I am still pretty new to Arduinos and am needing some help. I have been searching for a way to do this and trying to follow tutorials to learn with no luck, so I am in dire need of some help here. This is very time sensitive at this point because I only have a few days to get this to work and am doing this as part of a project I have chosen for a class. I will not have access to the physical parts of this project after the next few days and this counts as a significant part of my grade for the overall class. Although this is only a part of a larger project I REALLY need to get this to work to make sure I have a chance to pass the class and don't end up having to spend another year in classes when I get back.
Here's what I'm needing help with:
I am wanting to use an Arduino Mega connected to an ESP 8266 module to read the contents of a MySQL database that is hosted online to act as a remote turn on option.
I have created a PHP script that can access a specific field of a MySQL Table and the script will always return a single digit value of either 0 or 1.
I have setup 3 webpages (1 for each prop) that have buttons on them that change a specific value in the MySQL Table that corresponds to the prop that I want to activate.
I now need to figure out a way to get the Arduino to constantly run the PHP script I have written to monitor the given 1/0 status in the database for the prop it is associated with and retrieve the value so it can be used in the sketch so that when it reads that the 0 has turned into a 1 it will activate a relay attached to it.
I know that this should be possible, but I have been looking around and trying to follow tutorials with no luck and am really desperate at this point. Can someone please help me?
terminal206:
You must have a very good reason to use two processors.
Even a simple WeMos D1 mini is more powerful and has more memory than a Mega.
There are single-relay modules designed to plug directly onto a WeMos.
Leo..
I'm open to any suggestions! I'm just still really new to the Arduino family and already have at least some experience with the Mega, Uno, and Nano boards. I thought it would be easier to start with something I know a little about and expand from there, but if you can help me with a better option and it will be able to do what I am needing I would love to hear about it!
Just an update guys, I have confirmed that I have a solution working for the code on the website side of things!
At this point I just need help with code that will constantly run my PHP script, then activate a relay when the value changes to a 1. I am confident on the physical side of things (relay connection and activation), but if someone could help with the code to monitor the database I would really appreciate it!
Hey everyone, I have been looking into this more after Wawa suggested that I didn't have a need for 2 boards. After looking around for options for a while I have decided to switch to just using an ESP8266 ESP-12E board and attaching a relay board directly to it.
I have written a PHP script that will access the needed value in my database and return either a 1 or a 0 as a result. On receiving a 1 I want the board to turn the relay on, and on receiving a 0 I want the board to make sure the relay is turned off.
I have also come up with the code below to send a HTTP GET request to that PHP script and use the result to determine which "if" statement it should run repeatedly in the loop. I have ordered the ESP-12E boards, but they won't be in for a few days so I have no way to test this and have a deadline to get this done that is VERY close. Would someone mind taking a look at my code to see if it looks valid and/or test it for me to see if it works?
I feel like I am getting close to something here that should be viable! Any help is VERY much appreciated guys!
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
// Declare The Pin The Relay Is Connected To.
char relayPin = 4;
// WiFi Login Info
const char* ssid = "yourWifiName";
const char* password = "yourWifiPassword";
// Create A HTTP Client Instance.
HTTPClient http;
// Host To Get Data From.
const char* host= "http://thehouseofdeath.com/arduino3readscript.php";
// Set The Pin The Relay Is Connected To As An Output.
pinMode(relayPin, OUTPUT);
// Start The Serial Monitor & Try To Connect.
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
// Wait For The WiFi To Connect.
Serial.print(".");
delay(3000);
// Let the user know the WiFi connected and the address of the board.
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Send An HTTP GET Request.
http.begin(host);
int httpCode = http.GET();
String propStatus = http.getString(); // get data from webhost continously
// Just For Debugging.
Serial.print(propStatus);
// If A 1 Is Returned, Activate The Relay.
if(propStatus == "1"){
digitalWrite(relayPin, HIGH);
// If A 0 Is Returned, Make Sure The Relay Is Off.
else if(propStatus == "0"){
digitalWrite(relayPin, LOW);
// Wait 500 milliseconds before sending another request.
// End the HTTP Session.
http.end();
Do you mean you have ordered the WeMos D1 mini, with the ESP-12 module and all the supporting parts?
And the relay module designed for the WeMos D1 mini?
Leo..
'E' or 'F' is only the shape of the module's aerial.
Please forgive my ignorance, as I said I'm still pretty new at this. I think it is called the Node MCU. This is the board I bought:
If you have a spare second to look at my code in the post above, would you mind telling me if there is anything that immediately stands out as if I'm not understanding it's use correctly?
As you can see it causes an exception after a short period of running. I have not looked up the exception in detail but the exception decoder output is...
Exception 28: LoadProhibited: A load referenced a page mapped with an attribute that does not permit loads
PC: 0x40206ed4: HTTPClient::connected() at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 475
EXCVADDR: 0x0101020c
Decoding stack results
0x402012b0: HTTPClient::disconnect(bool) at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 434
0x402056b1: __delay(unsigned long) at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_wiring.cpp line 57
0x40202058: HTTPClient::end() at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 425
0x4020114d: loop() at D:\PortableApps_arduino\portable\sketchbook\temp1/temp1.ino line 66
0x40100175: esp_schedule() at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 125
0x402051c4: loop_wrapper() at D:\PortableApps_arduino\portable\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266\core_esp8266_main.cpp line 197
Your proposed code does not look too bad. It should work in principle I think.
The problem I can imagine is performance and efficiency. Using http to poll a database value continuously for a change in a value is very slow and cumbersome. Far better to have the esp notified in some way when the value has changed.
But I also think there could be a much better, simpler way.
You can simply have the esp modules act as Web servers. You can remotely access them to switch the relays directly. No need for an sql database or php running on a separate server.
This would require that the esp modules and the devices used to access them are on the same netork (maybe give the esp fixed ip addresses for convenience).
If they can't be on the same network, maybe use port forwarding on your router.
Or use the Blynk application, which would make the whole project easy.
Riva - Thank you so much for being willing to try my code out for me. The errors are obviously a problem, but at least I know that it was doing what I intended and that gives me hope that I am on the right track to a solution!
PaulRB - For this particular project the goal is to have users be able to activate the relays from anywhere there is an internet connection, so unfortunately I don't think a local server would work. I do have a bit of experience with port forwarding though, so I may look into something like that later for other projects. I also need to be able to integrate the controls into a personal website so I think that rules Blynk out from what I have seen. Thanks for the suggestions though!
6v6gt - Thanks for the advice on moving the delay, I will definitely do that! Do you think that is part of the stability issue? I've seen your posts in several other threads about HTTP Get calls, and it seems like you really know your stuff and have been able to help a lot of other people get things sorted out! Thanks for taking a look at my code!
Thanks again to all of you for taking the time to check out my posts!
