Hi there:) I am building a midi console to control ableton with the help of the awesome Control Surface library by tttapa (Control Surface: Main Page)
I want to have some banks so i can map my potentiometers to different settings depending on the bank selected. Also I want to be able to scroll through my tracks(this was solved by using remotify to generate a python script).
Is it possible to use my encoder in the following way:
When connected on the computer and ableton, due to the script installed, by rotating the encocder i scroll through my tracks.
When the push button of the encoder is pressed, my encoder exits scrolling mode and enters bank mode, meaning when i rotate my encoder it scrolls through the different banks.
When the push button of the encoder is pressed again the encoder goes back to scrolling through the tracks
Sure. Debounce* the switch, detect the switch state change*, use the state change to toggle a boolean value which is then used to select either scrolling or bank mode.
No though the problem is that I haven't figured yet how to insert an Encoder Selector in this piece of code so when the button is pressed the Borrowed encoder that will be enabled will function as a bank selector......Any ideas?
