.
