I need to use a constant in my code which in some cases, e.g. for some boards, will not be declared. How can I do this without getting a compiler error?
Context: Assume I want to convert an ESP32's physical touch pin number (e.g. pin 32) to the "human readable" touch pin index number (e.g. 9 for touch9) with the function
int touchPinToIndex(int pin);
Of course, I'll need to use the constants defined in the ESP32's pins_arduino.h for that:
Implementation is straightforward, e.g. with an array {T0, T1, T2, T3, T4, T5, T6, T7, T8, T9}, where I can look up the pin number, or with a long switch statement.
Now here's the part I'm struggling with: Not all ESP32 boards use all 10 available touch pins. The const declarations for the d-duino-32, for example, stop at T6, as this board only has seven touch pins available.
As a consequence, the above implementations will not compile, because T7...T9 are not declared.
Is there an easy way to work around this that I'm not seeing? Something like the preprocessor's #ifdef for constants?
This is precisely what #ifdef is used for - but you need to know which #define's are pertinent to the boards in question as the preprocessor only knows about preprocessor things, not const definitions.
You mean #ifdef arduino_board_d-duino-32 or whatever the correct macro name is for identifying boards?
This would be neither a simple nor a safe solution, as it would only safeguard against existing boards, not against boards added to the core in the future.
switch (pin) {
case (T0): {
result = 0;
#ifndef arduino_board_d-duino-32 // or whatever the correct macro is called
case (T7): {
result = 7;
case (T8): {
result = 8;
case (T9): {
result = 9;
#endif
First, I'd have to check all existing pin_arduino.h to see what other boards don't use all 10 pins, and second this would only work for existing boards.
Yes, it's funny that the accepted good practice today is to use consts, not #defines, yet in this specific case it would have made things easier. Not that it's an argument for #defines, but noteworthy nevertheless.
However, it is only a solution for this specific case.
I'd still be interested if there's a way around the general problem, which I think could come up in other constellations as well, particularly as today's above mentioned good practice is to give up on macro defines in favor of const declarations.
From the discussion up to now I take it that there simply is no easy answer to my initial question, though, but maybe there's still other thoughts.
