Using Hardware Serial Library with MIDI
I'm curious to know if anyone has used the Hardware Serial Library with MIDI, and whether or not it supports a 31250 baud (standard MIDI) rate.
There is a program called Midi-Sniffer from the Sparkfun site that uses Software Serial, it seems to work quite well.
I would like to use a Mega 2560 for Midi and use one of its real standard serial ports, or maybe more than one, creating kind of a Midi hub.
Any thoughts?
What is the Hardware Serial Library?
You can use the hardware serial ports of the Mega for MIDI.
See e.g. Control Surface: MIDI Tutorial, where they use a HardwareSerialMIDI_Interface on Serial1.
To create a MIDI hub, have a look at the Routing MIDI messages at the bottom of that page.
Yes, I use the single serial output of a Nano to send and receive using the Midi library.
I was able to get MidiSniffer from Sparkfun to do Midi on Mega 2560 Serial3 with minor changes suggested by another post on this forum (be sure to change all software serial port references to Serial3 in addition).
I asked Chat GPT "
anthony_artmann
Jun '23post #12
OK. It's working! Thanks everyone. Solution posted here.
I asked Chat GPT "How can I set the Arduino MIDI library to use serial port 3?"
It responded:
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI);
// Initialize Serial and MIDI
Serial3.begin(31250);
MIDI.begin(MIDI_CHANNEL_OMNI);
// Your MIDI code here
It responded:
#include <MIDI.h>
