Using data from Wire library in other functions
I am currently receiving data from another Arduino via I2C/Wire library and I would like to use the received data in a different function. (a function to transmit the bytes I receive via LoRa)
void receiveEvent() {
    byte x = Wire.read();
    Serial.print(char(x));
How can I access byte x from this function? I have already tried to use byte as a return type, but since I have declared:
    Wire.begin(8);        // join i2c bus
    Wire.onReceive(receiveEvent);
I don't get the value I want to see.
Something like below might do the job.
byte x;
bool I2Cready;
  if(I2Cready == true)
    Serial.print(char(x)); // print char
    I2Cready = false;
void receiveEvent()
  x = Wire.read();    // receive byte
  I2Cready = true;
Don't use single letter global variables. Instead of x, use e.g. receivedI2Cdata.
I'm not sure if the variables in receiveEvent need to be volatile.
Not tested
It works! Thank you :smile:
