I'm trying to control a strip of LED lights with an IR remote. My code uses a state machine to change the colors of the strip. One of the cases sends the strip into a function that I want to loop through various colors until I press another button on the remote. However, right now it just goes through the colors once and then ends (there's no loop function right now). When I put it in a loop, it will not respond to my IR remote state machine because it's stuck in the loop.
I've heard of using a interrupt service routine to get out of the loop when the value of a pin changes (I would want to use the signal pin from the IR receiver). However, I do not know how I would use the interrupt routine in my code - I've never used them before. Any help? Code for reference. Thanks!
#include <IRremote.h>
#define REDPIN 6
#define GREENPIN 9
#define BLUEPIN 5
#define FADESPEED 5
#define RECEIVER_PIN 2 // define the IR receiver pin
IRrecv receiver(RECEIVER_PIN); // create a receiver object of the IRrecv class
decode_results results; // create a results object of the decode_results class
unsigned long key_value = 0; // variable to store the key value
int r,g,b;
Serial.begin(9600); // begin serial communication with a baud rate of 9600
receiver.enableIRIn(); // enable the receiver
receiver.blink13(true); // enable blinking of the built-in LED when an IR signal is received
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
if (receiver.decode(&results)) { // decode the received signal and store it in results
if (results.value == 0xFFFFFFFF) { // if the value is equal to 0xFFFFFFFF
results.value = key_value; // set the value to the key value
switch (results.value) { // compare the value to the following cases
case 0xFFA25D:
//Serial.println("POWER");]
turnOff();
case 0xFF629D:
Serial.println("VOL+");
case 0xFFE21D:
Serial.println("FUNC/STOP");
case 0xFF22DD:
Serial.println("|<<");
case 0xFF02FD:
Serial.println(">||");
break ;
case 0xFFC23D:
Serial.println(">>|");
break ;
case 0xFFE01F:
Serial.println("DOWN");
break ;
case 0xFFA857:
Serial.println("VOL-");
break ;
case 0xFF906F:
Serial.println("UP");
break ;
case 0xFF6897:
//Serial.println("0");
cycleColors();
break ;
case 0xFF9867:
Serial.println("EQ");
break ;
case 0xFFB04F:
Serial.println("ST/REPT");
break ;
case 0xFF30CF:
//Serial.println("1");
toggleRed();
break ;
case 0xFF18E7:
//Serial.println("2");
toggleGreen();
break ;
case 0xFF7A85:
Serial.println("3");
break ;
case 0xFF10EF:
Serial.println("4");
break ;
case 0xFF38C7:
Serial.println("5");
break ;
case 0xFF5AA5:
Serial.println("6");
break ;
case 0xFF42BD:
Serial.println("7");
break ;
case 0xFF4AB5:
Serial.println("8");
break ;
case 0xFF52AD:
//Serial.println("9");
toggleWhite();
break ;
key_value = results.value; // store the value as key_value
receiver.resume(); // reset the receiver for the next code
delay(50);
void toggleRed(){
analogWrite(GREENPIN, 0);
analogWrite(REDPIN, 0);
analogWrite(BLUEPIN, 0);
for (r = 0; r < 256; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
void toggleGreen(){
for (g = 0; g < 256; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
void turnOff(){
for (r=255,g=255,b=255; r>=0,g>=0,b>=0; r--,g--,b--){
analogWrite(BLUEPIN, b);
delay(FADESPEED);
void cycleColors(){
// fade from blue to violet
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
delay(FADESPEED);
// fade from red to yellow
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
void toggleWhite(){
for (r=0,g=0,b=0; r<256,g<256,b<256; r++,g++,b++){
delay(FADESPEED);
The loop that I would want to create and exit when a button is pushed is the function cycleColors().
